le phenomene de raisonnance
النتائج 1 إلى 3 من 3
    ضشسيبل
    ضشسيبل غير متواجد حالياً
    je devant un probleme etude de tribune de stade et tou le monde sait que le phenomene de raisonnance est inevitable y'aurait klk1qui peut m'aider merci d'avance
    إبراهيم أسامة
    الصورة الرمزية إبراهيم أسامة
    Received: 16
    Given: 3
    بلاش فرنساوي
    انجليزي او عربي ممكن
    ضشسيبل
    The bridge's spectacular self-destruction is often used as an object lesson in the necessity to consider both aerodynamics and resonance effects in civil and structural engineering. However the effect that caused the destruction of the bridge should not be confused with forced resonance (as from the periodic motion induced by a group of soldiers marching in step across a bridge).[8] In the case of the Tacoma Narrows Bridge, there was no periodic disturbance. The wind was steady at 42 mph (67 km/h). The frequency of the destructive mode, 0.2 Hz, was neither a natural mode of the isolated structure nor the frequency of blunt-body vortex shedding of the bridge at that wind speed. The event can only be understood while considering the coupled aerodynamic and structural system which requires rigorous mathematical analysis to reveal all the degrees of freedom of the particular structure and the set of design loads imposed.
