برنامج الحماية المتكامل McAfee VirusScan Enterprise v8.7i Retail
النتائج 1 إلى 3 من 3
    الصورة الرمزية الشاكر لله
    الشاكر لله
    الشاكر لله غير متواجد حالياً
    السلام عليكم إخواني الأعزاء
    برنامج حماية أثبت فعاليته في المجال وتتضمن هذه النسخة على جدار ناري إلى جانب الحماية من الفايروسات والتروجانات وغيرها من الأخطار التي يمكن أن تهدد جهازك.
    Features:
    - Comprehensive McAfee anti-virus protection
    - Potentially unwanted program security
    - Buffer overflow prevention (IPS feature)
    - Complete outbreak response
    - Port blocking/lockdown (firewall feature)
    - Application monitoring: email engines (firewall feature)
    - File blocking, directory lockdown, folder/share blocking (IPS feature)
    - Infection trace and block
    - Powerful memory scanning
    - Centralized management and reporting
    - Enhanced email scanning
    - Protection from threats that use ******s
    - Optimized for mobile users
    New features in v8.7i
    New and updated features in the current release of the software:
    - Support for Microsoft Windows Server 2008
    - Architectural changes:
    ● Better rootkit detection and cleaning without system restart — Safe memory patching, better IRP repair support at the system core, and the ability to read locked files at the kernal level provide better rootkit detection and the ability to clean detections without restarting the system.
    ● On-access scan performance improvements during system startup — A new boot cache process improves on-access scan performance during system startup.
    ● Greater self-protection — The self-protection feature has been enhanced to protect against a wider range of mal-processes that can terminate McAfee processes. This provides greater VirusScan Enterprise self-protection and product stability.
    - Real-time malware protection:
    ● This feature uses sensitivity levels that can be configured, based on your risk tolerance, to look for suspicious files on your endpoints that are running VirusScan Enterprise 8.7i.
    ● When enabled, this feature detects a suspicious program and sends a DNS request containing a fingerprint of the suspicious file to McAfee Avert Labs, which then communicates the appropriate action back to VirusScan Enterprise 8.7i.
    ● The real-time defense feature also provides protection for classes of malware for which signatures might not be available.
    ● This protection is in addition to the world-class DAT-based detection VirusScan Enterprise has always provided. The user experience remains the same and no additional client software is required.
    ● In this release, this feature is available only for on-demand scans and email scanning and is disabled by default. You must select a sensitivity level to enable the feature.
    - Performance improvements:
    ● New scan deferral options improve local control of on-demand scans, including the ability to defer scans when using battery power or during presentations. One option can be configured to allow end users to defer scheduled on-demand scans for the increment of time you specify. You can specify hourly increments up to twenty-four hours, or forever.
    ● Enhanced system throttling now includes registry and memory scanning in addition to file scanning.
    - Improved email scanner
    - Buffer overflow protection exclusions by API
    - On-access scanner — Scan processes on enable
    - On-demand scan usability improvements:
    ● Clean — Report and clean the detection.
    ● Continue — Report the detection and continue scanning.
    وكل عام وأنتم بألف خير وبركة
    مزمل ميرغني
    مزمل ميرغني غير متواجد حالياً
    شكرا ياراع
    المهاجر16
    المهاجر16 غير متواجد حالياً
    أخي الكريم جزاك الله خيرا وبارك فيك لكن الرابط لا يعمل الرجاء إعادة رفعه من جديد
