برنامج EPLAN Fluid 1.8.4
النتائج 1 إلى 2 من 2
    الصورة الرمزية ماجد جلميران
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    EPLAN Fluid supports fluid engineering with automated documentation. Simple handling, numerous test functions, and standard support make your design efficient – from now on the system assumes time-consuming standard tasks.
    Compared with conventional, mostly CAD-based systems EPLAN Fluid comes with unique logic functions and automatisms that accelerate your fluid planning. The modern user interface with extensive drawing functions helps you familiarize yourself with its full potential – of course with the complete data stock from the predecessor system fluidPLAN. The autoconnect function applies to all connections that can be provided andanalyzed with logical properties. This means you have an overview of all components, including the small parts like connectors, hoses, and pipes – and therefore a firm grip on the costs!
    The new Engineering platform is your key to the future, providing core functions for fluid, electrical, measuring, and control engineering as well as CAE for electrical systems. Based on a unified platform all systems are suppliedfrom the same database. From now on multiple data entries and inconsistencies are history.
    Besides a unified database the platform also includes basic functions like thegraphical editor (for circuit diagrams, fluid plans, process control group plans), a unified rights management, the viewer, online/offline foreign language transla-tions, and the comprehensive audit system. The unique framework concept deliversimpressively fast results – not least of all owing to the unified look & feel throughout all applications.
    http://rapidshare.com/files/13386425....8.part1_2.zip
    http://rapidshare.com/files/13386429....8.part3_4.zip
    http://rapidshare.com/files/13386071...d1.8.part5.zip
    kimo_karam
    kimo_karam غير متواجد حالياً
    thanksssssssssssssssssssssssssssssssss
