لمن يبحث عن عمليات التكرير باللغة الانجليزية مع المخططات د. هواري - اليمن
النتائج 1 إلى 5 من 5
    المهندس هالي
    المهندس هالي غير متواجد حالياً
    السلام عليكم لمن يبحث عن عمليات تكرير النفط لقد قمت بالبحث عن هذه المعلومات ارجوا ان تعم الفائدة
    Atmosheric Distillation Unit
    Atmospheric Distillation
    Initial crude oil separation is accomplished by creating a temperature and pressure profile across a tower to enable different composition throughout the tower.
    Desalted crude oil is preheated to a temperature of 500-550˚F (260-290˚C) through heat exchange with distillation products, internal recycle streams and tower bottoms liquid. Finally, the crude oil is heated to approximately 750˚F (400˚C) in a fired heater and fed to the atmospheric distillation tower.
    Distillation concentrates lower boiling point material in the top of the distillation tower and higher boiling point material in the bottom. Progressively higher boiling point material is present between the top and bottom of the tower. Heat is added to the bottom of the tower using a reboiler that vaporizes part of the tower bottom liquid and returns it to the tower. Heat is removed from the top of the tower through an overhead condenser. A portion of the condensed liquid is returned to the tower as reflux. The continuous vaporization and condensation of material on each tray of the fractionation tower is what creates the separation of petroleum products within the tower.
    The most common products of atmospheric distillation are fuel gas, naphtha, kerosene (including jet fuel), diesel fuel, gas oil and resid. Atmospheric distillation units run at a pressure slightly above atmospheric in the overhead accumulator. Temperatures above approximately 750˚F (400˚C) are avoided to prevent thermal cracking of crude oil into light gases and coke. With the exception of Coker units, the presence of coke in process units is undesirable because coke deposit fouls refining equipment and severely reduces process performance.
    تحميل الملف المرفق لوحدات التكرير مع الشرح المختصر لكل وحدة
    ادعوا لنا بالتوفيق
    من احفاد اديسون606
    من احفاد اديسون606 غير متواجد حالياً
    الصورة الرمزية من احفاد اديسون606
    جزاك الله خيرا
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    مشكووووووووور على الموضوع الرائع ..............
    khaledc
    khaledc غير متواجد حالياً
    مشكور
    saif alshmary
    saif alshmary غير متواجد حالياً
    رد: لمن يبحث عن عمليات التكرير باللغة الانجليزية مع المخططات د. هواري - اليمن
    thanks alot
