أقوى مكتبة Finite Element متجددة باستمرار
النتائج 1 إلى 10 من 14
    meshkah
    meshkah غير متواجد حالياً
    اليوم أهديكم أقوى مكتبة Finite Element يمكن أن تو جد على الانترنت و متجددة باستمرار
    المكتبة هنا
    نبذة عن طريقة الحساب بال Finite Element
    Finite element method
    The finite element method (FEM) (sometimes referred to as finite element analysis) is a numerical technique for finding approximate solutions of partial differential equations (PDE) as well as of integral equations. The solution approach is based either on eliminating the differential equation completely (steady state problems), or rendering the PDE into an approximating system of ordinary differential equations, which are then solved using standard techniques such as Euler's method, Runge-Kutta, etc.
    In solving partial differential equations, the primary challenge is to create an equation that approximates the equation to be studied, but is numerically stable, meaning that errors in the input data and intermediate calculations do not accumulate and cause the resulting output to be meaningless. There are many ways of doing this, all with advantages and disadvantages. The Finite Element Method is a good choice for solving partial differential equations over complex domains (like cars and oil pipelines), when the domain changes (as during a solid state reaction with a moving boundary), when the desired precision varies over the entire domain, or when the solution lacks smoothness. For instance, in a frontal crash simulation it is possible to increase prediction accuracy in "important" areas like the front of the car and reduce it in its rear (thus reducing cost of the simulation); Another example would be the simulation of the weather pattern on Earth, where it is more important to have accurate predictions over land than over the wide-open sea.
    FEM example of 2D solution
    Example of 2D mesh
    History
    The finite-element method[1] originated from the needs for solving complex elasticity, structural analysis problems in civil and aeronautical engineering. Its development can be traced back to the work by Alexander Hrennikoff (1941) and Richard Courant (1942). While the approaches used by these pioneers are dramatically different, they share one essential characteristic: mesh discretization of a continuous domain into a set of discrete sub-domains, usually called elements.[2]
    Hrennikoff's work discretizes the domain by using a lattice analogy while Courant's approach divides the domain into finite triangular subregions for solution of second order elliptic partial differential equations (PDEs) that arise from the problem of torsion of a cylinder [3]. Courant's contribution was evolutionary, drawing on a large body of earlier results for PDEs developed by Rayleigh, Ritz, and Galerkin.
    Development of the finite element method began in earnest in the middle to late 1950s for airframe and structural analysis and gathered momentum at the University of Stuttgart through the work of John Argyris and at Berkeley through the work of Ray W. Clough in the 1960s for use in civil engineering.[4] By late 1950s, the key concepts of stiffness matrix and element assembly existed essentially in the form used today[5] and NASA issued request for proposals for the development of the finite element software NASTRAN in 1965. The method was provided with a rigorous mathematical foundation in 1973 with the publication of Strang and Fix's An Analysis of The Finite Element Method[6], and has since been generalized into a branch of applied mathematics for numerical modeling of physical systems in a wide variety of engineering disciplines, e.g., electromagnetism and fluid dynamics.
    FAE visualization
    Application
    A variety of specializations under the umbrella of the mechanical engineering discipline (such as aeronautical, biomechanical, and automotive industries) commonly use integrated FEM in design and development of their products. Several modern FEM packages include specific components such as thermal, electromagnetic, fluid, and structural working environments. In a structural simulation, FEM helps tremendously in producing stiffness and strength visualizations and also in minimizing weight, materials, and costs. FEM allows detailed visualization of where structures bend or twist, and indicates the distribution of stresses and displacements. FEM software provides a wide range of simulation options for controlling the complexity of both modeling and analysis of a system. Similarly, the desired level of accuracy required and associated computational time requirements can be managed simultaneously to address most engineering applications. FEM allows entire designs to be constructed, refined, and optimized before the design is manufactured. This powerful design tool has significantly improved both the standard of engineering designs and the methodology of the design process in many industrial applications.[7] The introduction of FEM has substantially decreased the time to take products from concept to the production line.[7] It is primarily through improved initial prototype designs using FEM that testing and development have been accelerated.[8] In summary, benefits of FEM include increased accuracy, enhanced design and better insight into critical design parameters, virtual prototyping, fewer hardware prototypes, a faster and less expensive design cycle, increased productivity, and increased revenue.
    For More About Finite Element Method
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    الصورة الرمزية ماجد جلميران
    انت بلا منازع ملك تقنية العنصر المحدد
    meshkah
    شكرا يا أخي على هذا الاطراء وأرجوا أن يستفيد الجميع
    awabtaha
    awabtaha غير متواجد حالياً
    الصورة الرمزية awabtaha
    Received: 10
    الف شكر جهد مقدر والكتب قيمة جدا
    نفعك الله بهذا المجهود
    سلامات
    اشرف بيبو
    اشرف بيبو غير متواجد حالياً
    الصورة الرمزية اشرف بيبو
    مشكوررررررررررررررررررررر
    اسلام الكبير
    اسلام الكبير غير متواجد حالياً
    الصورة الرمزية اسلام الكبير
    رائع جدا يا اخى
    محمد فارس عمر
    محمد فارس عمر غير متواجد حالياً
    والله معلم
    fmharfoush
    fmharfoush غير متواجد حالياً
    الصورة الرمزية fmharfoush
    مشــــــــــــــــــــــــــــــــــــــــــــــــ كور
    احمد محمد نجيب
    احمد محمد نجيب غير متواجد حالياً
    الصورة الرمزية احمد محمد نجيب
    Given: 6
    سكرا جزيلا وجزاك الله خيرا وفيرا
    nageeb
    شمس سالم
    شمس سالم غير متواجد حالياً
    شكرا جزيلا ووفقك الله دوما
