هنا نجيب على اسئلتكم واستفساراتكم وطلباتكم .. اهلا بكم
صفحة 188 من 303 الأولىالأولى ... 88138178184 185 186 187 188189 190 191 192 198238288 ... الأخيرةالأخيرة
النتائج 1,871 إلى 1,880 من 3024
  1. [1871]
    حامد الحمداوي
    حامد الحمداوي غير متواجد حالياً
    الصورة الرمزية حامد الحمداوي
    Given: 7
    اقتباس المشاركة الأصلية كتبت بواسطة أبوالمثنى مشاهدة المشاركة
    please I want to know about mechanical lifts
    A mechanical lift is also known as an elevator. It is a machine or a vehicle that transports either goods or people (or both) between floors of a building. The first historical elevator was found in the writings of the Greek writer Vitruvius, who mentioned a contraption built by Archimedes. Many of these early elevators were either powered by animals or by hand. In the mid 1800's a mechanical lift was invented that was powered by hydraulics.
    Mechanical lift products can assist with lifting, moving and transferring items and people. Large scale mechanical lifts are permanent fixtures within a building which allow movement of individuals or equipment through the push of a button, and eliminate the need for traverse stairs or ramps. There are a range of sizes to suit varying needs and are usually multi storey and built into a building at the time of construction.
    Mechanical lifts can be added to buildings post construction if required. For example, if, an individual becomes wheelchair bound following an accident, the mechanical lift can eliminate the person’s need to climb stairs to access upper floors of a building. Professional advice needs to be sought regarding the suitability of the building to be modified, local government approval requirements and compliance .
    Traction Mechanical Lifts
    Traction lifts are powered by motors. Geared traction lifts are powered by DC or AC motors. These motors use rolling steel hoists over a drive sheath that hoists the cables using a gearbox that it is attached by a high powered motor. Other lifts are powered by gearless motors. In this case, the drive sheath (the cable that is connected to the lift) is directly attached to the motor. In either case, the motor is attached to a plate on the top of the lift that is looped over to a counterweight that helps reduce the amount of power necessary to move the lift at a controlled rate
    http://www.jobaccess.gov.au/JOAC/Adv..._elevators.htm
  2. [1872]
    حامد الحمداوي
    Given: 7
    اقتباس المشاركة الأصلية كتبت بواسطة mnci مشاهدة المشاركة
    بالتوفيق لك وللجميع
    .........................0
    اخي وعزيزي mnci
    سعيد جدا بتواجدك هنا واتمنى ان اجدك معينا سيما وانك قادر على المزيد والافضل
    وتقبل مني ارق واحلى التحايا
  3. [1873]
    uofs
    uofs غير متواجد حالياً
    السلام عليكم ملتقى المهندسين العرب اريد بحث عن الضواغط الترددية احادية الفعل ولكم جزيل الشكر
  4. [1874]
    saleh_aledni
    saleh_aledni غير متواجد حالياً
    الرجاء الساعده من أهل الخبرة؟؟؟؟؟؟؟
    Dear sir.
    I' am looking for 4Rnner Toyota engine repair manual model 2000.
    Engine tape 5VZ-FE U.S.A specification, How can I get it? What will cost?
    Best regards
    السادة المهندسين الكرام.
    أملك سيارة تويوتا فورنر أوتوماتيك مواصفات أمريكية، يوجد فيها مشكلة التشك لايت "Check light" يظهر في التبلون الأمامي، بالرغم من أني أخذتها إلى أكثر من مهندس لكن دون جدوى.
    وهل يوجد هناك أي طريقه لفحص الحساس "SENSORS" ؟
    و هل من الممكن الحصول على الكتالوج الخاص بالسيارة إذا أمكن؟
    مع العلم أني أستخدم بترول سوبر و زيوت تويوتا أمريكي الصنع مع تبديل فلتر الزيت كل ثلاثين كيلوا متر "30كم" و المياه المستخدمة أنتي فريز وسعة قياس الحرارة تظهر الإشارة في المنتصف"طبيعي" و أيضاً "ATF" الهيدروليك تويوتا أمريكي.
    أرجوا المساعدة من أهل الخبرة، و سرعة الرد لأن هذه المشكلة تؤرقني.
  5. [1875]
    bodaboy
    bodaboy غير متواجد حالياً
    شكرا لكم لردكم على تساؤلى و قد استخرت الله _عز و جل_ وقررت بعد توفيق الله و كلامكم أن التحق بقسم الميكانيكا الذى أشعر وكأنه بحر واسع من العلم
  6. [1876]
    إستشاري المهندسين
    إستشاري المهندسين غير متواجد حالياً
    انا متخرج نهاية الترم القادم وعندي لكم سؤال هل الافضل ان اعمل في الشركات او التحق بالكلية الحربية واصير ملازم مهندس
    ومن لدية علم عن مرتب المهندس الميكانيكي المتخرج في شركة ارامكو السعودية يفيدنا براية
    جزاكم الله خير
  7. [1877]
    حياتي كهربه
    حياتي كهربه غير متواجد حالياً
    الصورة الرمزية حياتي كهربه
    وبعد......
    الرجاء افادتي بماتعلمونه عن الكهربه :انا طالب متخرج من الكفاءه المتوسطه ودخلت المعهد المهني قسم الكهرباء الأنشائيه ونا ما اعرف ايش يعني كهرباء انشائيه صحيح انا محب الكهرباء ولا كن ما اعرف ايش يعني لاكن في ناس نصحوني عنهااا وقالولي ادخلها ولا ادري ان تكون افضل لي ولمستقبلي او لا فرجاء افادتي بما تعلمونه.
    تحياااااااتي: حياتي كهربه
  8. [1878]
    sgmah1985
    sgmah1985 غير متواجد حالياً
    بسم الله
    صباح الخير يااخواني
    انا طالب هندسة ميكانيكة متدرب وواجهت مشكلة انهم ازالو بعض هي
    dead leg pipe
    they demolish some parts of the pipe because it was dead leg pipe
    please i want from the expert Eng to help me since i did not find as much as necessary information about it - i want to handle it as small case study
    regards for all
  9. [1879]
    a_basyouni
    a_basyouni غير متواجد حالياً
    i want a help about how to select a pupm and sand filter for a pool 57m cubic and has a compensation tank 5m cubic
  10. [1880]
    a_basyouni
    ما هي الفحوصات و الاجرائات التي يجب ان اتبعها عند استلام اجهزة ال duct split unit من المقاول
