port number
النتائج 1 إلى 8 من 8
    mai hussein
    mai hussein غير متواجد حالياً
    port number
    How can I know the port number of a specific web service??
    Iknow that each web service has aspecific port number which is well known
    but I want to know what is the tool by which I can get it.
    thanks alot
    laith1
    laith1 غير متواجد حالياً
    Hello ebuddy
    I think you want to knowing about port service such as MSN , Yahoo massenger , Gmail ,POP3 , IMAP.. etc right , if so you can determined it in multi ways like from ISA server object by chose also you can by follow simple way from web site search just print Port for specific web site (nominated it " that's all ... also I would like inform you if you want to use these ports in control & monitors fileds take in your considration some of it change from time to time
    Some of specific service port
    POP3 = 110
    MSN Messenger = 1863 TCP
    IMAP4 = 143
    ماروكوفائزة
    ماروكوفائزة غير متواجد حالياً
    I don't understand your question, because we haven't number port specific service web.
    But if you want to detect open TCP and UDP ports on a target computer, determine which services are running on those ports, and run queries such as whois, ping, ICMP traceroute, you can use SUPER SCAN
    Superscan is a free connect-based port scanning software
    ماروكوفائزة
    I can give you a lot of applications witch allow you to know the open port but i dont khow how i can download for you from this site
    أبوبتال
    أبوبتال غير متواجد حالياً
    so from you comments guys, we can say if we have switches with many ports ( lets say some of them ON and others OFF) each one has its own IP address
    so WHAT is the proper command and MODE that can provide the IP address of these PORTS with brief information
    I really appreicate your help guys since I m working on cisco switches and I m facing this problem currently
    Hasan
    laith1
    Salam alikum all
    dears as i said in previous submitting replays there was many tools for knowing ports for website (http , https , ftp , SSH , Rlogin ... etc ) , also if you opened some a spesfic websites from your own PC or laptop such as yahoo massenger & Google website and you want to knowing all ports which used to established these connections from both side ( your PC side and website response ports ) so just open the prompt command and write netstat command to knowing it that's all
    C:\>netstat -n
    Active Connections
    Proto Local Address Foreign Address State
    TCP 127.0.0.1:2339 127.0.0.1:2340 ESTABLISHED
    TCP 127.0.0.1:2340 127.0.0.1:2339 ESTABLISHED
    TCP 192.168.0.225:2455 68.180.217.30:5050 ESTABLISHED
    TCP 192.168.xx.xx:2473 68.142.233.140:443 ESTABLISHED
    C:\>
    so in highlight read color explain both ports fro your PC & website response port
    Hope all these info get you what's you want
    darbi84
    darbi84 غير متواجد حالياً
    hi all i wana help me for how can find port number in my pc plz help me i
    ahmad mohmmad
    ahmad mohmmad غير متواجد حالياً
    الصورة الرمزية ahmad mohmmad
    Received: 10
    السلام عليكم...
    البورت نمبر في الاجهزة حسب الابليكيشن او البرامج التي تعملي عليها مثلا برامج الاف تي بي بورت 23 يستخدم وهكذا ولكيفيه معرفه البورت عن طريق الفيروووول ..
