CCTV Headquarters China
النتائج 1 إلى 8 من 8
    كمال محمد
    كمال محمد غير متواجد حالياً
    Received: 19
    Given: 7
    CCTV Headquarters
    The CCTV Headquarters is a skyscraper in the Beijing Central Business District. The building is the headquarters of China Central Television. Groundbreaking took place on September 22, 2004 and the building was completed in December 2008. Rem Koolhaas and Ole Scheeren of OMA were the architects for the building, while Arup provided the complex engineering design. It stands at 234 meters (768 ft) tall and has 51 floors.
    The main building is not a traditional tower, but a continuous loop of five horizontal and vertical sections covering 4,100,000 square feet (381,000 m2) of floor space, creating an irregular grid on the building’s facade with an open center. The construction of the building is considered to be a structural challenge, especially because it is in a seismic zone. Because of its radical shape, it has acquired the nickname dà kùchā , translated into English as "Big Shorts".
    A second building, the Television Cultural Center , includes a hotel, a visitor's center, a large public theatre, and exhibition space. It is visible from the main intersection of the new Central Business District through the window of the main CCTV headquarters building. A media park forms a landscape of public entertainment, outdoor filming areas, and production studios as an extension of the central green axis of the CBD. The Mandarin Oriental Hotel will be part of the complex
    The building was built in two sections that were joined to complete the loop on December 26, 2007. In order not to lock in structural differentials this connection was planned to be completed at the coldest time of night when the steel in the two towers cooled to the same temperature.
    كمال محمد
    Received: 19
    Given: 7
    صور أخرى
    هذه صور أخرى
    كمال محمد
    Received: 19
    Given: 7
    صور أخرى
    وهذه صور أخرى
    كمال محمد
    Received: 19
    Given: 7
    صور أخرى بعد الانتهاء
    صور إضافية بعد الانتهاء
    كمال محمد
    Received: 19
    Given: 7
    المجموعة الأخيرة من الصور
    وهذه المجموعة الأخيرة من الصور وشكرا لكم
    anass81
    anass81 غير متواجد حالياً
    الصورة الرمزية anass81
    Received: 676
    Given: 723
    شكرا لك على هذه الصور وهذا الجهد
    abu Habib
    abu Habib غير متواجد حالياً
    الصورة الرمزية abu Habib
    Received: 48
    مشكوووووووووررررررررررررررررررر
    ahmedfahim
    ahmedfahim غير متواجد حالياً
    شكرا وبارك الله فيك
