ثلاث اسطوانات تعليم البرنامج الشهير solid work
النتائج 1 إلى 10 من 24
    الصورة الرمزية ahmed taye3
    ahmed taye3
    ahmed taye3 غير متواجد حالياً
    مرحباً بكم فى
    Solidworks Video Tutorial Volume 1 To Volume 3 | 1.6 GB
    This video tutorial covers SolidWorks 2007, and is also applicable to some earlier versions. With its comprehensive, step-by-step approach, this hands-on tutorial will help you master the techniques you need to quickly become productive in SolidWorks. Created by SolidWorks experts, the video tutorials contain real-world insight and will enable you to draw, design, edit, view and plot in SolidWorks. You will find all of the essential material necessary to successfully create any 2-dimensional (2D) as well as 3-dimensional solid models applicable to any design, architecture, or service industry.
    VIDEO COURSE *******
    01 Basic
    02 Interface 43 Overview
    03 Tangent Arc 44 Optimizing The Part
    04 More on Extrusion eDrawings
    05 Sample Hole 45 Overview
    06 Complex Extruded Cut 46 Interface
    07 Hole Wizard 47 Measure Tool
    08 Shell 48 Manipulate Components
    09 Section View 49 Section Tool
    10 Constant Radius Fillet 50 Mass/Texture
    11 Variable Radius Fillet 51 Markup Tool
    12 Face Fillet 52 STL Files
    13 Full Round Fillet Sheet Metal
    14 FilletXpert 53 Bend Allowance
    15 Chamfer 54 Applying K-Factor
    16 Revolved Feature 55 Bend Allowance/Deduction
    17 Revolved Cut 56 Bend Table
    18 Mirror Feature 57 Gauge Table
    19 Apply Color 58 Creating Base Flange
    20 Apply Texture 59 Edge Flange
    21 Apply Material 60 Trim Side Bends & Offset
    22 Linear Pattern 61 Auto Relief
    23 Circular Pattern 62 Custom Relief
    24 Draft (Neutral Plane) 63 Miter Flange
    25 Draft (Parting Line) 64 Hem Tool
    26 Draft (Parting Line with Step) 65 Sketched Bend
    27 DraftXpert 66 Closed Corner
    28 Rib 67 Jog
    29 2D Fillet 68 Break Corner/Corner Trim
    30 Mirror Sketching 69 Break Flat Pattern
    31 Dynamic Mirror Sketching 70 Tab
    32 Trim Entithes 71 Lofted Bend
    33 Offset 72 Extruded Cut
    34 Selected Contours 73 Simple Hole
    35 Sketch Picture 74 Unfold & Fold
    36 Assemble 75 Flattened State
    37 First 2D Drawing 76 The Design Library
    38 Projection View 77 Creating a Library Feature
    39 Section View 78 Creating a Forming Tool
    40 Dimensions 79 Using a Forming Tool
    41 Sample 3Dsketch 80 Forming Tool Comand
    42 3D Sketch Plane 81 Insert Bends
    82 Vent
    83 Fill Pattern
    Volume 2 - SURFACE DESIGN
    Running Time: 4 hours 41min
    01 Curvature Options 32 Funnel Body
    02 Zebra Stripes 33 Extrude Surface (Handle)
    03 Geometric Continuity 34 Support Sketch (Handle)
    04 Extruded Surface 35 Lofted Surface (Handle)
    05 Surface Trim 36 Adjusting Handle
    06 Boundary Surface Project (Pocket Game)
    07 Fillet 37 Circuit Board
    08 Project Curve 38 Housing (Solid Body)
    09 Thicken 39 Surface (Top Housing)
    10 Half Pipe Connection 40 Surface (LCD Opening)
    11 Sketch Cross-Connection 41 Surface (Bottom Housing)
    12 Pipes Cross-Connection 42 Fillet (Housing)
    13 Filled Surface 43 Battery Cover
    14 Lofted Surface 44 Create Assembly
    15 Swept Surface 45 Creating Shell
    16 Swept Twist 46 Edit Battery Cover
    17 Swept (Follow Path) 47 Insert Assembly
    18 Planar Surface 48 Creating Buttons
    19 Face Curves 49 LCD Opening
    20 Intersection Curve 50 Top Housing (Details)
    21 Offset Surface 51 Dial Pad (Details)1
    22 Ruled Surface 52 Dial Pad (Details)2
    23 Insert Pictures 53 Dial Pad (Add Fillets)
    24 Creating Bottom Surface 54 Buttons Openings
    25 Revolved Surface 55 Battery
    26 Middle Surface Bodies 56 Add Ribs Top Housing
    27 Solid Body 57 Add Ribs Bottom Housing
    28 Bathroom Sink 58 Add Bosses (Buttom)
    29 Filled Surface 59 Holes (PC Board)
    30 Base & Drain Pipe 60 Add Bosses (Top)
    31 Funnel (Creating sketch) 61 LCD Openings (Details)
    Volume 3 - WELDMENTS & MOLD DESIGN
    Running Time: 1 hour 25min
    01 Structural Member
    02 End Caps
    03 Gusset
    04 Filled Bead
    05 Trim-Extend
    06 Insert Part
    07 Custom Profile
    08 Sub-Weldment
    09 Move-Copy
    10 Extruded Cut
    11 Configurations
    12 Project (3d Sketch)
    13 Project 2
    14 Cut List (Drawings)
    Mold Design
    15 Move Face
    16 Scale
    17 Parting Line
    18 Straddle Faces
    19 Undercut Detection
    20 Parting Line II
    21 Shut off Surfaces
    22 Parting Surface
    23 Tooling Split
    24 Core
    25 Mold Assembly
    26 MoldflowXpress
    Vol.1
    http://www.filefactory.com/file/354e11/
    http://www.filefactory.com/file/f21913/
    http://www.filefactory.com/file/55525e/
    http://www.filefactory.com/file/7d39a7/
    http://www.filefactory.com/file/cec959/
    http://www.filefactory.com/file/4ec943/
    Vol.2
    http://www.filefactory.com/file/10ba26/
    http://www.filefactory.com/file/5c6534/
    http://www.filefactory.com/file/d6dbb9/
    http://www.filefactory.com/file/b8f28d/
    http://www.filefactory.com/file/0f61e8/
    http://www.filefactory.com/file/6f7a91/
    http://www.filefactory.com/file/edfd81/
    http://www.filefactory.com/file/587028/
    http://www.filefactory.com/file/5ba521/
    Vol.3
    http://www.filefactory.com/file/07f0d9/
    http://www.filefactory.com/file/3ccbff/
    1.6 GB
    هذا وبالله التوفيق والحمد لله رب العالمين
    لاتنسونا من صالح دعائكم
    مهندس وعد
    مهندس وعد غير متواجد حالياً
    الصورة الرمزية مهندس وعد
    ممنون وبارك الله بيك. جاري التحميل . اسطوانات رائعه
    الزيدون
    الزيدون غير متواجد حالياً
    اشكر الاخ على هدا الموضوع
    نرجو اعادة تحميل الجزء الرابع من الاسطوانة الثانية لانه لم يعد موجودا على السرفر
    شكرا
    ENG-COOL
    ENG-COOL غير متواجد حالياً
    ممنون وبارك الله بيك.,ياريت تحملهم علي الرابيد شير لان هذا الموقع يعطيني ان الملف غير موجود علي السيرفر وهذا الموقع معقد ولم أعرف الأشتراك فيه و مششششششششششششششكو ر مرة أخري
    الزيدون
    هاهي الروابط كاملة على رابيدشار
    http://rapidshare.com/files/58281580...sar.part01.rar
    http://rapidshare.com/files/58281503...sar.part02.rar
    http://rapidshare.com/files/58281545...sar.part03.rar
    http://rapidshare.com/files/58281739...sar.part04.rar
    http://rapidshare.com/files/58281511...sar.part05.rar
    http://rapidshare.com/files/58281519...sar.part06.rar
    http://rapidshare.com/files/58281577...sar.part07.rar
    http://rapidshare.com/files/58281628...sar.part08.rar
    http://rapidshare.com/files/58281619...sar.part09.rar
    http://rapidshare.com/files/58276736...sar.part10.rar
    http://rapidshare.com/files/58274022...l_1_quasar.sfv
    http://rapidshare.com/files/58281534...sar.part01.rar
    http://rapidshare.com/files/58281372...sar.part02.rar
    http://rapidshare.com/files/58281544...sar.part03.rar
    http://rapidshare.com/files/58281841...sar.part04.rar
    http://rapidshare.com/files/58281692...sar.part05.rar
    http://rapidshare.com/files/58281543...sar.part06.rar
    http://rapidshare.com/files/58281844...sar.part07.rar
    http://rapidshare.com/files/58281696...sar.part08.rar
    http://rapidshare.com/files/58281499...sar.part09.rar
    http://rapidshare.com/files/58281647...sar.part10.rar
    http://rapidshare.com/files/58281392...sar.part11.rar
    http://rapidshare.com/files/58281560...sar.part12.rar
    http://rapidshare.com/files/58281454...sar.part13.rar
    http://rapidshare.com/files/58277367...sar.part14.rar
    http://rapidshare.com/files/58274034...l_2_quasar.sfv
    http://rapidshare.com/files/58281268...asar.part1.rar
    http://rapidshare.com/files/58281504...asar.part2.rar
    http://rapidshare.com/files/58281541...asar.part3.rar
    http://rapidshare.com/files/58275255...asar.part4.rar
    http://rapidshare.com/files/58274037...l_3_quasar.sfv
    احمد عبدالله سليم
    احمد عبدالله سليم غير متواجد حالياً
    نرجو اعادة تحميل الجزء الثاني من الاسطوانة الثالثة لانه لم يعد موجودا على السرفر............... وشكراً
    احمد عبدالله سليم
    وقت طويل لتنزيل الملفات واحد بواحد من الربيد شير ... فهل هناك طريقة أفضل
    عمران احمد
    عمران احمد غير متواجد حالياً
    Received: 40
    Given: 71
    بارك الله فيك و الى مزيد من النجاح
    امير المياحي
    امير المياحي غير متواجد حالياً
    مشكور يا اخي على الموضوع الرائع لكن اريد ان اعرف قبل ان احمل الاسطوانات فيما اذا كانت بالعربية ام بالانكليزية
    مع فائق تقديري
    عمران احمد
    Received: 40
    Given: 71
    جزاك الله كا خير و الى مزيد من التوفيق و لكن انا اريد ان اعرف بعد التحميل كيف يتم تشغيلهم
    نرجو الافادة و لك جزيل الشكر
