اخواني اعضاء المنتدى مساعدة عاجلة جداجدا
النتائج 1 إلى 2 من 2
    ابوميدو
    ابوميدو غير متواجد حالياً
    اخواني لو ممكن مساعدتي
    مطلوب مني بحث وصراحة تعب وانا ادور ما حصلت
    مطلوب ايجاد 4 مشاكل ميكانيكية في تخصص انتاج الصناعي وحلها بحد كل مشكلة صفحة واحدة باللغة الانجليزية او العربية
    او 4 مواضيع عن التطوير في نفس المجال بحد اقصى صفحة لكل تطوير
    مطلوب مني يوم الاثنين
    الي عندة معلومة لا يبخل علينى تحياتي
    مهندس سورجي
    مهندس سورجي غير متواجد حالياً
    In the Name of God More merciful
    Dear Sir thr fowlloaing description is one of the problem accured during the mechanical Engineering.
    In this paper, a computer aided methodology of classification of flaws, which are formed in aluminium alloys during production of elements for car engines with the low-pressure casting method is presented. The flaw identification was performed on the basis of digital recorded data registered by the use of X-ray image analysis method. In order to solve this problem, an elaborated methodology and related computer programmes for X-ray images analysis, as well as the preparation of entrance data for neuronal networks and also the quality cast control were used. The classification results of the best type of every network investigated are presented. Analysing a number of correct classifications of pointed out test data, the classifying problems are evaluated.
