Crane-Supporting Steel Structures: Design Guide
النتائج 1 إلى 4 من 4
    الصورة الرمزية زاد أحمد
    زاد أحمد
    زاد أحمد غير متواجد حالياً
    Received: 17
    Given: 26
    2nd Edition, 2nd Revised Printing - Draft
    R.A. MacCrimmon
    This guide fills a long-standing need for technical information for the design and construction of crane-supporting steel structures that is compatible with Canadian codes and standards written in Limit States format. It is intended to be used in conjunction with the National Building Code of Canada, 2005 (NBCC 2005), and CSA Standard S16-01, Limit States Design of Steel Structures (S16-01).
    This guide provides information on how to apply the current Canadian Codes and Standards to aspects of design of crane-supporting structures such as loads, load combinations, repeated loads, notional loads, monosymmetrical sections, analysis for torsion, stepped columns, and distortion induced fatigue.
    The scope of this design guide includes crane-supporting steel structures regardless of the type of crane. The interaction of the crane and its supporting structure is addressed.
    The Second Edition Draft incorporates crane load combinations in the proposed CSA S16 Appendix C.
    134 pages (0.9 MB)i
    http://ifile.it/abmyl05/craneguidedraft2e2p.pdf
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    مشكور جدا يا باشمهندس زاد وجزاك الله خيرا
    الإمام محمد الغزالي
    مصطفى ساطع
    مصطفى ساطع غير متواجد حالياً
    الصورة الرمزية مصطفى ساطع
    جزاك الله خيرا"
    عزام عبدالناصر
    عزام عبدالناصر غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية عزام عبدالناصر
    جزاك الله كل خير
