كتب كثيرة لها علاقة بالهندسة الطبية و الصيدلية
صفحة 2 من 12 الأولىالأولى 1 23 4 5 6 ... الأخيرةالأخيرة
النتائج 11 إلى 20 من 111
    casaouis02
    casaouis02 غير متواجد حالياً
    الصورة الرمزية casaouis02
    Toxicology of industrial compounds
    By H. Thomas
    • Publisher: CRC
    • Number Of Pages: 448
    • Publication Date: 1995-12-01
    • ISBN-10 / ASIN: 074840239X
    • ISBN-13 / EAN: 9780748402397
    • Binding: Library Binding
    A large number of chemical compunds are constantly being introduced and produced, both to assist and ease modern human life. Among these chemicals, industrial compounds represent a particular fraction of chemicals which are not intended for use in biological systems, but to which humans may be accidently exposed, whether in the workplace, by product application, or via the environment. Industrial chemicals, as opposed to pharmaceuticals and agrochemicals, are in many cases subjected only to a very basic examination of handling safety, and may lack further toxicity testing. This implies that essentially nothing is known about their bioavailability, metabolism, excretion and toxicological properties, unless problems arise.; Covering the investigation of industrial chemicals, this book focuses on their individual structure, biological fate, potential toxicity to mammals and the molecular mechanisms possibly underlying their adverse effects by highlighting the use and significance of experimental toxicology. Special emphasis is placed on mechanistic aspects in the safety assessment of industrial compounds, in addition to current regulatory and legal considerations.
    DOWNLOAD LINK:
    http://rapidshare.com/files/148896263/074840239X.zip
    مشرف على قسم الصيانة الميكانيكية - مرحبا بكم -
    casaouis02
    Chemical Properties Handbook: Physical, Thermodynamics, Engironmental Transport, Safety & Health Related Properties for Organic & Inorganic Chemical
    • Publisher: McGraw-Hill Professional
    • Number Of Pages: 784
    • Publication Date: 1998-10-01
    • ISBN-10 / ASIN: 0070734011
    • ISBN-13 / EAN: 9780070734012
    • Binding: Hardcover
    Necessary data that's often hard to find or difficult to calculate, all in one place, in easy-access format. That's what this Handbook provides to scientific, engineering, and environmental professionals, and students, who seek information on how chemicals will behave at different temperatures and under different conditions. Covering both organic and inorganic substances, and providing both experimental values and estimated values based on methods developed by the author and other noted experts, this book can save countless hours of searching for the right source or performing complicated calculations. Useful for hundreds of on-the-job information requirements, this much-needed Handbook makes it easy to obtain critical values for temperature and pressure for design or operation of compressors and turbines; find heat capacity data for heat exchangers; accurately design and safely operate vaporizers and condensers with precise information on enthalpy of vaporization; size vaporizer/condenser storage vessels with density data; determine the heating and cooling requirements of reactors with values for the enthalpy of formation; determine chemical equilibria for reactions using Gibbs’ energy of formation; design and operate effective stripping operations for water pollutant removal using water solubility data and Henry’s Law Constant; find needed adsorption capacities of activated carbon for cleaning air of various pollutants; use soil sorption coefficient for agricultural applications; solve problems for fluid flow of gases and liquids using viscosity data; use thermal conductivity data for heat transfer applications; use lower and upper explosion limits in air, flock point and autoignition temperature for safety in designs and operations; use threshold limit value (ACGIH), permissible exposure limit (OSHA) and recommended exposure limit (NIOSH) to design facilities while safeguarding health; use thermal expansion coefficient data to design relief systems; and find thousands of other time-saving uses.
    DOWNLOAD LINK:
    http://rapidshare.com/files/8045931/Chemical.Properties.Handbook-0070734011.rar
    casaouis02
    Design of Experiments in Chemical Engineering: A Practical Guide
    • Publisher: Wiley-VCH
    • Number Of Pages: 620
    • Publication Date: 2005-01-04
    • ISBN-10 / ASIN: 3527311424
    • ISBN-13 / EAN: 9783527311422
    While existing books related to DOE are focused either on process or mixture factors or analyze specific tools from DOE science, this text is structured both horizontally and vertically, covering the three most common objectives of any experimental research:
    • screening designs
    • mathematical modeling, and
    • optimization
    Written in a simple and lively manner and backed by current chemical product studies from all around the world, the book elucidates basic concepts of statistical methods, experiment design and optimization techniques as applied to chemistry and chemical engineering. Throughout, the focus is on unifying the theory and methodology of optimization with well-known statistical and experimental methods.
    The author draws on his own experience in research and development, resulting in a work that will assist students, scientists and engineers in using the concepts covered here in seeking optimum conditions for a chemical system or process.
    With 441 tables, 250 diagrams, as well as 200 examples drawn from current chemical product studies, this is an invaluable and convenient source of information for all those involved in process optimization.
    DOWNLOAD LINK:
    http://rapidshare.com/files/115693900/_2__DESIGN_OF_EXPERIMENTS_IN_CHEMICAL_ENGINEERING. pdf
    casaouis02
    Handbook of Chemical Reactor Design, Optimization, and Scaleup
    • Number Of Pages: 600
    • Publication Date: 2001-09-26
    • ISBN-10 / ASIN: 0071377530
    • ISBN-13 / EAN: 9780071377539
    Black, gold foil-enhanced frame holds an 8 1/2 x 11 certificate. Built-in hook and easel allows wall or desktop display. Features black book bound edges and a clear acetate window to protect the award. Includes one sheet of 24 lb. ivory parchment paper.
    DOWNLOAD LINK:
    http://rapidshare.com/files/92260542/chredeopsc.rar
    casaouis02
    Modern Spectroscopy
    • Publisher: Wiley
    • Number Of Pages: 480
    • Publication Date: 2004-01-16
    • ISBN-10 / ASIN: 0470844167
    • ISBN-13 / EAN: 9780470844168
    • Binding: Paperback
    The latest edition of this highly acclaimed title introduces the reader to a wide range of spectroscopies, and includes both the background theory and applications to structure determination and chemical analysis. It covers rotational, vibrational, electronic, photoelectron and Auger spectroscopy, as well as EXAFs and the theory of lasers and laser spectroscopy.
    • A revised and updated edition of a successful, clearly written book
    • Includes the latest developments in modern laser techniques, such as cavity ring-down spectroscopy and femtosecond lasers
    • Provides numerous worked examples, calculations and questions at the end of chapters.
    DOWNLOAD LINK:
    http://rapidshare.com/files/12519645/Modern_Spectroscopy_0470844167.rar
    casaouis02
    Lange's Handbook of Chemistry
    • Number Of Pages: 1424
    • Publication Date: 1998-10-30
    • ISBN-10 / ASIN: 0070163847
    • ISBN-13 / EAN: 9780070163843
    Revered as the standard reference for chemists for more than 60 years, this new edition of Lange's brings chemistry professionals, students, and anyone interested in science an enormous compilation of facts, data, tabular material, and experimental findings in every area of chemistry. Included in this massive compendium are listings of the properties of approximately 4,000 organic and 1,400 inorganic compounds. The 15th Edition includes new material on separation methods and analytical chemistry; statistical methods; polymers; rubbers, fats, oils, and waxes; new inorganic compounds; IUPAC nomenclature of organic compounds; updated lists of physical and chemical symbols; definitions and abbreviations; new tables, charts, and illustrations; with SI units used throughout (conversion tables supplied). The American Technical Technologists' Events magaine said of the last edition of this book, "Bargains are rare in the publication arena but this book represents one ... it is just overflowing with useful information that is available at your beck and call."
    DOWNLOAD LINK:
    http://rapidshare.com/files/99907217/lange_s.handbook.of.chemistry.rar
    casaouis02
    Synthetic Nitrogen Products: A Practical Guide to the Products and Processes
    • Publisher: Springer
    • Number Of Pages: 388
    • Publication Date: 2004-05-19
    • ISBN-10 / ASIN: 0306482258
    • ISBN-13 / EAN: 9780306482250
    This book provides a comprehensive description of 1) products that are made from or that contain nitrogen, 2) the processes that produce these products and 3) the markets that consume these products. The goal has been to present an abundance of information in one book so that the reader will find the maximum amount of useful information in one place.
    The first four chapters provide basic information about nitrogen and nitrogen products and processes. Chapters 5 through 20 provide detailed descriptions of various nitrogen or nitrogen-containing products. The material is presented in a standardized format that should make this book easy to use and helpful to all readers. A wide variety of readers in countries around the world should find the book useful - from students to professors, to technical professionals to business marketing personnel.
    DOWNLOAD LINK:
    http://rapidshare.com/files/103379019/synnitpro.rar
    casaouis02
    Thermal Analysis of Pharmaceuticals
    • Publisher: CRC
    • Number Of Pages: 416
    • Publication Date: 2006-12-21
    • ISBN-10 / ASIN: 0824758145
    • ISBN-13 / EAN: 9780824758141
    As a result of the Process Analytical Technologies (PAT) initiative launched by the U.S. Food and Drug Administration (FDA), analytical development is receiving more attention within the pharmaceutical industry. Illustrating the importance of analytical methodologies, Thermal Analysis of Pharmaceuticals presents reliable and versatile characterization tools for the successful development of pharmaceutical products. It draws attention to the most widely applicable methods and demonstrates how to interpret the associated data.
    The book opens with the first three chapters devoted to differential scanning calorimetry (DSC), the most commonly used thermal method. These chapters cover the principles, optimal use, and pharmaceutical applications of the method. Subsequent chapters explore modulated temperature DSC, thermogravimetric analysis, thermal microscopy, microcalorimetry, high sensitivity DSC, dynamic mechanical analysis, and thermally stimulated current, all of which have attracted great interest within the pharmaceutical field. The chapters include theoretical background, measurement optimization, and pharmaceutical applications of each technique.
    Exploring important techniques for characterizing the physical structure and properties of pharmaceutical materials, Thermal Analysis of Pharmaceuticals achieves an ideal balance in the depth, relevance, and accessibility of topics presented. The book provides an excellent overview of this key area in pharmaceutical development.
    DOWNLOAD LINK:
    http://rapidshare.com/files/139900103/Thermana_pharma.zip
    casaouis02
    Asymmetric Phase Transfer Catalysis
    • Number Of Pages: 228
    • Publication Date: 2008-04-18
    • ISBN-10 / ASIN: 3527318429
    • ISBN-13 / EAN: 9783527318421
    Edited by the leading expert on the topic, this is the first book to present the latest developments in this exciting field. Alongside the theoretical aspects, the top contributors provide practical protocols to give readers additional important information otherwise unavailable.
    A must for every synthetic chemist in academia and industry.
    DOWNLOAD LINK:
    http://rapidshare.com/files/140421356/apasdlfadwd3527318429.rar
    casaouis02
    Introduction to Mass Spectrometry
    Publisher: Wiley
    Number Of Pages: 862
    Publication Date: 2007-12-04
    ISBN-10 / ASIN: 0470516348
    ISBN-13 / EAN: 9780470516348
    Binding: Hardcover
    Completely revised and updated, this text provides an easy-to-read guide to the concept of mass spectrometry and demonstrates its potential and limitations. Written by internationally recognised experts and utilising "real life" examples of analyses and applications, the book presents real cases of qualitative and quantitative applications of mass spectrometry. Unlike other mass spectrometry texts, this comprehensive reference provides systematic descriptions of the various types of mass analysers and ionisation, along with corresponding strategies for interpretation of data. The book concludes with a comprehensive 3000 references.
    This multi-disciplined text covers the fundamentals as well as recent advance in this topic, providing need-to-know information for researchers in many disciplines including pharmaceutical, environmental and biomedical analysis who are utilizing mass spectrometry.
    DOWNLOAD LINK:
    http://rapidshare.com/files/145248100/introduction_mass_spectrometry_instrumenattion_4th .rar
