AISC Seismic Design Handbook
النتائج 1 إلى 3 من 3
    SAB35263
    SAB35263 غير متواجد حالياً
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 206
    Given: 261
    المتوفر حاليآ ربما يفيدك :
    http://www.arab-eng.org/vb/t104019.html
    { الَّذِينَ آتَيْنَاهُمُ الْكِتَابَ يَعْرِفُونَهُ كَمَا يَعْرِفُونَ أَبْنَاءَهُمُ }
    أهل الحديث
    Received: 206
    Given: 261
    GENERAL
    1.1 Scope
    This Standard specifies design, detailing, fabrication and quality criteria for
    connections that are prequalified in accordance with the AISC Seismic Provisions
    for Structural Steel Buildings (herein referred to as the AISC Seismic Provisions)
    for use with special moment frames (SMF) and intermediate moment frames
    (IMF). The connections contained in this Standard are prequalified to meet the
    requirements in the AISC Seismic Provisions only when designed and constructed
    in accordance with the requirements of this Standard. Nothing in this
    Standard shall preclude the use of connection types contained herein outside
    the indicated limitations, or the use of other connection types, when satisfactory
    evidence of qualification in accordance with Appendix S of the AISC Seismic
    Provisions is presented to the authority having jurisdiction.
    1.2 References
    The following standards form a part of this Standard to the extent that they
    are referenced and applicable:
    2005 AISC Seismic Provisions for Structural Steel Buildings
    2004 AWS D1.1 Structural Welding Code – Steel (herein referred to as AWS
    D1.1)
    2004 RCSC Specification for Structural Joints using ASTM A325 or A490 Bolts
    (herein referred to as the RCSC Specification)
    2005 AISC Specification for Structural Steel Buildings (herein referred to as
    the AISC Specification)
    1.3 General
    All design, materials, and workmanship shall conform to the requirements of
    the AISC Seismic Provisions, and this Standard. The connections contained in this
    Standard shall be designed according to the Load and Resistance Factor Design
    (LRFD) provisions. Connections designed according to this Standard are permitted
    to be used in structures designed according to the LRFD or Allowable
    Strength Design (ASD) provisions of the AISC Seismic Provisions.
    http://rapidshare.com/files/56469649...ames_for_Seism
    http://rapidshare.com/files/64673057/R20071023A.rar
