من اقوى واسهل برامج تقنية العنصر المحدد finite element برنامج ALGOR Designcheck v23.0
النتائج 1 إلى 3 من 3
    الصورة الرمزية ماجد جلميران
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    ALGOR Designcheck v23.0 SP2
    Win App | 110mb | RS,FBase (Interchangeable)
    With ALGOR DesignCheck finite element analysis (FEA) software, you can verify your single part designs with a first-pass engineering analysis to virtually test the behavior of product designs, speed up time to market and make better, safer products at a lower cost.
    Available directly from the Alibre Design Professional Tools menu as an Add-on, DesignCheck makes it easy to perform finite element modeling and analysis, evaluate results and prepare professional design reports.
    ALGOR DesignCheck includes
    * Direct CAD/CAE data exchange with Alibre Design for single parts
    * Windows-native data input screens
    * Multiple view windows
    * Tree view of the model and associated data
    * Real-time data checking for reasonable input
    * Automatic 3D solid hybrid meshing (bricks on the model surface and tetrahedra inside) with a built-in aspect ratio check
    * Intelligent, automatic, feature-based mesh refinement tools and point-and-click definition of areas where a finer mesh is desired
    * Right-click application, modification and deletion of surface forces, surface constraints and FEA properties
    * Static stress analysis with linear material models
    * Analysis results displayed graphically for von Mises stress and deflected shape
    * Image output in the BMP, JPG, TIF, PNG, PCX and TGA formats
    * Animations through AVI creation and display tools
    * Automatic generation of professional text or HTML design reports
    More Info:
    Homepage
    Download Links :
    http://rapidshare.com/files/19169899....SP2.part1.rar
    http://rapidshare.com/files/19169448....SP2.part2.rar
    Filebase Part1
    Filebase Part2
    فتوح
    فتوح غير متواجد حالياً
    Received: 130
    Given: 148
    جزاك الله خيراً
    وأتمنى إذا يسر الله لك بعمل شرح لهذا البرنامج
    قال الأحنف بن قيس: لا ينبغي للأمير الغضب لأن الغضب في القدرة مفتاح السيف والندامة
    mailzlt
    mailzlt غير متواجد حالياً
    لو سمحت ممكن تشرحنا كيفية تنصيب هدا البرنامج لاني حاولت ومااستطعتش ؟؟؟
