ما المقصود بـ By Pass Factor عند الكلام عن التكييق المركزي
النتائج 1 إلى 10 من 17
    الصورة الرمزية majdy82
    majdy82
    majdy82 غير متواجد حالياً
    mona.noor
    mona.noor غير متواجد حالياً
    bypass factor of an evaporator is used to indicate when an air filter of an HVAC is clogged. The bypass factor represents the amount of air that is bypassed without direct contact with the evaporator. As the air filter clogs, the bypass factor decreases. The bypass factor can also be used for early detection of clogging of the air filter. A first bypass factor is calculated by using the temperature measurements, and a second bypass factor is calculated by using the airflow rate of the air. The difference between the two bypass factors determines the error. An increase in the error indicates that the air filter is clogged. A coefficient of performance of the evaporator can also be calculated to detect if the air filter is clogged. A decrease in the coefficient of performance indicates that the air filter is clogged.
    dido067
    dido067 غير متواجد حالياً
    Perfect Answer
    اقتباس المشاركة الأصلية كتبت بواسطة mona.noor مشاهدة المشاركة
    bypass Factor Of An Evaporator Is Used To Indicate When An Air Filter Of An Hvac Is Clogged. The Bypass Factor Represents The Amount Of Air That Is Bypassed Without Direct Contact With The Evaporator. As The Air Filter Clogs, The Bypass Factor Decreases. The Bypass Factor Can Also Be Used For Early Detection Of Clogging Of The Air Filter. A First Bypass Factor Is Calculated By Using The Temperature Measurements, And A Second Bypass Factor Is Calculated By Using The Airflow Rate Of The Air. The Difference Between The Two Bypass Factors Determines The Error. An Increase In The Error Indicates That The Air Filter Is Clogged. A Coefficient Of Performance Of The Evaporator Can Also Be Calculated To Detect If The Air Filter Is Clogged. A Decrease In The Coefficient Of Performance Indicates That The Air Filter Is Clogged.
    Perfect Answer
    م/سليمان333
    م/سليمان333 غير متواجد حالياً
    معامل الامرار الجانبى ( ومعناها الهواء الذى دخل الى وحدة التكييف ولكن لم يتلامس مع سطح المبخر وبالتالى لم يتم تبريدة بشكل جيد ) واللة اعلم
    خالد العسيلي
    خالد العسيلي غير متواجد حالياً
    عضو داعم للملتقى
    الصورة الرمزية خالد العسيلي
    Received: 26
    الشكر الجزيل لكل الإخوة الذين شاركونا بالمعلومات القيمة
    ادعوا لأخيكم ان ييسر الله أمره ويفرج كربه
    و ادعوا لإخوتكم في سورية أن يكتب لهم الله النصر
    إنه على ذلك قدير
    majdy82
    اشكر اخواني الذين شاركوني في سؤال هذا و اتمنى ان يوضحوا لنا ما يلي : مثلا هلا و غلااذا كان معامل الامرار الجانبيي 0.33 عند تدفق هواء يساوي 4000 cfm
    فماذا تعني هذه القيمة و كيف يمكن الاستفادة منها تصميميا..........
    adiiy_1234
    adiiy_1234 غير متواجد حالياً
    يا اخي مجدي معامل الامرار الجانبي هي قيمة تدخل في المعادلات الحسابية المتعلقة بحسابات احمال اجهزة التكييف والتبريد(لملفات التبريد).وهي قيمه تعطى من قبل الشركات المصممة ولا يمكن ان نعرف قيمتها .ويجب ان تذكر في المعطيات الحسابية .اما من الناحية العملية فانت لن تحتاجها
    رعسشم
    رعسشم غير متواجد حالياً
    شكر على الكلام الجميل دة
    ممكن بردة تنظر فى كتاب كاريير v1 صفحة 121
    هادي العاني
    هادي العاني غير متواجد حالياً
    معامل الامرار الجانبي هو يعطي نسبة الهواء غير المبرد فاذا كان معامل الامرار الجانبي يساوي 0.33 فيمكن حساب درجة حرار الهواء الخارج من ملف التبريد و كما يلي
    درجة حرارة الهواء الخارج من الملف = (1- 0.33)×درجة حرارة ملف التبريد+0.33×درجة حرارة الهواء قبل ملف التبريد
    هادي العاني
    اما بالنسبة لمعدل تدفق الهواء فلا يعني شيئا بالنسبة لمعامل الامرار الجانبي و يدخل ضمن النسبة اي اذا ضربت المعادلة اعلا بقيمة معدل تدفق الهواء فستختصر من الطرفين
