الأرضـــــــــــــــــــى والأرض والتأريــــض
صفحة 18 من 32 الأولىالأولى ... 814 15 16 17 1819 20 21 22 28 ... الأخيرةالأخيرة
النتائج 171 إلى 180 من 312
  1. [171]
    صلاح محمد سلام
    صلاح محمد سلام غير متواجد حالياً
    Kingshehab
    سيدى الفاضل/المهندس شهاب ابراهيم -ماذكره المهندس محمد عبدالرحمن ليس له علاقه بتاتا بسؤالى واكرر السؤال مره اخرى :
    الاخوه الافاضل مهندسى الكهرباء عندى سؤال اريد اجابتكم وتوجيهاتكم بالاجابه عليهوان كان ممكن ارسال اى رد على الايميل الخاص بى والمنتدى ايضا واكون شاكر لكم حسن تعاونكم
    :[ What are the difference between
    Neutral,Earthing,Grounding ndigo]
  2. [172]
    mzerighi
    mzerighi غير متواجد حالياً
    الاخ/صلاح محمد سلام أرجو أن يكون هذا جواب لسؤالك .
    Ground in a mains (AC power) electrical wiring system is a conductor that provides a low impedance path to the source to prevent hazardous voltages from appearing on equipment
    Normally a grounding conductor does not carry current.
    Earth is a conductor that provides a path to the earth. where the source is earthed so that it is provides a path between an equipment and the source to prevent hazardous voltages from appearing on equipment, same as ground..
    Normally grounding & earthing conductors does not carry current.
    Neutral "return" wire is a circuit conductor that may carry current in normal operation,
    Neutral wires are usually connected together at a neutral bus (bar) within panel boards or switchboards, and are "bonded" to ground or earth at either the electrical service entrance, or at transformers within the system. For electrical installations with three-wire single phase service, the neutral point of the system is at the center-tap on the secondary side of the service transformer. For larger electrical installations, such as those with polyphase service, the neutral point is usually at the common connection on the secondary side of delta/wye connected transformers. Other arrangements of polyphase transformers may result in no neutral point, and no neutral conductors.
    Different systems are used to minimize the voltage difference between neutral and local earth ground. In some systems, the neutral and earth join together at the service intake (TN-C-S); in others, they run completely separately back to the transformer neutral terminal (TN-S), and in others they are kept completely separate with the house earth having its own rod and the neutral being rodded down to earth within the distribution network (TT). In a few cases, they are combined in house wiring (TN-C), but the dangers of broken neutrals and the cost of the special cables needed to mitigate this mean that it is rarely done nowadays.
  3. [173]
    mzerighi
    الاستاذ محمد عبد الرحمن السلام عليكم
    انقطعت مشاركاتك القيمة عنا ، أدعو الله أن يكون المانع خير ، وألا يحرمنا من مشاركاتك المفيدة
    وأن نقراء تعليقاتك قريبا.
  4. [174]
    صلاح محمد سلام
    استاذى الفاضل اولا اشكرك على مجهودك العظيم الوافر فى الاجابة القيمة ولكن لم تشمل الاجابة مااريد انا الاستفسار عنه - حضرتك شرحت فقط ال(function )اى نظرية العمل او دور كل منهما
    same as ground اى لم تفرق بينهما ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
    ولكن سؤالى (what are the different) بمعنى اننا لازم ناخد بند او عامل واحد وليكن التيار او الجهد مثلا ونبحث تاثيره فى كل خاصيه على حدى ومن هنا يتضح لنا الفرق .
    [ Normally grounding & earthing conductors does not carry current ]
    هذه الاجابه لى تحفظ عليها وأسأل :واين مسار مركبة التيار الصفرية Zero seq. current =I
    وذلك فى حالة عدم اتزان الحمل او حالة التسرب الارضى او حاله العطل الملامس للارضى (earth fault)مثلا.
    والفرق بين ااتوصيلات المختلفه لتوصيله النجمه :
    1- ثلاثيه الاطراف المعزوله(3 اطراف )
    2- ثلاثيه الاطراف المؤرضه(3 اطراف ومؤرضة)
    3- رباعيه الاطراف المعزولة(3 اطراف والحيادى)
    4- رباعية الاطراف المؤرضة(3 اطراف والحيادى ومؤرضة)
    والسؤال الاخر ماهى نقطة التعادل (الحيادى) ومافائدتها لان اجابتك كانت تخص خط التعادل (الحيادى) فقط
    انا شاكر وسعيد للحوار البناء
    صلاح سلام salah_sllm @yahoo.com
  5. [175]
    mzerighi
    أخي الكريم : لقد اشرت إلى نقاط مهمة ،تفتح الباب لنقاش مثمر إن شأء الله ، لذا دعنا جميعا نناقش ما أشرت إليه وأرجو المشاركة من كل الاخوة الاعضاء .
    - في العادة خط ground و earth لا يحملان تيار، أما بالنسبة لمركبة التيار الصفري فهي تظهر عند حدوث حالة تسرب أرضي أو في حالة ملامسة الطور الحي للأرضي وهذه حالة غير عادية .
    - تحقيق الاتزان في حالة عدم الاتزان في أنظمة 3phase يكون من خلال الخط الرابع المتعادل N .
    - نظام 3phase 3wire L1.L2,L3 - IT EARTHING SYSTEM
    أي أن نقطة النجمة معزولة وهذا النظام يستخدم في المختبرات و غرفة العمليات وورش التصليح والصيانة . تحديد حيث يكون هناك احتمالية كبيرة لحدوث تلامس مع الخط الحي وفي هذه الحالة لن يمر تيار من خلال الارض لعدم وجود تأريض في المصدر.
    -3PHASE + PE L1,L2,L3 PE(EARTH WIRE) . هذا النظام يستخدم في الاحمال المتزنة أي تتغذى من الاطوار الثلاثة مثل المحركات الكهربائية.
    -3PHASE 4WIRE L1,L2,L3,N TT EARTHING SYSTM
    أي أن نقطة النجمة مؤرضة ويخرج منه خط المتعادل مع باقي الاطوار للأحمال التي تشتغل بجهد طور واحد .وهذا يستخدم لتقليل تكلفة إضافة كابل خاص بالارضي
    - 3PHASE 5WIRE L1,L2,L3,N & PE TN EARTHING SYSTEM
    أي أن نقطة النجمة مؤرضة ويخرج منها خط أرضي و خط متعادل لتغذية الاحمال التي تشتغل بجهد طور واحد .
    - نقطة التعادل أو نقطة النجمة STAR POINT هي نقطة إلتقاء ملفات المحول الثلاثة من جهة الثانوي في حالة توصيلة النجمة Y .
  6. [176]
    صلاح محمد سلام
    اخى الفاضل اشكرك على اهتمام البالغ والرد الذى كما اشرت فتحت باب كبير للنقاش لذى اطلب من الاخوه الزملاء صاحبى الخبره او المعلومه اعطائنا النصيحه والمشوره فى هذا الموضوع وانا شخصيا احاول احاوب او اعداد الرد او بعنى اخر احاول صياغه للرد
    ولكنى لازلت انتظر رد الاخوة الافاضل
    صلاح سلام
  7. [177]
    mfawzih
    mfawzih غير متواجد حالياً
    مشكور يا مهندس محمد علام
  8. [178]
    waled27`
    waled27` غير متواجد حالياً
    Thumbs up
    من waled27]
    كل عام وانتم بخير
  9. [179]
    WASEEMIRAQ10
    WASEEMIRAQ10 غير متواجد حالياً
    الصورة الرمزية WASEEMIRAQ10
    اقتباس المشاركة الأصلية كتبت بواسطة محمدعبدالرحمن علام مشاهدة المشاركة
    الإخوه الأعزاء
    أثير اليوم مفهوم الجهد و فرق الجهد
    مرفق ملف يحتوى على رسم لدائرة تغذية لمبه موصله على بطاريه وطرفها الآخر على الأرضـى earth .
    السـؤال :
    هل هذه اللمبه بهذا التوصيل ستضئ أم لا ؟
    رجاء التفكير جيدا من منطلق الجهد و فرق الجهد
    فى انتظـار ردودكم حتى يمكننى التواصل
    تحياتى
    اللمبة سوف تضيء لان احد اطراف اللمبة مربوط بالارضي والارضي يعتبر الخط السالب بشرط ان يكون الخط السالب للبطارية موصل بالارضي ...... وشكراً
  10. [180]
    صلاح محمد سلام
    الاخوه الافاضل اضاءه اللمبه او اى حمل مهما ان كان يعتمد على نظام الدائره ا لمغلقهclosed loop سواء باستخدام التاريض او غيره بمعنى ضروره توفير مسار للتيار (عفوا لايوجد مرفق)
