كتاب مرجع في صيانة وتصليح المعدات الكهربائية
النتائج 1 إلى 10 من 24
    المعرفة1900
    المعرفة1900 غير متواجد حالياً
    ارجو ان لا يكون الموضوع مكرر واذا كتن فأعتذر مقدما
    الرابط:
    http://ifile.it/y1vajt/electrical_eq...aintenance.pdf
    Electrical Equipment Handbook : Troubleshooting and Maintenance
    Summary:Maximize your company?s energy output while ensuring the reliability and longevity of your industrial electrical equipment!
    Everything you need for selection, applications, operations, diagnostic testing, troubleshooting and maintenance for all capital equipment placed firmly in your grasp. Keeping your equipment running efficiently and smoothly could make the difference between profit and loss. Electrical Equipment Handbook: Troubleshooting and Maintenance provides you with the state-of?the-art information for achieving the highest performance from your transformers, motors, speed drives, generator, rectifiers, and inverters. With this book in hand you'll understand various diagnostic testing methods and inspection techniques as well as advance fault detection techniques critical components and common failure modes. This handbook will answer all your questions about industrial electrical equipment.
    In Electrical Equipment Handbook: Troubleshooting and Maintenance, you will:
    Learn about the various types of transformers, motors, variable speed drives, generators, rectifiers, inverters, and uninterrupted power systems.
    Understand diagnostic testing and inspection, advanced fault detection techniques, critical components, and common failure modes.
    Study selection criteria, commissioning requirements, predictive and preventive maintenance, reliability, testing and cost discover the maintenance required to minimize their operating cost and maximize their efficiency, reliability and longevity.
    Synopsis:
    FOR ENGINEERS OF ALL DISCIPLINES, MANAGERS, TECHNICIANS, MAINTENANCE PERSONNEL, AND OTHER TECHNICAL INDIVIDUALS.
    HERE?S WHERE TO TURN WHEN YOU HAVE ANY QUESTION ABOUT INDUSTRIAL ELECTRICAL EQUIPMENT
    This fact-packed resource provides the detailed, wide-ranging, state-of-the-art coverage you need to maximize your company?s energy output while ensuring the reliability and longevity of your industrial electrical equipment.
    With this handbook you?ll be able to achieve the highest performance possible from your transformers, motors, variable speed drives, generators, rectifiers, inverters and circuit breakers and gain a full understanding of these crucial aspects of industrial electrical equipment:
    * Diagnostic testing and inspection methods
    * Advanced fault detection techniques, critical components and common failure modes
    * Predictive and preventative maintenance, reliability and testing methods
    * Equipment selection and their best application
    This is the book you must own if minimizing operating costs, maximizing efficiency and having fingertip access to sound, reliable answers to any electrical equipment problem is important to you.
    Keeping your equipment running smoothly can mean the difference between profit and loss ? here?s the handbook that tells you how!
    Table of *******s
    Preface
    Acknowledgments
    Chapter 1: Fundamentals of Electric Systems
    Chapter 2: Introduction to Machinery Principles
    Chapter 3: Transformers
    Chapter 4: Transformer Components and Maintenance
    Chapter 5: AC Machine Fundamentals
    Chapter 6: Induction Motors
    Chapter 7: Speed Control of Induction Motors
    Chapter 8: Maintenance of Motors
    Chapter 9: Power Electronics, Rectifiers, and Pulse-Width Modulation Inverters
    Chapter 10: Variable-Speed Drives
    Chapter 11: Synchronous Machines
    Chapter 12: Synchronous Generators
    Chapter 13: Generator Components, Auxiliaries, and Excitation
    Chapter 14: Generator Main Connections
    Chapter 15: Performance and Operation of Generators
    Chapter 16: Generator Surveillance and Testing
    Chapter 17: Generator Inspection and Maintenance
    Chapter 18: Generator Operational Problems and Refurbishment Options
    Chapter 19: Circuit Breakers
    Chapter 20: Fuses
    Chapter 21: Bearings
    Chapter 22: Used-Oil Analysis
    Chapter 23: Vibration Analysis
    Chapter 24: Power Station Electrical Systems & Design Requirements
    Chapter 25: Power Station Protective Systems
    عبدالرحمن المخلافي
    عبدالرحمن المخلافي غير متواجد حالياً
    الصورة الرمزية عبدالرحمن المخلافي
    مشكووووووووووووووووووووووووو اخييييي
    كتوموتو
    كتوموتو غير متواجد حالياً
    hfhcfhfhfhfhfugfutgugugugug
    abueseem
    abueseem غير متواجد حالياً
    مشكووووووووووووووووووووووووووووووووووووور يا طيب
    و بصراحه انا هاد الكتاب اللي كنت بستنا فيه
    علاء نجار
    علاء نجار غير متواجد حالياً
    الف شكر
    automation
    automation غير متواجد حالياً
    مشكوررررررررررررررررررر
    essamyoussry
    essamyoussry غير متواجد حالياً
    جزاك الله خيرا
    eng h a
    eng h a غير متواجد حالياً
    الف شكر على هذة الهدية القيمة
    محمد ضو
    محمد ضو غير متواجد حالياً
    http://www.4shared.com/file/95440656...book_.html?s=1
    هذا رابط اخر للتحميل
    مشكووووووووووووووووور
    anass0300
    anass0300 غير متواجد حالياً
    مشكوررررررررررررررررررر الف شكر على هذة الهدية القيمة
