اكبر مكتبة متخصصة فى برامج التصميم فى العالم الجزء 5,4,3,2,1
صفحة 30 من 30 الأولىالأولى ... 2026 27 28 29 30
النتائج 291 إلى 300 من 300
  1. [291]
    أحمد مختار محمود
    أحمد مختار محمود غير متواجد حالياً
    Up and Running with Autodesk Inventor Simulation 2010: A Step-by-Step Guide to Engineering Design Solutions
    Wasim Younis, "Up and Running with Autodesk Inventor Simulation 2010: A Step-by-Step Guide to Engineering Design Solutions"
    Butterworth-Heinemann | 2009 | ISBN: 1856176940 | 352 pages | PDF | 21,8 MB
    Inventor Simulation is an essential part of the Autodesk Digital Prototyping process. It allows engineers and designers to explore and test components and products virtually, visualizing and simulating real-world performance.
    Up and Running with Autodesk Inventor Simulation 2010 is dedicated to the requirements of Inventor users who need to quickly learn or refresh their skills, and apply the dynamic simulation, assembly analysis and optimization capabilities of Inventor Simulation 2010.
    Step-by-step approach gets you up and running fast
    Discover how to convert CAD models to working digital prototypes, enabling you to enhance designs, reduce over design, failure, and the need to create physical prototypes
    Extensive real-world design problems explore all the new and key features of the 2010 software, including assembly stress analysis; parametric optimization analysis; creating joints effectively; avoiding redundant joints; unknown force; logic conditions; and more.
    Tips and guidance you to tackle your own design challenges with confidence
    Companion site (elsevierdirect.com/companions) provides Simulation datasets for the design problems in the book that enable you to apply, experiment and manipulate solutions, and move on to solving your own design problems. Inventor Simulation is an essential part of the Autodesk Digital Prototyping process. It allows engineers and designers to explore and test components and products virtually, visualizing and simulating real-world performance.
    http://rapidshare.com/files/407490240/1856176940.pdf
  2. [292]
    Mohamedabdall_z
    Mohamedabdall_z غير متواجد حالياً
    اخى العزيز المهندس احمد انا اشكرك على هذا المجهود الجبار فى تحميل هذه البرامج الجميلة جدا
    عزيزى انا محتاج تحميل برنامج Autodesk Algor Simulation Professional v2011 Multilinguale
    وبرنامج Autodesk Autocad Inventor Suite 2011
    ارجو يكون التحميل من لنكات التورنيت لأن جميع النكات يكون فيه مشاكل
    واسال الله لك العفو والرضا والستر فى الدنيا والأخرى
    ارجوك انا متظر الرد منك بسرعة ولك جزيل الشكر اخوك المهندس محمد عبدالله
  3. [293]
    masry aseel
    masry aseel غير متواجد حالياً
    الف شكككككككككككككر
  4. [294]
    ABDERRAHIMSUP
    ABDERRAHIMSUP غير متواجد حالياً
    الصورة الرمزية ABDERRAHIMSUP
    بسم الله الرحمن الرحيم أللهم كثر من أمثالك قول وفعل ليس كالآخيرن الذين يكذبون على الناس الذين يقلون أدخل الموقع ولا لا لا لايجدون شيييييييييييييييييأ
  5. [295]
    ABDERRAHIMSUP
  6. [296]
    raafat abo abdou
    raafat abo abdou غير متواجد حالياً
    الصورة الرمزية raafat abo abdou
    اللينكات مش شغالة يا باشمهندس
    أخيكم
    رأفت أبوعبده
  7. [297]
    مهندس كتر
    مهندس كتر غير متواجد حالياً
    الصورة الرمزية مهندس كتر
    مجهود ليس له مثيل
    CATR66H
  8. [298]
    محمد دامرلي
    محمد دامرلي غير متواجد حالياً
    الروابط لا تعمل ارجو المساعدة
    الروابط لا تعمل ارجو المساعدة بتنزيلها على اي موقع ولكم جزيل الشكر
  9. [299]
    hamzawey92
    hamzawey92 غير متواجد حالياً
    اللينكات كلها مش شغالة يابشمهندس ياريت لينك للسوليد وورك 32 بيت لينك واحد او اتنين بس شغالين وشكرا
  10. [300]
    مرتضى ال جحمان
    مرتضى ال جحمان غير متواجد حالياً
    ادهشتنى اخى الفاضل متعك الله بالصحه والعافية . هل يوجد اتوكاد للرسم الكهربائي ؟
