traduction svp
النتائج 1 إلى 5 من 5
    sonia13
    sonia13 غير متواجد حالياً
    traduction svp
    Translate into French language the following text and try to understand why viscosity increases with temperature for gases and decreases for liquids
    Viscosity in Gasses
    The molecules of gasses are only weakly kept in position by molecular cohesion (as they are so far apart). As adjacent layers move by each other there is a continuous exchange of molecules. Molecules of a slower layer move to faster layers causing a drag, while molecules moving the other way exert an acceleration force. Mathematical considerations of this momentum exchange can lead to Newton law of viscosity.
    If temperature of a gas increases the momentum exchange between layers will increase thus increasing viscosity.
    Viscosity will also change with pressure - but under normal conditions this change is negligible in gasses.
    Viscosity in Liquids
    There is some molecular interchange between adjacent layers in liquids - but as the molecules are so much closer than in gasses the cohesive forces hold the molecules in place much more rigidly. This cohesion plays an important roll in the viscosity of liquids.
    Increasing the temperature of a fluid reduces the cohesive forces and increases the molecular interchange. Reducing cohesive forces reduces shear stress, while increasing molecular interchange increases shear stress.
    من مواضيع sonia13 :
    bobstream
    bobstream غير متواجد حالياً
    الصورة الرمزية bobstream
    La viscosité dans des Gaz que les molécules de gaz sont seulement faiblement gardées dans la position par la cohésion moléculaire (comme ils sont jusqu'ici à part). Comme le mouvement de couches adjacent l'un par l'autre il y a un échange continu de molécules. Les molécules d'une couche plus lente se déplacent aux couches plus rapides causant une traînée, tandis que les molécules déplaçant l'autre voie exercent une force d'accélération. Les considérations mathématiques de cet échange d'élan peuvent mener à la loi de Newton de viscosité.
    Si température
    bobstream
    Viscosité dans Liquides
    Il y a un peu d'échange moléculaire entre des couches adjacentes dans des liquides - mais comme les molécules sont tellement tout près que dans des gaz les forces cohésives tiennent les molécules en place beaucoup plus rigidement. Cette cohésion joue un rouleau(rôle) important dans la viscosité de liquides.
    L'augmentation de la température d'un liquide réduit les forces cohésives et augmente l'échange moléculaire. La réduction de forces cohésives réduit tondent le stress(l'accent), en augmentant moléculaire
    bobstream
    بالتوفيق أختي في الدراسة
    sonia13
    merci bcp mon frére
