What's the difference between ASTM standard c-136 and d-422 ?
النتائج 1 إلى 9 من 9
    amgad34
    amgad34 غير متواجد حالياً
    amgad34
    اين المهندسين؟؟؟؟؟؟؟؟
    حسان2
    حسان2 غير متواجد حالياً
    الصورة الرمزية حسان2
    Received: 206
    اقتباس المشاركة الأصلية كتبت بواسطة amgad34 مشاهدة المشاركة
    الأخ الكريم amgad34
    فيما يلي نسخة من ASTM STANDARD C-136 & d422
    وهما ملفين صغيريم من عنوانهما تستطيع أن تجد الفرق, واذا قرأت صفحاتهما القليلة ستجد مزيدا من التفاصيل
    Egab
    Egab غير متواجد حالياً
    منقول http://www.eng-tips.com/viewthread.c...=88276&page=15
    Mechanical)25 Feb 04 19:27
    I have found that some ASME codes specify materials such as ASTM A 105, whereas the material is listed as ASTM SA-105 in other codes. The ASTM SA-105 specification says it is identical to ASTM A 105.
    Is there any reason why the material is refered to as A105 and SA-105 if it is identical? Are most (or all) SA-XXX's identical to A-XXX's? Are there any differences?
    Rich2001 (Mechanical)25 Feb 04 20:36
    The SA version is the ASME code accepted version of the ASTM A specification. Once an ASTM standard is revised it must then be accepted by the ASME B&PV code committee. For this reason the ASME SA-XXXX lag behind the revisions to ASTM A-XXXX.
    In most cases they are identical, however if you want B&PV material specify the ASME SA-XXXX on your purchase order not ASTM A-XXXX.
    JoeTank (Structural)26 Feb 04 9:56
    I believe you are misreading the ASME Code. The Code specifies ASME SAxxx material, not ASTM SAxxx material.
    The reason ASME Code specifies ASME material designations (rather than ASTM material designations) is that each and every material must be accepted by the ASME Code Committee for Code construction. Eventhough most of the ASTM and ASME material specs are identical, there are many ASTM materials that are not acceptable for Code construction. Steve Braune
    Tank Industry Consultants
    www.tankindustry.com
    engabuomar
    engabuomar غير متواجد حالياً
    لا حول ولا قوة الا بالله
    انا ابحث عن astm c97!!!
    هل هو موجود في احد هذه الاقسام؟؟؟
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    ربنا يوفقك
    cocanouar
    cocanouar غير متواجد حالياً
    Astm c 805
    بسم الله الرحمان الرحيم
    انا ابحث عن astm c805!!
    جزاكم الله
    agwila
    agwila غير متواجد حالياً
    salam brother, please check the attached files
    engabuomar
    Thanks!!
    اقتباس المشاركة الأصلية كتبت بواسطة agwila مشاهدة المشاركة
    Dear Brother Agwila,
    Thanks so much for providing me the file!
