=====>("-...the future soon ...-")<=====
النتائج 1 إلى 3 من 3
    الصورة الرمزية وائل ايراجون
    وائل ايراجون
    وائل ايراجون غير متواجد حالياً
    When you combine the idea of
    electro-magnetically floating skyscrapers
    Ever imagined that a building could hover about the ground - floating in mid air? Architect Joseph Cory thinks the above scenario might be possible in the future, using electro-magnetism. In his Electro-Magnetic Skyscrapers project, the structures support each others through their electromagnetic fields.
    “By using magnetic fields as a construction material there can be infinite vertical and horizontal expansions due to the final liberation from gravity.”
    Using magnetic fields as a construction material, the skyscrapers would also integrate built-in energy systems from photovoltaic cells on the sides of the cube to wind turbines, air shafts forcing wind into energy, water conservation tanks, and more.
    Cory is currently working towards his PhD in the IIT, Isreal, and has teamed up with other sustainable conscious architects, artists and scientists to push the limits of sustainability though a variety of award-winning design competition projects. “Geotectura means merging land and architecture together with ecological values, cost effective technologies, psychological consideration and social context,” he says.
    In this futuristic scenario controlled Electro Magnetic force (E.M.) will be a key element in the building industry. This controlled E.M. force will free humanity from the need to waste our planet resources by making the E.M. technology the ultimate sustainable method. E.M. Structures will be able to support each other simply by pure physical magnetism that can also direct electricity. By using magnetic fields as a construction material there can be Infinite vertical and horizontal expansions due to the final liberation from gravity. Tokyo was chosen to set the first example for the rest of the world in building a series of Electro-Magnetic Skyscrapers and these buildings will be able to migrate like birds. Self sufficient energy cubes will provide the basic needs to the community. By using built-in energy resources in every E.M. Cube (such as photovoltaic cells on the sides of the cube, Wind turbines, air shafts forcing wind into energy, water conservation tanks etc.) the process will make this self-sufficient cubes an economical and ecological building units. The endless dimensionality and durability of the self spatial growing cubes is due to the magnetic force that can never run out of its power. The magnetic forces will replace the traditional way of moving with a new multi dimensional magnetic elevators that can run along side the E.M. Cubes accelerating/ decelerating through a magnetic gear.
    وائل ايراجون
    Thumbs up sunbus station
    هيطول غيــــابى بسبب الدراسه ..ادعولى من قلبكم بالتوفيق.. وان شاء الله ممكن اتواجد كل يوم خميس او جمعه
    هتوحشــــــــــــــونى
    وائل ايراجون
    Post absolute green
