الفرق بين المحولات الجافة والمحولات السائلة
النتائج 1 إلى 10 من 33
    Rana Alhanbali
    Rana Alhanbali غير متواجد حالياً
    The difference between Oil cooled Transformer and Dry type transformer is so much that we need to write a full article. A brief of points are appended below.
    Advantages of dry type transformer
    Low maintenance cost. Needs only to be cleaned of dust.1.
    OCT needs regular oil checking, filtration and replacement of oil which is
    very costly and need high recurring expense.
    2. Can be installed very close to load center hence can save low voltage
    Transmission losses, which is substantial recurring saving and advantage on energy conservation step. (Considering the present day energy shortage).
    3. Need comparatively less space for installation and can be integrated with VCB control unit to make a single unit to save space for HT switching panel
    4. Reduce fire hazard in substation since no oil is used.
    Disadvantage
    Non-repairable unlike OCT if there is damage to winding if it is cast resign type.
    The safety of over heating is through sensors which should be monitored regularly to ensure safety against overloading and fault conditions.
    Regular dust cleaning if not carried out, can result in damage to transformer.
    The cost difference and pay back period will depend on each case study which you will have to calculate depending on site conditions.
    hemasalam
    hemasalam غير متواجد حالياً
    شكرا - بس ممكن اعرف ايهما افضل وعلى اى اساس يتم اختيار المحول الزيتى او المحول الهوائى 0 (السعر - الكفاءة - الامان - 0000 )
    يوسف_555
    يوسف_555 غير متواجد حالياً
    الصورة الرمزية يوسف_555
    شكرا ارجو تفسير اوضح بالعربى
    hemasalam
    مقارنة بين المحولات الجافة والمحولات الزيتيةالمحولات الجافة - Dry Transformerالمحولات الزيتية - Oil Transformer1الحجم لنفس القدرة - Dimensionsأقل - Small sizeأكبر حجما - Bigger size2الصيانة - Maintenanceنظافة فقط - Clean onlyنظافة + تغيير زيت - Clean + Oil changing3تأثير النار - Fire impactاطفاء ذاتى - Self distinguishingيمكن انفجاره - Possibility for Explosion4التحميل المستمر - Loading 100%80%5زيادة الحمل - Operation at over loadحتى 40% زيادة بوجود تهوية جبرية - Up to 40% with the fansحتى 33% زيادة بتهوية جبرية - Up to 33% with fans6المفاقيد فى اللاحمل - Losses at no loadعالية - Highمعتدله - Moderate7المفاقيد فى الحمل الكامل - Losses at full load عالية - Highمعتدله - Moderate8التركيب - Installationيمكن وضعه قريب من أماكن الاستهلاك وبالتالى توفير الكابلات - Installation close to the consumers - Reduce cable costsيفضل وضعه بمكان آمن - Installation in safe place9السعر - Priceحوالى 1.5 المحول الزيتى
    hemasalam
    انا الحقيقة عملت جدول مقارنة بين المحولات الجافة والمحولات الزيتية بس عشان انزله لازم المشاركات
    تكون اكثر من 100 مشاركة - ارجوا المعذرة
    my pen
    my pen غير متواجد حالياً
    ajeeljabbar
    ajeeljabbar غير متواجد حالياً
    الصورة الرمزية ajeeljabbar
    المشاركة غير واضحة لاهي بالعربي ولا بالانكليزي
    hemasalam
    هاحاول اوضح الفرق قدر الامكان
    المحول الجاف لنفس القدرة بالنسبة للزيتى - أقل بالحجم ويمكن وضعه داخل المبانى بصورة آمنة
    المحول الجاف صيانتة اسهل من الزيتى حيث يحتاج الى نظافة فقط اما الزيتى نظافة وفلترة الزيت ثم غياره بعد مدة
    المحول الجاف مقاوم للحريق بينما الزيتى يمكن انفجاره
    المحول الجاف يمكن تحميله بصفة مستمرة بنسبة 100% بينما الزيتى حوالى 80 %
    المحول الجاف يمكن تحميله بزيادة 40 % مع وجود تهوية جبرية ( مراوح شفط ) بينما الزيتى يمكن تحميله بزيادة 33 % مع وجود تهوية جبرية
    يعتبر كل ما سبق مميزات للمحول الجاف وفيما يلى عيوبه
    المحول الجاف نسبة المفاقيد فى حالة الحمل وحالة اللاحمل عالية جدا مقارنة بالمحول الزيتى 0
    المحول الجاف سعره حوالى 1.5 سعر المحول الزيتى ( المساوى له فى القدرة )
    1 Not allowed!
    علي راشد
    علي راشد غير متواجد حالياً
    مشكور ...............
    ta wfeek2009
    ta wfeek2009 غير متواجد حالياً
    الصورة الرمزية ta wfeek2009
    شكر جزيلا يا مهندسين جزاكمالله خييييييييييييييييييييييييييييييييييييييييييييييييي يييييييييييير
