Keybad acces door
النتائج 1 إلى 2 من 2
    omer7166
    omer7166 غير متواجد حالياً
    Keybad acces door
    I need help if possible ..
    Can you write the code for these electronic circuit:
    Keybad acces door
    The idea of work:
    1 - The user enter six digit.If the code entered was a valid code, then the red and
    green LEDs will flash back and forth for 2 seconds. During this time
    the relay will be energized .
    2- you can change your password .
    3- If the user enetr invalid code number for five times . the circuit Will not respond Even five minutes is going
    Note : using PIC 16F84A.
    2 - I'm very sorry for Inconvenience, but I need to help soon, because the project would be handed over within a week from now.
    Thank you very much ..
    OMER7166*************
    من مواضيع omer7166 :
    الصور المرفقة
    محمدالقبالي
    محمدالقبالي غير متواجد حالياً
    الصورة الرمزية محمدالقبالي
    Received: 28
    Given: 36
    in which language do you want the program
    assemply or PICBasic
    chose on of these langauges and i tray to help as sson as possiable
    سبحان الله وبحمده -- سبحان الله العظيم
