طالب مهم
النتائج 1 إلى 5 من 5
    بوووب
    بوووب غير متواجد حالياً
    طالب مهم
    لو سمحتم حد يقولي theory of operation of patient monitors
    من مواضيع بوووب :
    ابوريان44
    ابوريان44 غير متواجد حالياً
    الصورة الرمزية ابوريان44
    ياليت تفيدنا اخوي على العام هنا لو حصلت على المطلوب وكل عام وانت بخير
    ابوريان44
    Article InformationSystem theory in industrial patient monitoring: an overview
    Baura, G.D.
    Engineering in Medicine and Biology Society, 2004. IEMBS apos;04. 26th Annual International Conference of the IEEE
    Volume 2, Issue , 1-5 Sept. 2004 Page(s):5356 - 5359
    Digital Object Identifier 10.1109/IEMBS.2004.1404495
    Summary:Patient monitoring refers to the continuous observation of repeating events of physiologic function to guide therapy or to monitor the effectiveness of interventions, and is used primarily in the intensive care unit and operating room. Commonly processed signals are the electrocardiogram, intraarterial blood pressure, arterial saturation of oxygen, and cardiac output. To this day, the majority of physiologic waveform processing in patient monitors is conducted using heuristic curve fitting. However in the early 1990s, a few enterprising engineers and physicians began using system theory to improve their core processing. Applications included improvement of signal-to-noise ratio, either due to low signal levels or motion artifact, and improvement in feature detection. The goal of this mini-symposium is to review the early work in this emerging field, which has led to technologic breakthroughs. In this overview talk, the process of system theory algorithm research and development is discussed. Research for industrial monitors involves substantial data collection, with some data used for algorithm training and the remainder used for validation. Once the algorithms are validated, they are translated into detailed specifications. Development then translates these specifications into DSP code. The DSP code is verified and validated per the Good Manufacturing Practices mandated by FDA.
    ابوريان44
    اشترك معاهم هنا وشوف ممكن تحصل الفل ارتكل
    http://ieeexplore.ieee.org/Xplore/lo...number=1404495
    بوووب
    thanks for your effort
