Centifugal Pumps
النتائج 1 إلى 6 من 6
    الصورة الرمزية دلاور
    دلاور
    دلاور غير متواجد حالياً
    Centifugal Pumps
    Johann Friedrich Gülich “Centrifugal Pumps"
    Springer | 2007-11-14 | ISBN: 3540736948 | 926 pages | PDF | 25,5 MB
    This book gives an unparalleled, up-to-date, in-depth treatment of all kinds of flow phenomena encountered in centrifugal pumps including the complex interactions of fluid flow with vibrations and wear of materials.
    The scope includes: all aspects of hydraulic design, 3D-flow phenomena and partload operation, cavitation, numerical flow calculations, hydraulic forces, pressure pulsations, noise, pump vibrations (notably bearing housing vibration diagnostics and remedies), pipe vibrations, pump characteristics and pump operation, the effects of highly viscous flows, pumping of gas-liquid mixtures, hydraulic transport of solids, fatigue damage to impellers or diffusers, material selection under the aspects of fatigue, corrosion, erosion-corrosion or hydro-abrasive wear, pump selection, and hydraulic quality criteria.
    To ease the use of the information, the methods and procedures for the various calculations and failure diagnostics discussed in the text are gathered in more than 100 pages of tables which may be considered almost unique in the open literature. The text focuses on practical application in the industry and is free of mathematical or theoretical ballast. In order to find viable solutions in practice, the physical mechanisms involved should be thoroughly understood. The book is focused on fostering this understanding which will benefit the pump engineer in industry as well as academia and students.
    depositfiles.com
    filefactory
    الثراوين
    الثراوين غير متواجد حالياً
    الصورة الرمزية الثراوين
    مشكور والى الامام
    الثراوين
    النجم مصر
    النجم مصر غير متواجد حالياً
    مشكور والى الامام
    النجم المصرى
    بلال عبدالرازق
    بلال عبدالرازق غير متواجد حالياً
    مشكور ........ وجزاك الله خيرا
    حمدي الزعيم
    حمدي الزعيم غير متواجد حالياً
    الصورة الرمزية حمدي الزعيم
    شكرا جزيلا و جزاك الله عنا كل الخير
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    اتفضلوا اخوانى اضافة على موضوع اخى
    http://carsnology.blogspot.com/2008/...eshooting.html
    ملف على صيانة الpumps
