ماذا تعرف عن الخرسانة المسلحة بالالياف الزجاجية
النتائج 11 إلى 20 من 33
    خالد قدورة
    خالد قدورة غير متواجد حالياً
    Received: 30
    موضوع شيق مشكور يا اخي
    رزق حجاوي غير متواجد حالياً
    الصورة الرمزية رزق حجاوي
    Received: 4,986
    Given: 1,442
    استكمالا لما سبق فان هناك تطبيقات كثيرة لمادة Fiberglass Reinforced Plastic =FRP
    وتمتاز هذه المادة بقدرتها العالية على مقاومة ةالتاكل وخصوصا في البيئة الصعبة Aggressive Enviroment مثل مصانع الكيماوية البيئة البحرية ، محطات التنقية ..... وفيما يلي شرح مبسط لهذه الاستخدامات :-
    Fibergrate Product Applications
    Fibergrate was originally developed in response to the harsh conditions of chemical facilities which require products that can withstand corrosive chemicals, high temperatures, constant washdowns and multiple impacts. Fibergrate products with their specially engineered resin systems can be used throughout a facility from mixing tank walkways; to loading platforms; to accessways, manholes and trenches
    . Commercial
    From hotels, to apartments, to downtown corporate courtyards, Fibergrate has solutions for your commercial facility. Whether you need an aesthetically pleasing sunscreen, rooftop walkway, fountain drainage or a slip-resistant stairway, Fibergrate can provide the perfect solution
    . Food and Beverage
    With a consistently wet environment and harsh cleaning products, the food and beverage industry needs unique solutions to their corrosion and slip hazard problems. Fibergrate products, in particular the Chemgrate® line of grating, are designed to meet FDA and USDA criteria and can be used throughout these facilities from mixing lines, to packaging, to docks
    . Manufacturing
    No matter the product in production, manufacturing plants worldwide deal with worker safety and lowering maintenance costs. Fibergrate’s products have been engineered to withstand severe conditions and can be used around mills and lathes, along assembly lines, on docks and in maintenance areas
    . Metals and Mining
    Fibergrate’s products are providing economical and safe solutions in the metals and mining industry. With its corrosion-resistant, slip-resistant and nonconductive properties, Fibergrate is used in recovery operations, processing, plating areas, conveyors and loading docks.
    Microelectronics
    Oil and Gas
    Designed to stand up to the harsh environmental conditions encountered in the oil and gas industry, Fibergrate products are the ideal solution for both offshore and land based production. Key features such as corrosion and slip resistance, flame retardancy, impact absorbency, nonconductivity, high strength-to-weight properties, and low maintenance make these products ideal for all types of oil and gas facilities.
    Pharmaceutical
    Fibergrate products are the perfect solution for the diversity of production methods found in the pharmaceutical world. The ergonomic features as well as corrosion and slip resistance, flame retardancy and low maintenance make Fibergrate the right fit for use in packaging, material storage, research and development, manufacturing and clean room applications.
    Power
    Engineered from fiberglass reinforced plastic, Fibergrate products provide the power industry with the solution for a variety of environmental conditions. Fibergrate is electromagnetically transparent, nonconductive and corrosion resistant. These properties make Fibergrate perfect for use around transmission structures, distribution equipment, in storage and containment areas as well as cooling towers and discharge areas
    . Pulp and Paper
    Heavy traffic and wet environments call for durable, chemical- and slip-resistant products. Fibergrate provides long-term, cost-effective solutions for the pulp and paper industry. Products can be used throughout facilities including pulping and bleaching areas, stock preparation, paper machines, chemical recovery, and finishing and converting.
    Recreational
    From sports fitness facilities, to water parks, to zoos and aquariums, to parks and marinas, safety, corrosion-resistance, aesthetics and maintenance are major concerns. Fibergrate’s full line of slip-resistant, low-maintenance products provide solutions for these concerns. Products can be used for foot bridges, piers and decks, park equipment, showers, pools, feeding areas, batting cages – the applications are endless.
    Telecommunications
    Fibergrate is providing telecommunications customers with the most cost-effective composite solutions for their projects. The RF transparent and lightweight features as well as nonconductive properties of Fibergrate’s products make them ideal for virtually all telecommunications projects. Installations are quick, easy and can be done with minimum labor and tools including on-site modifications
    . Transportation
    Severe weather, corrosive elements and heavy traffic within the transportation industry require products that are durable, low-maintenance and safe. Fibergrate products provide a cost-efficient solution to these harsh conditions. Products can be used as accessways, docks, trenches, tanker fill areas as well as walking surfaces and in work areas.
    Water and Wastewater
    Fibergrate products provide long-term solutions with products designed to address safety and corrosion issues found in all phases of water and wastewater treatment. Fibergrate’s products are environmentally safe and can be used extensively as filter media support, access walkways, trench and manhole covers, and walkovers. When required, Fibergrate will provide NSF approved products for your facility.
    ولمزيد من المعلومات يمكن الرجوع للموقع التالي
    http://www.fibergrate.com/
    مع تحياتي للجميع
    م. رزق حجاوي
    بنار اسيا
    بنار اسيا غير متواجد حالياً
    الصورة الرمزية بنار اسيا
    Received: 43
    Given: 131
    بارك الله فيكي اختي نور وجزاك وكل من ااثرى الموضوع والمعلومات القيمة كل خير وفقتم جميعا
    وجعلها الله من ميزان حسناتكم امين
    وفقتم باذن الله
    اللهم ارفع الظلم عن غزة في شهرك الفضيل يا ارحم الراحمين
    هادي المهندس
    هادي المهندس غير متواجد حالياً
    الصورة الرمزية هادي المهندس
    Received: 50
    عاشت اناملكم التي خطت لتنحت العلوم المميزه والتي انارتنا اكثر, طبعا الشكر للجميع لمن اثار الموضوع ولمن شارك فيه , لذا لدي سؤال:
    لماذا لا نشاهد هذا النوع في المباني , هل لغلائه ام لعدم انتشاره ام غير محبذ ام ماذا علما اني استعملته لتغليف قبب جامع وكذلك المناره وعاده يستخدم الالوان والنقوش الاسلاميه , ولم اشاهده يستخدم في مكان اخر
    Ayman
    Ayman غير متواجد حالياً
    الصورة الرمزية Ayman
    Received: 10
    اقتباس المشاركة الأصلية كتبت بواسطة هادي المهندس مشاهدة المشاركة
    صراحة ارى ان ال Grc أصبح منتشرا جدا في وقتنا الحالي...كما تنوعت استخداماته كثيرا بدءا من الأسقف و الحوائط مرورا بالمظلات و حتى الأشكال المزخرفة في المساجد وغيرها...
    غلاء سعر ال Grc المزخرف لا يقارن بأسعار الأرابيسك مثلا ..
    وقد نفذت مؤخرا تشطيب لواجهة فيلا كاملة به (تحوي كيرفات و قطاعات صعبة )
    بعض مميزاته:
    قطاعات صغيرة جدا - سهولة في الحمل و التركيب - قوة تحمل كبيرة - سطح أملس جميل - مقاومة للعوامل الجوية - سهولة التنظيف و تغيير اللون....
    تقبل تحياتي,,,,,,,,,
    اللهم تقبل
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    أشكرك أختي نور على طرح هذا الموضوع المفيد الذي فتح باب النقاش حوله من قبل الأساتذة الكرام.. شكراً لكم جميعاً..
    مع تحيـــــــــــــــاتي..
    بومكحلة
    بومكحلة غير متواجد حالياً
    الصورة الرمزية بومكحلة
    بارك الله فيكي اختي نور وجزاك الله كل خير وجعلها الله في ميزان حسناتكم امين أنا طالب سنة خامسة هندسة مدنية أود أن أعرف في أي المناطق عندنا في الجزائر يكثر استعمال الخرسانة المسلحة بالالياف الزجاجية
    وفقكم الله
    والــحـبُّ لـلـمُصْطَفَى لا الـشِّـعرُ iiيـدرِكُـهُ ولا دُهـــــورٌ مــــن الإنــشَــادِ و iiالــزَّجــلِ
    ولــو جَـمَـعْتَ فُـحـولَ الـقوْلِ كـي iiيَـصِفُوا أفـضـالَـهُ لَـمَـضَـوْا فــي مَـوْكِـبِ iiالـفَـشَلِ
    صـلَّـى عـلـيكَ رَجَـائِـي يــا فَــدَاكَ iiدَمِـي وسـلَّـمَـتْ فـــي رِضـــا إيــمَـاءةُ iiالـرُّسُـلِ
    Ayman
    Received: 10
    أخي المشرف الكريم
    حقيقة لا أذكر انه قد فتح النقاش حول ال Grc من قبل..
    اللهم تقبل
    Abo Fares
    Received: 344
    Given: 291
    اقتباس المشاركة الأصلية كتبت بواسطة ayman مشاهدة المشاركة
    أخي المشرف الكريم
    أهلاً أخي أيمن..
    لا أعتقد أني ذكرت في مشاركتي هذه بأن الموضوع قد تم النقاش فيه من قبل
    أقصد من خلال مشاركتي بأن هذا الموضوع قد سمح بفتح باب للنقاش حوله الآن ;)
    مع تحيــــــــــــــــاتي..
    Ayman
    Received: 10
    أهلاً أخي أيمن..
    نعم وصل معنى الجملة ..الرك على التشكبل...او النظر!
    صحيح مبروك للأهلي
    اللهم تقبل
