المميزات الجديدة لبرنامج DIALux 4.6 لحساب الإضاءة
النتائج 1 إلى 4 من 4
    الصورة الرمزية Ezzat_Baroudi
    Ezzat_Baroudi
    Ezzat_Baroudi غير متواجد حالياً
    مشرف تصميم الإضاءة
    Received: 137
    Given: 35
    إن شركة DIAL المنتجة لبرنامج DIALux تقدم للمشتركين بالمجلة الإلكترونية الخاصة بالبرنامج آخر أخبار البرنامج
    حتى يتسنى للمستخدمين معرفة كل ماهو جديد عن البرنامج وللإشتراك يمكن للمستخدم وضع عنوان بريده الإلكتروني على الرابط التالي
    http://www.dial.de/CMS/English/Artic...er_Inhalt.html
    وعلى كل حال سأنقل لكم ماهي المميزات الجديدة في الإصدار الأخير للبرنامج كما وردت على موقع الشركة
    DIALux 4.6
    • Sports complexes: In addition to existing outdoor planning functions, professional planning of sports aomplexes is now possible with DIALux. As well as various normed calculation grids there are also numerous positioning aids. Among other features, mirroring of floodlight arrangements simplify the illumination of stadiums
    • Floodlighting: Luminaires can be mirrored via two symmetrical axes. The alignment of the luminaires is made via focal points which are positioned on the area to be illuminated; with a mouse click further focal points can be set, then a luminiare of the same type is positioned automatically and aligned, and, if necessary, can be removed again in this way.
    • Grids with direct visualization in CAD: Calculation results can now be presented in real time for calculation grids. The results of direct light are shown in the CAD view. Modifications such as increasing the number of luminaires and the alignment are displayed immediately as a result.
    • Should a common calculation result be required by several calculation grids, these can now be combined with DIALux 4.6. For example the uniformity of different steps in a stairway can be displayed as a result.
    • To simplify the alignment of luminaires DIALux now enables you to switch on the LDC presentation of the luminaires positioned in the project for CAD views. The number of LDCs displayed can now be freely defined. Display either all or only individual LDCs. You decide for yourself.
    • With these enhancements and improvements our partners are now able to provide even more detailed luminaire models. Greater functionality of the articulated joints of luminaires enables you to be more flexible in future and adhere even more closely to the plans during light planning.
    • The guide shown on the right hand side of the screen can be structured as you wish. Simply adapt the ******* to your planning requirements and activate or deactivate individual planning menus.
    • DIAlux reminds you to save your plan. By means of a freely adjustable interval in “Settings” DIALux asks you at regular intervals to save your planning data. So you will no longer lose anything.
    المهندس المحبوب
    المهندس المحبوب غير متواجد حالياً
    انتظار
    الصورة الرمزية المهندس المحبوب
    مشكور استاذ عزت على كل ما تقدمه لنا من معلومات قيمة
    Omar.ie
    Omar.ie غير متواجد حالياً
    مشكووور استاذ عزت على المعلومات المميزة و ننتظر منك المزيد من المعلومات حول كيفية استعمال البرنامج بالطريقة الاحترافية.
    Ezzat_Baroudi
    مشرف تصميم الإضاءة
    Received: 137
    Given: 35
    شكرا أخي عمر
    Tweeter @ezzatbaroudi
