تحديثات مهمة لأوتوكاد 2009 من Autodesk
النتائج 1 إلى 10 من 18
    الصورة الرمزية meee
    meee
    meee غير متواجد حالياً
    قامت شركة Autodesk بأضافة بعض التعديلات على البرنامج , نظراً لحدوث بعض المشاكل التقنية في البرنامج!
    ألتحديث الأول
    http://usa.autodesk.com/adsk/servlet...linkID=9240618
    ألتحديث الثاني
    قم بتثبيت التحديثات على التوالي
    أدناه, تقرير يوضح المشاكل المراد أصلاحها
    Problems Reported with the Customer Error Reporting Utility
    As a result of detailed information from customers who used the Customer Error Reporting Utility, a number of problems were identified and fixed. Updates have been made in the following feature areas:
    * 3D Visual Styles
    * Annotation Scaling
    * External References (xref) palette
    * Raster Images
    * Partial Open
    * Plot
    * Properties Palette
    * Hatch
    * Remote text (rtext)
    General Updates
    The following defects have also been fixed:
    .NET API
    * When a .NET function with a LispFunction attribute has the return type as object, an exception is thrown in AutoCAD.
    Annotation Scaling
    * A drawing that contains a large number of anonymous blocks and copies of annotative entities created in AutoCAD 2007, or an earlier release, opens slowly in AutoCAD 2009.
    * A scale is infinitely enumerated when you insert a drawing that contains the same scale as a block or an external reference (xref).
    Attributes
    * When you attempt to display a tooltip of a multiline text (mtext) attribute that contains 281 characters or more, AutoCAD crashes.
    * When you move a block using an insertion grip, mtext attributes move incorrectly.
    * When the default value of an mtext attribute in a block contains a field, you cannot edit the attribute text to replace the field with other data.
    Blocks
    * When you insert or redefine a block that contains attributes on a locked layer, AutoCAD crashes.
    * When you change the scale of a block through the Properties Palette, an attribute displays incorrectly.
    Export a Layout to Model Space
    When you export a layout to model space the following occurs:
    * The linetype scale changes.
    * Dimension arrowheads do not display.
    * Text does not rotate correctly.
    * Drawing properties are lost.
    External Reference ESW
    * The External References palette does not display when auto-hidden and used with the XREF or IMAGE commands are used.
    Hatch
    * When you recreate a hatch boundary, it consists of separate line segments rather than a closed polyline.
    Hide/Shade
    * When you plot, objects in an xref are not correctly hidden.
    Menu Browser
    * You cannot access the menu browser in a non-English version of AutoCAD using the shortcut Alt+Key.
    Multileader (mleader)
    * When created on a rotated UCS, a multileader does not respect POLAR or ORTHO settings.
    Multiline Text (mtext)
    * When you drag and drop a drawing while the In-Place Text Editor is active, AutoCAD crashes.
    * When some of the values in the In-Place Text Editor are changed, AutoCAD crashes.
    * Some mtext objects with double byte characters display as a single line.
    Open/Save
    * When you attempt to save a file with a long file name, AutoCAD may crash.
    * When you drag and drop a file from Windows Explorer into the AutoCAD title bar while in Single Document Interface (SDI) mode, AutoCAD may crash.
    * When you attempt to open multiple files from Windows Explorer, only the first selected file opens.
    Partial Open
    * When the OPENPARTIAL system variable is set to 1, if you use the PURGE command, drawings may become corrupted.
    Plot
    * When you plot upside-down, an OLE object does not plot correctly.
    Property Palette
    * In the Properties palette, the Dimension Style control may display an incorrect dimension style name.
    Publish
    * In the Publish dialog box, the Publish To setting always defaults to DWF format even if you select a different setting.
    Quick Properties
    * When you change the theme of your operating system while running AutoCAD and then click the Quick Properties window, AutoCAD crashes.
    RECOVER
    * When you open some valid drawings, you are prompted to use the RECOVER command.
    Render
    * When you use the RENDER command with certain drawings that contain textured object, AutoCAD crashes.
    Ribbon
    * When acad.CUI is loaded as a partial CUI, some buttons in the multiline text (mtext) ribbon contextual tab fail.
    * On a ribbon panel, you may not be able to move items between rows.
    * A ribbon panel continues to display after it is removed from a ribbon tab.
    * A button image used on a ribbon panel that is loaded from a resource DLL file lacks a transparent background.
    * If you transfer a ribbon panel and a tab, buttons display small.
    * Enterprise, main, and partial CUI files display multiple ribbon tabs in workspaces.
    * You cannot control a ribbon tab when you use more than one non-AutoCAD CUI file.
    * A ribbon tab and/or menu macro may not function properly when referenced from multiple CUI files.
    * If you load a CUI file that references a missing BMP file, a fatal error displays.
    Visual LISP
    * The AutoLISP Redraw function fails to hide or highlight objects.
    ZOOM
    * When you zoom while inserting some blocks, AutoCAD crashes.
    Known Issues with This Update
    After you apply this update, you may experience the following ribbon customization-related problems:
    An Incorrect or Missing Ribbon Tab
    Known Issue: When you display a ribbon tab from a partial of Enterprise CUI file, on the ribbon, the ribbon tab displays incorrectly or is missing.
    Workaround: To correctly display a ribbon tab, recreate the workspace used to display the ribbon tab from scratch. Do not duplicate or attempt to update the workspace. Once you create a new workspace, set the workspace current. The ribbon tab should display correctly.
    For a partial CUI file, before you add a ribbon tab to a workspace, use the Customize User Interface (CUI) Editor to change the customization group name of the file. The customization group name is represented by the uppermost node of the tree in the Customization In pane.
    A Blank Image for a Command
    Known Issue: On a ribbon panel, the image associated with a command defined in the Command List pane displays as a blank icon.
    Workaround: To recreate a ribbon command item on a ribbon panel, delete it. Then, from the Command List pane, add the command to the ribbon panel.
    تحياتي ــــــــــــــــ
    el_shawadify
    el_shawadify غير متواجد حالياً
    شكرا جزيلا أخي الكريم وبارك الله فيك..
    عبداللطيف الوحيشي
    عبداللطيف الوحيشي غير متواجد حالياً
    الصورة الرمزية عبداللطيف الوحيشي
    جزاك الله خيرا
    ومشكووووووووووووور
    ::: أخى لا تجعل فى توقيعك ما يوقعك فى ذنب:::
    ::: و لا تكتفى بأن يكون توقيعك لا يغضب الله:::
    ::: بل إجعل توقيعك دعوة الى الله:::
    "فذكر ان الذكرى تنفع المؤمنين"
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    ... بارك الله فيك اخي الكريم ...
    ... وجزاك الله خير جزاء ....
    .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج ....
    ... اعتــــــذر عن عدم التواجد ...
    ... العين تقراء السطور ... والعقل يقراء ما بين السطور ...
    meee
    الصورة الرمزية meee
    اقتباس المشاركة الأصلية كتبت بواسطة el_shawadify مشاهدة المشاركة
    لا شكر على واجب
    meee
    الصورة الرمزية meee
    اقتباس المشاركة الأصلية كتبت بواسطة عبداللطيف الوحيشي مشاهدة المشاركة
    جزاك الله خيرا
    ومشكووووووووووووور
    1000 أهلا وسهلا عبد اللطيف
    meee
    الصورة الرمزية meee
    اقتباس المشاركة الأصلية كتبت بواسطة mu7ammad مشاهدة المشاركة
    منورالموضوع محمد
    التنين الفضى
    التنين الفضى غير متواجد حالياً
    الصورة الرمزية التنين الفضى
    لك جزيل الشكر على ما قدمته من عمل جيد
    التنين الفضى
    meee
    الصورة الرمزية meee
    اقتباس المشاركة الأصلية كتبت بواسطة التنين الفضى مشاهدة المشاركة
    Thanks for replying the Silver Dragon
    Regards
    عمرو السباعى
    عمرو السباعى غير متواجد حالياً
    الصورة الرمزية عمرو السباعى
    مشكوووووور وجزاك الله خيرا
