Distructive Blow Out in Iran
النتائج 1 إلى 4 من 4
    فيصل الطائي
    فيصل الطائي غير متواجد حالياً
    Received: 10
    this file shows some images taken from an Iranian well was blown out because the crew failed to keep the well filled in with the drilling fluid so the hydraustatic pressure became less than the necessary pressure allowing the formation fluids to flow into the borehole.
    after the kick: the well is blown, the rig is 100% distructed and the well site engineer is seated down chewing the asses of his careless crew. more than that is in the pdf file
    من مواضيع فيصل الطائي :
    .قال ما اسم هذه الارض؟
    فاجابوه نينوا يبن رسول الله
    قال وهل لها اسما اخر؟
    فاجابوه الغاضرية
    فقال وهل لها اسم ثالث؟
    فأجابوه: نعم اسمها كربلا
    قال فانزلوا الركب ها هنا, جنة الخلد حولنا.
    احمد العروشي
    احمد العروشي غير متواجد حالياً
    thanks
    i think this mistake not from the crew but the respontly from the driller because he can say the order that control in the well.
    فيصل الطائي
    Received: 10
    you are right
    yes you are right but don't you think that all the team should be aware of filling the well occasionally? specially when they are pulling the string out of the well
    فاجابوه الغاضرية
    mechat_eng
    mechat_eng غير متواجد حالياً
    i think the responsibility for all team
