ردود مكتبة السلامة المهنية مجمعة
صفحة 39 من 52 الأولىالأولى ... 2935 36 37 38 3940 41 42 43 49 ... الأخيرةالأخيرة
النتائج 381 إلى 390 من 518
  1. [381]
    احمد ابو جلال
    احمد ابو جلال غير متواجد حالياً
    الصورة الرمزية احمد ابو جلال
    Process Hazard Analysis - PHA
    Process Hazard Analysis (PHA) is a method to evaluate and identify credible hazardous scenarios. PHA is a thorough, orderly, systematic approach for identifying, evaluating, and controlling the hazards of processes involving hazardous chemicals. Based on most U.S. state and federal standards, an initial PHA must be performed on all covered processes. Thereafter all PHAs must be updated and revalidated, based on their completion date, at least every 5 years.
    The process hazard analysis methodology selected must be appropriate to the complexity of the process and must identify, evaluate, and control the hazards involved in the process. One or more of the following methods is used, as appropriate, to determine and evaluate the hazards of the process being analyzed:
    * What-if,
    * Checklist,
    * What-lf/checklist,
    * Hazard and operability study (HAZOP),
    * Failure mode and effects analysis (FMEA),
    * Fault tree analysis, or
    * An appropriate equivalent methodology.
    The PHA must address the following:
    * The hazards of the process;
    * The identification of any previous incident that had a potential for catastrophic consequences in the workplace;
    * Engineering and administrative controls applicable to the hazards and their interrelationships, such as appropriate application of detection methodologies to provide early warning of releases. Acceptable detection methods might include process monitoring and control instrumentation with alarms, and detection hardware such as hydrocarbon sensors;
    * Consequences of failure of engineering and administrative controls;
    * Facility siting;
    * Human factors; and
    * A qualitative evaluation of a range of the possible safety and health effects on employees in the workplace if there is a failure of controls.
    The PHA is performed by a team with expertise in engineering and process operations. The PHA team should include at least one employee who has experience with and knowledge of the process being evaluated. One member of the team must be knowledgeable in the specific analysis methods being used.
    In performing a PHA, the first step is to define the purpose, scope and objectives of the study. The purpose defines why the PHA is being performed, e.g. to identify hazardous scenarios, to meet a regulatory requirement, etc. The scope defines the boundaries of the process being studied. The objectives define the expectations of the PHA results.
    Next step is amass all the pertinent Process Safety Information (PSI) [see “The more you know: Process Safety Information (PSI)”] and appropriate Standard Operating Procedures. To plan the PHA, the process is divided into smaller manageable sections.
    The PHA is conducted by identifying deviations from the design intent. The design intent includes values for operating conditions (e.g. temperature, pressure, flow, etc.), equipment (e.g. materials of construction, etc.) or external events (e.g. general loss of electrical power, etc.). There may be one or several causes of deviations. Causes are categorized as: 1.) Human Error, 2.) Equipment Failure or 3.) External Events. The team brainstorms and decides the credible causes of these deviations. If one of these deviations may occur, there are consequences that may result. The consequences may impact operability, quality or may be hazardous. Each scenario (deviation/cause – consequence combination) is evaluated further, particularly the hazardous scenarios. In evaluating these scenarios, existing safeguards are documented that prevent, detect or mitigate the scenarios. The team then determines if a recommendation is appropriate to prevent, detect or mitigate the scenarios.
  2. [382]
    eng_ahmed_toshiba
    eng_ahmed_toshiba غير متواجد حالياً
    الصورة الرمزية eng_ahmed_toshiba
    thankssssssssssssssssssssssssssssssssssss
  3. [383]
    المهندس غسان خليل علوة
    المهندس غسان خليل علوة غير متواجد حالياً
    مشرف السلامة المهنية
    الصورة الرمزية المهندس غسان خليل علوة
    Received: 112
    Given: 64
    جزاكم الله كل خير على النقل
    سأقوم بتحميل الكتب ومن سنتحدث بالتفاصيل إنشاء الله
  4. [384]
    Received: 112
    Given: 64
    أخي أحمد قد نتأخر بالرد ولكن ليس هذا نتيجة تقصير وإنما للإطلاع على محتوى الكتاب
    أما بعد
    بارك الله فيك أخ محب الله ورسوله
    كتاب ممتاز بكل ما للكلمة من معنا
    وفقك الله فأنت موسوعتنا الالكترونية المميزة التي نعتمد عليها على الدوام
    كما أن الأخ أسامة عباس بدأ بإتحافنا بكتب جديدة
    جزاكم الله كل خير
  5. [385]
    Received: 112
    Given: 64
    ليس هناك من عبارات شكر تفيك حقك
    وليس هناك أي كلمات تعبر عن مضمون إعجابي بك
    جزاك الله عنا كل خير
    وبارك بك وبجهودك
  6. [386]
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    جزاك الله تعالى خيرآ ونفع بك
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
  7. [387]
    أهل الحديث
    Received: 205
    Given: 261
    الحمد لله تعالى أن أفادتكم الكتب
    وفقكم الله وأعانكم ونفع بكم وسدد خطاكم
  8. [388]
    أهل الحديث
    Received: 205
    Given: 261
    اقتباس المشاركة الأصلية كتبت بواسطة eng_ahmed_toshiba مشاهدة المشاركة
    اخي العزيز ارجو تحميله علي موقع اخر لانني مش عارف احمل من علي هذه المواقع ارجو الرد بسرعة لاني محتاج الكتاب ده اوي
    شرح كيفية التحميل للكتب من Rapidshare والمواقع الأخرى
    http://www.arab-eng.org/vb/t78750.html
  9. [389]
    Received: 112
    Given: 64
    جزاكم الله كل خير
    كتاب مهم
    بارك الله فيك
  10. [390]
    طارق رزق شلبى
    طارق رزق شلبى غير متواجد حالياً
    الصورة الرمزية طارق رزق شلبى
    جزاك الله خيرا
    برجاء إذا كان لديكم أى محاضرات ورد وباور بوينت عن الناسب ياريت وشكرا
