cassion footings
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 18 من 18
    م.ضياء علاء
    م.ضياء علاء غير متواجد حالياً
    الصورة الرمزية م.ضياء علاء
    An example of Geotechnical analysis for drilled circular footings(bored-and-cast-in-place) for the interior columns footings to be used to support a four story proposed structure. I used the guide lines of the Canadian Foundation Engineering Manual 4th. Edition with additional references such as Soil mechanics by R.F. Craig and Soil mechanics in engineering practice by TERZAGHI, K. and PECK, R.B.
    I considered these factors which govern the bearing capacity and settlement:
    1. The depth to diameter ratio of 2.5 to 1.
    2. The effect of drilling is to cause a relief of lateral pressure on the walls of the hole which results in swelling of the clay and there will be a migration of pore water towards the exposed clay face(unless bentonite slurry will be used to prevent this condition) ,which shall weaken the soil around the footing and eliminate the skin friction therefore, I considered them as end-bearing piles.
    3. Experience of a very large number of loading tests taken to failure, made on piles of diameters up to about 1200mm and of many types both in clays and sands, has shown that if a safety factor of 2.5 is applied, then the settlement at the working load is unlikely to exceed 30mm.
    4. Condition of the base of the drilled hole with respect to removal of drill cuttings and other loose debris to prevent uncontrolled settlement.
    5. The Ultimate end-bearing pressure of drilled circular footing in clayey soil (using undrained shear strength obtained by Vane Shear tests (the term ru)) is calculated from the equation
    * ru=5 µ τu (1+0.2D/B) (1+0.2B/L) + σo
    where ru is the Ultimate bearing capacity, µ Vane strength reduction factor(equal to 0.9), τu is the undrained shear strength obtained by Vane Shear tests, σo is the overburden pressure(γD).
    The minimum τu in native clayey silt subsoil( 2.5 m below the anticipated finish floor level) was 200 Kpa
    and D/B =2.5
    and B/L=1(circular footing)
    and σo=γD=18*2.5=45 Kpa→ average γ for the 2.5 m below the anticipated finish floor level=18 KN/m³
    ru=5*0.9*200*1.5*1.2+45= 1665 Kpa
    Allowable bearing pressure= ru/2.5= 666 Kpa→ I used 650Kpa
    م.ضياء علاء
    الاخ أبو الحلول
    نعم يصلح لمعظم أنواع التربة ولكن طريقة العمل وحساب bearing capacity يختلف من تربة لأخرى
    م.ضياء علاء
    الاخ أنس
    شكرا على الروابط وبالنسبة هل هي footing أو foundation
    الاسم العلمي هو foundation ولكن ليس الشائع بمعنى أنك لو تحدثت مع الناس( حتى بعض المهندسين) هنا في كندا وقلتfoundation فسوف يعتقدون أنك تقصد مؤسسة ما
    م.ضياء علاء
    كذالك bearing capacity أو bearing pressure
    الشائع bearing pressure
    anass81
    anass81 غير متواجد حالياً
    الصورة الرمزية anass81
    Received: 679
    Given: 724
    اقتباس المشاركة الأصلية كتبت بواسطة م.ضياء علاء مشاهدة المشاركة
    أخواني العزاء ,
    لمست من خلال قرأتي لبعض مواضيع الاساسات في هذا الموقع الكريم خلطاً بين الاساسات العميقة البايلات وcassion footings
    للعلم الكيسون يعتبر اساس سطحي وليس بايل ويعتد فقط على bearing end فقط
    ومصطلح الكيسون يستخدم فقط للاساسات الدائرية التى تيم عملها كثقوب لابعاد متفاوتة وصبها بالخرسانة
    وهذا النوعية من الاساسات تستخدم بشكل كثير في شمال أمريكا خاصة للبنايات التجارية وبعض البنايات السكنية لسرعتها و أقتصاديتها وتحملها لاحمال عالية
    ولتبين الصورة لنفرض أن هنالك أرض خالية في وسط مدينةوأننا أردناعمل بيناية فيها وبعد عمل فحص التربة أكتشفنا أن التربة لاول ٥م غير صالحة ما العمل هل نحفر لعمل اساس سطحي؟أو نصمم وننفذ بايلات تحتاج وقت ومال؟لا تنسوا أن الهندسة أيضا توفير مال وجهد ،أن عمل الكيسون هوأسرع وأوفر حل ولايحتاج الى خفركل قطعة الارض وانما عمل ثقوب باقطار صغيرة وحتى بدون اية أعمال نجارة!!
    أن مفهوم وعمل الكيسون غير متبع في الوطن العربي وأنا من واقع خبرتي كمهندس تربة مرخص في كندا P.ENG أرى أنه أفضل نظام أساسات للبنايات التى لاتتجاوز الخمسة طوابق ومفيد جدا في غير ذلك
    اما لماذا يعتبر الكيسون اساس سطحي وليس بايل فهذا له تفسير علمي سأذكره في مداخلة قادمة أن شاء الله
    الاخ ضياء
    لم يكن قصدي هو تصحيح ال Foundation وانما تصحيح كلمة Caisson التي وردت في مشاركتك الاولى
    جزاك الله خيرا على معلوماتك القيمة
    م.ضياء علاء
    ذكرني الاخ أنس بحادثة طريفة حدثت معي ,عندما بدأت الشغل في كندا عملت لفترة في مساحة الطرق, وكلنا يعرف الثيدولايت في أول يوم عمل لي كان كل شخص في فريق العمل الذي معي يتحدث عن الترانزشن وأين سوف يضعونة وأشياء أخرى عنه وأنا أعتقدت أنهم يتحدثون عن المراحل الانتقالية في الكيرفات الرئسية بينما كانوا يقصدون الثيدولايت ويسمونه الترانزشن!!
    م.ضياء علاء
    الاخ أنس بارك الله فيك آسف لبعض الاخطاء الاملائية بالعربي و الانجليزي وذلك لانني ليس عندي لوحة مفاتيح عربية وأنمااستخدم
    http://www.arabic-keyboard.org/
    لكتابة موضوعي وقد تحدث مثل تلك الاخطاء
    بسام.م.ب
    بسام.م.ب غير متواجد حالياً
    الصورة الرمزية بسام.م.ب
    Received: 36
    جزاك الله خيرا يأخ أنس...
    بسام
