Free Motor
النتائج 1 إلى 2 من 2
    الصورة الرمزية alsaneyousef
    alsaneyousef
    alsaneyousef غير متواجد حالياً
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    Gravity Wheel
    http://carsnology.blogspot.com/2008/11/gravity-wheel.html
    The BuzzSaw gravity wheel has two duel rim wheels supported on an axle. There is an inner
    wheel and outer wheel, the inner having 16 gullets and the outer having 8. The inner red
    wheel is attached to and drives the axle. The outer wheel has 4 black spokes on the back
    and rotates freely on bearings on the axle. When in motion, the weights would freely fall from
    one wheel to the other.
    The outer wheel has a cover that can be removed with screws to insert / remove weights.
    The original wheel had 12 weights but it is uncertain if all were used or not. The original
    wheel had a custom 42 tooth sprocket attached for a #60 chain.
