موقد للطبخ يعمل بوقود الماء من تايوان
النتائج 21 إلى 28 من 28
  1. [21]
    مبتدىءلينوكس
    مبتدىءلينوكس غير متواجد حالياً
    الصورة الرمزية مبتدىءلينوكس
    Water Torch Machine
    SKU: BWT02
    This machine generates a clean pin point flame with temperatures between 1800~5000F from pen size torch. Machine is ideal for polishing and soldering. It also eliminates the danger and cost of using gas to generate flames. The Oxy-hydrogen Flame Generator analyzes distilled water into hydrogen and oxygen by using electricity.
    Applications:
    1. Acrylic Industry: Quick and fine polishing for acrylic edge, solving problems that puffer cannot achieve.
    2. Jewery Industry: Soldering chains and strings made by platinum, gold, copper, stainless.
    3. Electronic Industry: Soldering enameled wire, LED wafer.
    Specifications:
    Power:110V, 350W.
    Weight: 43LB
    Gas flow: 75~80 L/H
    Accessories:
    1. 2 boxes backfire-proof torches, each box contains 4 copper nozzles, 1 pinhead nozzle, shelf, and an additional big nozzle.
    2. Rubber hose.
    3. Plastic funnel.
    4. 2 bottles electrolyte p
    http://de.youtube.com/watch?v=kFIXrB...g-Tools/Detail
    اسم الرابط Water torch
  2. [22]
    مبتدىءلينوكس
    Place of origin: Malaysia
    Hydrogen Fuelsaver (Oxy Hydrogen Generator for Cars
    Features Specifications: Hydrogen Fuelsaver (Oxy Hydrogen Generator for Cars, Vehicles)
    The Hydrogen Fuelsaver OxyHydrogen Generator is a simple yet extremely brilliant instrument.
    Thedevice separates water to its two constituents - Hydrogen andOxygen andinjecting it into the air intake of an engine whichultimately helps(supplements) in the combustion process of fuelburning.
    Increase your fuel mileage by up to 30%
    Forget those ludicrous claims of super fuel saving additives or devices that are often unproven.
    TheHydrogen Fuelsaver OxyHydro Generator will help you save up to 30% onyour fuel costs.The device has been tested on many vehicles and we havean average of30% increase in mileage. It is extremely efficient as muchresearch anddevelopment has gone into the product.
    Increase the power of your engine
    SinceHydrogen gas is an almost perfect energy carrier, it burnsfar cleanerthan any other fuel around. This not only increases theamount of energyoutput in your vehicle but also helps clean the carbonbuild up in yourengine meaning that your engine will run smoother.(Hydrogen does notcreate any carbon when burnt).
    Reduce your green house gas emissions
    Bysupplementing your vehicle's fuel with OxyHydrogen, your vehiclewillproduce less green-house gases and less overall deadly emissionsintothe atmosphere. This is because the OxyHydrogen replaces some ofthefuels that will be burnt by your engine therefore decreasing theamountof harmful emissions released into the atmosphere
    ob Price: US$ 400~450 Port Klang
    Malaysia
    Model No: HFS200x
    Fob Price: US$ 1250~1400 Port Klang
    Port: Port Klang
    Payment Terms: L/C,T/T
    Minimum Order Quantity: 1 Set/Sets
    Supply Ability: 2000 Set/Sets per Month
    Package: Box packed with polystyrene filler
    Delivery Time: Depends on Quantity
    Brand Name: Hydrogen Fuelsaver
  3. [23]
    مبتدىءلينوكس
    Made-in-China.com
    Hydrogen Generator (YFRH Series)
    Product Description
    Our hydrogen generator adopts three kinds of working theory: Pure water electrolysis technology/min 99.9995%, KOH electrolyte technology/min 99.999%, palladium tube penetration technology/ min. 99.9999%; Pressure ranges from 0-0.4 to 0.6Mpa, outflow speed ranges from 100ml/min. To 10, 000ml/min;
    They can be used to supply hydrogen gas for any model GC system as carrier gas or fuel gas.
    For details, pls. Visit our website or contact us directly, any of your inquiry is welcomed.
  4. [24]
    مبتدىءلينوكس
    Made-in-China.com
    Hydrogen Oxygen Generator (HO5000)
    Product Description
    Technology Theory
    Oxy-hydrogen machine is a high-tech product in the world. It adopts water electrolysis technology to decompose hydrogen and oxygen from water under electricity, this machine uses hydrogen as the fuel and oxygen as the combustion-supporting gas in polishing, brazing, cutting, welding, furnaces; Oxy-hydrogen machine is a very promising and practical equipment, friendly to environment in the meantime.
    Multi-purposes
    This machine might turn water into flame which is like that produced by oxy-acetylene, oxy-propane and oxy-LPG and can do same work like cutting carbon iron, metal welding, processing headgears, jewelries, gold, platinum, silver, glassware.
    Safe energy
    Oxy-hydrogen is a very safe fuel, no poison, no harming smell to human body. Hydrogen has the smallest density among all gases, once leaking it will escape to the air quickly and not as dangerous as LPG, acetylene etc.
    Easily procured energy sources
    Oxy-hydrogen fuel is easily procured as we can find water and electricity easily. It can save much energy other than using acetylene, propane, LPG, etc., for example, each cubic oxy-hydrogen gas consumes 0.5 liter water and 3.5 KW electricity which is cheaper cost than using acetylene.
    Working features compared with tradtional oxy-fuels
    As oxy-hydrogen flame body is slimmer than other flame bodies, it has advantages like narrower slit, focused firepower, little heat affection area, high heat value, faster preheating, better cutting quality. The following is the workpiece cut by it:
    When welding, the welding surface is glossy, if filling a little gasoline or alcohol, the welding piece will be oxidation resistant.Model: HO5000
  5. [25]
    مبتدىءلينوكس
    Oxy-Hydrogen Machine (SPEHO)
    Product Description
    This instrument can generate oxygen and hydrogen gas in the meantime with pure water. The purity of oxygen is min. 99%, that of hydrogen is 99.997%-99.9995%. This instrument is a plug and play type, oxygen and hydrogen can be stored in tank for future use.Model: SPEHO
  6. [26]
    مبتدىءلينوكس
    Oxy-Hydrogen Generator (HO3000)
    Product Description
    Technology Theory
    Multi-purposes
    Safe energy
    When welding, the welding surface is glossy, if filling a little gasoline or alcohol, the welding piece will be oxidation resistant.Model: HO3000
  7. [27]
    hussien95
    hussien95 غير متواجد حالياً
    الصورة الرمزية hussien95
    Received: 24
    Given: 3
    موضوع رائع
  8. [28]
    masallam1
    masallam1 غير متواجد حالياً
    رائع
    الموضوع مثير للاهتمام لفوائده العظيمة
