expansion Tank
النتائج 1 إلى 10 من 23
    الصورة الرمزية المهندس مضر
    المهندس مضر
    المهندس مضر غير متواجد حالياً
    expansion Tank
    السلام عليكم ، أرجو من الأخوة المهندسين الذين لديهم خبرة ومعرفة في حسابات الـ expansion tank أن يطلعنا عليها ، وخاصة intial pressure and maximum working pressure
    وبارك الله فيكم
    bobstream
    bobstream غير متواجد حالياً
    الصورة الرمزية bobstream
    أولا هيا جهاز يستعمل للحماية الدارة من الأنفجار ناتج عن زيادة حجم منسوب المياه نتيجة زيادة حرارة
    أما الجهاز يكون أسطواني الشكل به تجويف فيه هواء حيت لما يزيد منسوب المياه يضغط الهواء لكي يأخذ مكانه
    [IMG]file:///C:/DOCUME%7E1/admin/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG]
    [IMG]file:///C:/DOCUME%7E1/admin/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG] [IMG]file:///C:/DOCUME%7E1/admin/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
    bobstream
    bobstream
    Expansion tanks are required in heating, cooling or air condition systems to avoid unacceptable increase of system pressures during heat-up.
    Expansion tanks are in general designed as
    • open tanks
    • closed compression tanks
    • diaphragm tanks
    Net expansion of water can be expressed as
    Vnet = (v1 / v0) - 1 (1)
    Vnet = necessary expansion volume of water (gallon, liter)
    v0 = specific volume of water at initial (cold) temperature (ft3/lb, m3/kg)
    v1 = specific volume of water at operating (hot) temperature (ft3/lb, m3/kg)
    Open Expansion Tanks
    Required volume of an open expansion tank can be expressed as
    Vet = k Vw [(v1 / v0) - 1] (2)
    Vet = required expansion tank volume (gallon, liter)
    k = safety factor (approximately 2 is common)
    Vw = water volume in the system (gallon, liter)
    With an open expansion tank fresh air absorbed to the water tend to corrode the system. Open expansion tanks must be located above the highest heating element, in general on the top of buildings, where it may be exposed to freezing.
    Closed Compression Expansion Tanks
    Closed compression tanks can be designed as
    • adjustable expansion tank - air is evacuated or injected by an automatic valve to the tank to control the system pressure when the temperature and expansion of the water rise or falls
    • pump-pressured cushion tank - water is evacuated or injected to compensate temperature rice or fall
    • compression tank with a closed gas volume - the tank contains a specific volume of gas which is compressed when the temperature and system volume increase.
    The required volume of closed expansion tanks can be expressed as
    Vet = k Vw [ ( v1 / v0 ) - 1 ] / [ ( pa / p0 ) - ( pa / p1 ) ] (3)
    where
    pa = atmospheric pressure - 14.7 (psia)
    p0 = system initial pressure - cold pressure (psia)
    p1 = system operating pressure - hot pressure (psia)
    • initial temperature 50oF
    • initial pressure 10 psig
    • maximum operating pressure 30 psig
    Diaphragm Expansion Tanks
    The required tank volume of diaphragm expansion tank can be calculated as
    Vet = k Vw [ ( v1 / v0 ) - 1 ] / [ 1 - ( p0 / p1 ) ] (4)
    • initial temperature 50 oF
    • safety factor aprox. 2
    • acceptance factor aprox. 0.5
    Example - Volume Open Expansion Tank
    The minimum volume of an open expansion tank for a system with 1000 gallons of water heated from 68 oF to 176 oF can be calculated as
    Vet = 2 (safety factor) (1000 Gallons) [( (0.01651 ft3/lb) / (0.01605 ft3/lb) ) - 1]
    = 57 (gallons)
    المهندس مضر
    thank you very much boss , really I apreciate your help
    م عبدالحكيم نعمه
    م عبدالحكيم نعمه غير متواجد حالياً
    بارك الله فيك
    NAK
    NAK غير متواجد حالياً
    الصورة الرمزية NAK
    Received: 10
    بارك الله فيك و رحم الله والديك و جزاك الله خيراً
    عبدالله المنسوب
    عبدالله المنسوب غير متواجد حالياً
    Thumbs up
    أرجو الإفاده عن وظيفة خزان التمدد
    ابو اسامة63
    ابو اسامة63 غير متواجد حالياً
    Received: 49
    في الموضوع التالي يوجد شرح عن خزان التمدد المفتوح في التدفئة وذلك في المشاركات 22 و 23 و 24 ارجو ان تفيدك
    http://www.arab-eng.org/vb/t132957-2.html
    السيدعبدالمجيد
    السيدعبدالمجيد غير متواجد حالياً
    أتمنى من ألاخ الكريم أن يساعدنى فى diaphragm expansion tank
