Bosch ESI[tronic] Training Course
صفحة 5 من 7 الأولىالأولى 1 2 3 4 56 7 الأخيرةالأخيرة
النتائج 41 إلى 50 من 66
  1. [41]
    أكرم إدريس
    أكرم إدريس غير متواجد حالياً
    الصورة الرمزية أكرم إدريس
    3.7 Mechanics &maintenance charts
    هذه الخاصية مهمة جدا كغيرها ، وهي تقوم بتوفير بيانات كاملة عن النظام الميكانيكي المستخدم في السيارة كما يتواجد بها جداول الصيانة لكافة القطع الموجودة وغيره الكثير هنا نورد بعض التفصيل عنه .....
    Mechanical option in navigation bar Contains a well-arranged and systematic display of the mechanics information such as, for example maintenance charts including resetting of service interval display, notes on changing toothed belts, wheel alignment data as well as notes on key programming, see (Figure 3-17).
    Vehicle identification: Number of cylinders, capacity of the engine, compression ratio, suitable for unleaded petrol (Yes/ No), minimum octane rating and diagnostic socket (Yes/No).
    - Service adjustments: Thermostat opens (Co), compression pressure (bar), oil pressure (bar/r.p.m), radiator cap (bar), idle speed (r.p.m), lambda at increased idle and levels of O2( %), CO2(%) and HC (ppm) at idle speed etc.
    - Ignition system: Ignition system type, ignition coil supply voltage (V), firing order, ignition timing-basic BTDC (oEngine/r.p.m), ignition advance checks (manual or automatic control).
    - Spark plugs: Type of spark plugs and electrode gap (mm).
    - Fuel system: description of fuel system, type of carburetor/injection system, type of air metering, combined ignition and fuel ECM (Yes/NO) and system pressure without vacuum (bar).
    - Air conditioning: Air conditioning refrigerant type (eg: R12), air conditioning
    refrigerant quantity (gm), type of air conditioning oil and air conditioning oil quantity (cm3).
    - Starting &charging: Battery type, alternator type and its maker, starter type and its maker and alternator output at engine speed (A/V/r.p.m).
    - Brake disk and drum dimensions: Minimum disc thickness (mm), disk thickness vibration (mm), disk runout (mm), minimum pad thickness (mm), minimum shoe thickness (mm) and hand brake travel (no. of notches).
  2. [42]
    أكرم إدريس
    الان سنقوم بطرح مثال على واحدة من الامكانيات المعلوماتية التي يوفرها البرنامج وهي زوايا العجلات وترصيصها .....
    Figure 3-20shows all iformation about wheel alignment that can be found under Mechanical option in navigation bar.
  3. [43]
    أكرم إدريس
    هكذا نكون وصلنا الى
    نهاية الجزء الاول من دورتنا
    الجزء الثاني سيكون عن التشخيص المباشر
    Vehicle diagnosis using
    KTS 5xx/650 devices
    ESI [tronic]
  4. [44]
    أكرم إدريس
    اشكر جميع الاخوة الذين شاركونا بهذه الدورة ... ولكل من استفاد منها ارجوا منكم الدعاء
    اخوتي اعتذر عن التاخير الذي حصل بوضع حلقات جديدة .... وذلك لوفاة حصلت لاحد الاخوة الاحبة في الاردن هنا ، وثم انشغالي الشديد بأمور القسم ... لكم مني خالص المحبة
    زميلكم واخوكم في الله
    م . اكرم ادريس الحمود
  5. [45]
    master_277
    master_277 غير متواجد حالياً
    الصورة الرمزية master_277
    Thumbs up
    مشكورين على المعلومات القيمة
    و هذى هديتى اليكم
    http://www.filefactory.com/file/9b1f...pm_part001_rar
    http://www.filefactory.com/file/61b2...pm_part002_rar
    http://www.filefactory.com/file/0314...pm_part003_rar
    http://www.filefactory.com/file/818d...pm_part004_rar
    http://www.filefactory.com/file/0fe5...pm_part005_rar
    http://www.filefactory.com/file/e0e8...pm_part006_rar
    http://www.filefactory.com/file/ec1f...pm_part007_rar
    http://www.filefactory.com/file/4a96...pm_part008_rar
    http://www.filefactory.com/file/475f...pm_part009_rar
    http://www.filefactory.com/file/524e...pm_part010_rar
    http://www.filefactory.com/file/67be...pm_part011_rar
    http://www.filefactory.com/file/8729...pm_part012_rar
    http://www.filefactory.com/file/a457...pm_part013_rar
    http://www.filefactory.com/file/f394...pm_part014_rar
    http://www.filefactory.com/file/b0d3...pm_part015_rar
    http://www.filefactory.com/file/7503...pm_part016_rar
    http://www.filefactory.com/file/ef95...pm_part017_rar
    http://www.filefactory.com/file/306b...pm_part018_rar
    http://www.filefactory.com/file/7778...pm_part019_rar
    http://www.filefactory.com/file/9857...pm_part020_rar
    http://www.filefactory.com/file/714a...pm_part021_rar
    http://www.filefactory.com/file/95d5...pm_part022_rar
    http://www.filefactory.com/file/7643...pm_part023_rar
    http://www.filefactory.com/file/9d95...pm_part024_rar
    http://www.filefactory.com/file/bece...pm_part025_rar
    http://www.filefactory.com/file/b5af...pm_part026_rar
    http://www.filefactory.com/file/d694...pm_part027_rar
    http://www.filefactory.com/file/2ed4...pm_part028_rar
    http://www.filefactory.com/file/96e0...pm_part029_rar
    http://www.filefactory.com/file/8b4e...pm_part030_rar
    http://www.filefactory.com/file/4401...pm_part031_rar
    http://www.filefactory.com/file/9d95...pm_part032_rar
    http://www.filefactory.com/file/356b...pm_part033_rar
    http://www.filefactory.com/file/39fc...pm_part034_rar
    http://www.filefactory.com/file/ef95...pm_part035_rar
    http://www.filefactory.com/file/1c7a...pm_part036_rar
    http://www.filefactory.com/file/0b3e...pm_part037_rar
    http://www.filefactory.com/file/154e...pm_part038_rar
    http://www.filefactory.com/file/871e...pm_part039_rar
    http://www.filefactory.com/file/9ebd...pm_part040_rar
    http://www.filefactory.com/file/a5a2...pm_part041_rar
    http://www.filefactory.com/file/cc11...pm_part042_rar
    http://www.filefactory.com/file/dac5...pm_part043_rar
    http://www.filefactory.com/file/b92b...pm_part044_rar
    http://www.filefactory.com/file/d4da...pm_part045_rar
    http://www.filefactory.com/file/8b9d...pm_part046_rar
    http://www.filefactory.com/file/b0d3...pm_part047_rar
    http://www.filefactory.com/file/0ec2...pm_part048_rar
    http://www.filefactory.com/file/9d95...pm_part049_rar
    http://www.filefactory.com/file/69a9...pm_part050_rar
    http://www.filefactory.com/file/9caf...pm_part051_rar
    http://www.filefactory.com/file/aeb4...pm_part052_rar
    http://www.filefactory.com/file/40fc...pm_part053_rar
    http://www.filefactory.com/file/3d6a...pm_part054_rar
    http://www.filefactory.com/file/cd16...pm_part055_rar
    http://www.filefactory.com/file/5170...pm_part056_rar
    http://www.filefactory.com/file/0314...pm_part057_rar
    http://www.filefactory.com/file/9ebd...pm_part058_rar
    http://www.filefactory.com/file/16fd...pm_part059_rar
    http://www.filefactory.com/file/6b7a...pm_part060_rar
    http://www.filefactory.com/file/6d83...pm_part061_rar
    http://www.filefactory.com/file/ecf3...pm_part062_rar
    http://www.filefactory.com/file/1c7a...pm_part063_rar
    http://www.filefactory.com/file/9407...pm_part064_rar
    http://www.filefactory.com/file/0b3e...pm_part065_rar
    http://www.filefactory.com/file/8392...pm_part066_rar
    http://www.filefactory.com/file/5000...pm_part067_rar
    http://www.filefactory.com/file/0e54...pm_part068_rar
    http://www.filefactory.com/file/0bd2...pm_part069_rar
    http://www.filefactory.com/file/6f75...pm_part070_rar
    http://www.filefactory.com/file/a457...pm_part071_rar
    http://www.filefactory.com/file/3b30...pm_part072_rar
    http://www.filefactory.com/file/35e1...pm_part073_rar
    http://www.filefactory.com/file/fed8...pm_part074_rar
    http://www.filefactory.com/file/8288...pm_part075_rar
    http://www.filefactory.com/file/9ebd...pm_part076_rar
    http://www.filefactory.com/file/bbd0...pm_part077_rar
    http://www.filefactory.com/file/fe3a...pm_part078_rar
    http://www.filefactory.com/file/1c68...pm_part079_rar
    http://www.filefactory.com/file/25f9...pm_part080_rar
    http://www.filefactory.com/file/c314...pm_part081_rar
    http://www.filefactory.com/file/5520...pm_part082_rar
    http://www.filefactory.com/file/d797...pm_part083_rar
    http://www.filefactory.com/file/8b4e...pm_part084_rar
    http://www.filefactory.com/file/46a3...pm_part085_rar
    http://www.filefactory.com/file/2ee9...pm_part086_rar
    http://www.filefactory.com/file/98ee...pm_part087_rar
    http://www.filefactory.com/file/77e1...pm_part088_rar
    http://www.filefactory.com/file/350f...pm_part089_rar
    http://www.filefactory.com/file/150f...pm_part090_rar
    http://www.filefactory.com/file/a5a2...pm_part091_rar
    http://www.filefactory.com/file/a80a...pm_part092_rar
    http://www.filefactory.com/file/7bfd...pm_part093_rar
    http://www.filefactory.com/file/8b4e...pm_part094_rar
    http://www.filefactory.com/file/da47...pm_part095_rar
    http://www.filefactory.com/file/0314...pm_part096_rar
    http://www.filefactory.com/file/11e7...pm_part097_rar
    http://www.filefactory.com/file/3c34...pm_part098_rar
    http://www.filefactory.com/file/c20e...pm_part099_rar
    http://www.filefactory.com/file/e9f0...pm_part100_rar
    http://www.filefactory.com/file/9b94...pm_part101_rar
    http://www.filefactory.com/file/e0e8...pm_part102_rar
    http://www.filefactory.com/file/dbec...pm_part103_rar
    http://www.filefactory.com/file/25e9...pm_part104_rar
    http://www.filefactory.com/file/0fe5...pm_part105_rar
    http://www.filefactory.com/file/39fc...pm_part106_rar
    http://www.filefactory.com/file/c4a3...pm_part107_rar
    http://www.filefactory.com/file/a5a2...pm_part108_rar
    http://www.filefactory.com/file/4228...pm_part109_rar
    http://www.filefactory.com/file/aa49...pm_part110_rar
    http://www.filefactory.com/file/7833...pm_part111_rar
    http://www.filefactory.com/file/a527...pm_part112_rar
    http://www.filefactory.com/file/356b...pm_part113_rar
    http://www.filefactory.com/file/029f...pm_part114_rar
    http://www.filefactory.com/file/7e05...pm_part115_rar
    http://www.filefactory.com/file/dbe5...pm_part116_rar
    http://www.filefactory.com/file/f596...pm_part117_rar
    http://www.filefactory.com/file/5fe9...pm_part118_rar
    http://www.filefactory.com/file/8b4e...pm_part119_rar
    http://www.filefactory.com/file/e5d0...pm_part120_rar
    ولا تنسونا من صالح دعائكم
  6. [46]
    altarrah82
    altarrah82 غير متواجد حالياً
    الصورة الرمزية altarrah82
    Given: 38
    مشكورررررر أخي جزاك الله خيرا بداية موفقة
  7. [47]
    ماهر طلبة
    ماهر طلبة غير متواجد حالياً
    مجهود رائع واسأل الله الكريم ان يجزى كل من ساهم فى نشر المعرفة والعلم
  8. [48]
    ميكانيكي ديزل
    ميكانيكي ديزل غير متواجد حالياً
    الصورة الرمزية ميكانيكي ديزل
    وفقك الله وشافى والدتك
    أخوك : حسام العمري
  9. [49]
    مراد اسماعيل
    مراد اسماعيل غير متواجد حالياً
    شكرا أخي جزاك الله خيرا
  10. [50]
    ماهر طلبة
    تم تحميل البرنامج كاملا وفى انتظار تجميعة فى مجلد واحد
    لكم جزيل الشكر
