electrical engineers needs help
النتائج 1 إلى 8 من 8
    الصورة الرمزية cyprus
    cyprus
    cyprus غير متواجد حالياً
    dear friends i want to ask about split unit AC or central AC
    now sometimes when i design the projects in the country that i work in it most of the customers ask me what type of ACi should use ( spilt unit ) how much BTU so is there any rule or formulas that can help me to find the answer
    secondly is there any file that can help me to understand the central AC basics how much power it takes the connections
    hope my question is clear
    thanks
    شربة ماء
    شربة ماء غير متواجد حالياً
    الصورة الرمزية شربة ماء
    combien de BTU tu as besoin dépend du local qu'on veut climatiser. cette quantité de chaleur est déterminée en faisant un calcul de bilan de charges thermiques dans ce local, ce cacul se fait en utilisant une des méthodes de calcul telle que la méthode de COSTC, métode de CARRIER ou autre méthode suivant les normes du pay où vous êtes. ce travail concerne les ingénieus de froid et climatisation et non pas votre travail mon collègue
    cyprus
    thanks dear friend but i cant understand ur language i just know Arabic English or Turkish :) thanks again for ur answer
    شربة ماء
    you can use traductor from google
    محمد محمود خليل
    محمد محمود خليل غير متواجد حالياً
    زائر
    الصورة الرمزية محمد محمود خليل
    Received: 37
    This is the translation from google(COPY- PASTE)
    how many BTU you need depends on the local you want cool. this amount of heat is determined by a calculation of thermal balance of charges in this room, this is Caçula using one method of calculation as the method of COSTC, Metodi Carrier or other method according to the standards of where you pay are. this case ingénieus cooling and air-conditioning and not your work my colleague
    محمد محمود خليل
    زائر
    Received: 37
    اقتباس المشاركة الأصلية كتبت بواسطة cyprus مشاهدة المشاركة
    thanks
    Dear Syprus
    usually we use ton refrigeration to describe the cooling capacity of the airconditioning units
    we also use other units such as watt ,btu,kcal...etc
    one tone refrigeration us equal to 12000 btu (british thermal unit) also is equal to about 3.5 kw
    the power consumption depends on the unit manufacturing
    EER (energy efficiency ratio) is cooling capacity in watts devided by the electrical power consumption in watts which should be mor
    than 2.5 otherwise the unit is too bad
    you can consider the power consumtion 30% of the cooling capacity
    example : we have a room of 40 cubic meter surface
    lets consider that the unit capacity is 2 tons refrigeration which is equal to 24000 btu or about 7.1 kw cooling(lets say 7 kw)...the power consumption is 7 x 0.3=2.1kw power
    you can consider about 6 ampers for one ton refrigeration at running
    these informations are not very very precise because the depend on the unit type but there are resonable
    cyprus
    thanks for the information
    نورالدين بلال
    نورالدين بلال غير متواجد حالياً
    ابحث عن برنامج لتصميم داراة الكهربائية لغرف التبريد
    و عن برنامج لتصميم وموضع انابيب و عناصر الاساسية لغرف التبريد
