Pile Design for Structural and Geotechnical Engineers -2008
النتائج 1 إلى 5 من 5
    الصورة الرمزية majdiotoom
    majdiotoom
    majdiotoom غير متواجد حالياً
    Received: 66
    by Ruwan Rajapakse
    By Ruwan Rajapakse
    • Publisher: Butterworth-Heinemann
    • Number Of Pages: 416
    • Publication Date: 2008-02-08
    • ISBN-10 / ASIN: 0750687630
    • ISBN-13 / EAN: 9780750687638
    • Binding: Paperback
    All objects and structures transfer their load either directly or indirectly to the earth. The capacity of the earth to support such loads depends on the strength and stability of the supporting soil or rock materials. Pile foundations are the part of a structure used to carry and transfer the load of the structure to the bearing ground located at some depth below ground surface. There are many texts on pile foundations. Generally, these books are complicated and difficult to understand. Easy to use and understand, this book covers virtually every subject concerning pile design, featuring techniques that do not appear in other books on the subject. The book contains design methods with real life examples on pin piles, bater piles, concrete piles, steel piles, timber piles, auger cast piles, underpinning design, seismic pile design, negative skin friction and design of Bitumen coated piles for negative skin friction and many other subjects. The book is packed with design examples, case studies and after construction scenarios are presented for the reader's benefits. This book enables the reader to come away with a complete and comprehensive understanding of the issues related to the design, installation and construction of piles.
    * Handy guide for engineers perparing the professional engineer (PE) exam.
    * Nomrous design examples for sandy soils, clayey soils, seismic loadings
    * Methodologies and case studies for different pile types
    links
    م شرحبيل
    م شرحبيل غير متواجد حالياً
    الملف غير موجود على الروابط
    rtaleb
    rtaleb غير متواجد حالياً
    First link is OK
    Here is an other link on 4shared
    http://www.4shared.com/file/R-kUEr_t/Pile_Design.html
    م.تسنيم
    م.تسنيم غير متواجد حالياً
    الصورة الرمزية م.تسنيم
    جزاك الله عنا كل خير
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 448
    مشكور وجزاكم الله خيراً اخي الفاضل
    الإمام محمد الغزالي
