Crane-Supporting Steel Structures: Design Guide
النتائج 1 إلى 4 من 4
    الصورة الرمزية زاد أحمد
    زاد أحمد
    زاد أحمد غير متواجد حالياً
    Received: 17
    Given: 26
    2nd Edition, 2nd Revised Printing - Draft
    R.A. MacCrimmon
    This guide fills a long-standing need for technical information for the design and construction of crane-supporting steel structures that is compatible with Canadian codes and standards written in Limit States format. It is intended to be used in conjunction with the National Building Code of Canada, 2005 (NBCC 2005), and CSA Standard S16-01, Limit States Design of Steel Structures (S16-01).
    This guide provides information on how to apply the current Canadian Codes and Standards to aspects of design of crane-supporting structures such as loads, load combinations, repeated loads, notional loads, monosymmetrical sections, analysis for torsion, stepped columns, and distortion induced fatigue.
    The scope of this design guide includes crane-supporting steel structures regardless of the type of crane. The interaction of the crane and its supporting structure is addressed.
    The Second Edition Draft incorporates crane load combinations in the proposed CSA S16 Appendix C.
    134 pages (0.9 MB)i
    http://ifile.it/abmyl05/craneguidedraft2e2p.pdf
    mashaly
    mashaly غير متواجد حالياً
    thanxxxx ya man
    good work
    eng-kizo
    eng-kizo غير متواجد حالياً
    السلام عليكم ... انا سعيد جدا بأول مشاركة لي
    واتمنى ان يعين الله القائمين على اعمال المنتدى ومساعدة الاخوة العضاء
    Eng. Mithaq
    Eng. Mithaq غير متواجد حالياً
    مشكوررررررررررررررررررررررر
