سؤال لاهل الخبرة والحلول في هذة المشكلة
النتائج 1 إلى 4 من 4
    hasssum
    hasssum غير متواجد حالياً
    السلام عليكم ورحمة اللة وبركاتة
    انا زائر من قسم التخطيط والعمارة ولدي مشكلة وارجو المساعدة
    عندما اقوم بفتح الهوت ميل واريد فتح الرسائل واقوم بالضغط علي زر الماوس الايمن افتح الرسالة في نافذة جديدة تظهر لي هذة الرسالة:
    javascript:;
    The page cannot be displayed
    The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
    To attempt fixing network connectivity problems, click Tools, and then click "Diagnose Connection Problems..."
    Other options to try:
    Click the Refresh button, or try again later.
    If you typed the page address in the Address bar, make sure that it is spelled correctly.
    To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
    See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
    Click the Tools menu, and then click Internet Options.
    On the Connections tab, click LAN Settings.
    Select Automatically detect settings, and then click OK.
    Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
    If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
    Click the Back button to try another link.
    Cannot find server or DNS Error
    Internet Explorer
    ولا اعرف الحل وجزاكم اللة خيراً
    محبة الله ورسوله*
    Received: 30
    Given: 13
    حيااااااااك الله اخي
    المشكلة في برنامج الانترنت اكسبلورر يعني المتصفح وهو جاب لك المشكلة وعرض عليك الحلول كمان
    وإذا كان ولابد اخي وعايز تفتح *****ي في صفحة جديدة افتح البررررريدددد اكثر من مرة على حسب احتياجك وبدل الزر الايمن ...
    وفقك الله
    متغيبه عن الملتقي دعواتكم
    الياسين الياسين
    الياسين الياسين غير متواجد حالياً
    بتحصل مع اي واحد
    ابراهيم الانصارى
    ابراهيم الانصارى غير متواجد حالياً
    الصورة الرمزية ابراهيم الانصارى
    المشكلة كما قالت وردة فعلا وواجهتنى
