original cfd fluent tutorial with source code files
النتائج 1 إلى 5 من 5
    سعا
    سعا غير متواجد حالياً
    Tutorial 1. Introduction to Using FLUENT: Fluid Flow and Heat Transfer in a Mixing Elbow
    Tutorial 2. Modeling Periodic Flow and Heat Transfer
    Tutorial 3. Modeling External Compressible Flow
    Tutorial 4. Modeling Unsteady Compressible Flow
    Tutorial 5. Modeling Radiation and Natural Convection
    Tutorial 6. Using a Non-Conformal Mesh
    Tutorial 7. Modeling Flow Through Porous Media
    Tutorial 8. Using a Single Rotating Reference Frame
    Tutorial 9. Using Multiple Rotating Reference Frames
    Tutorial 10. Using the Mixing Plane Model
    Tutorial 11. Using Sliding Meshes
    Tutorial 12. Using Dynamic Meshes
    Tutorial 13. Modeling Species Transport and Gaseous Combustion
    Tutorial 14. Using the Non-Premixed Combustion Model
    Tutorial 15. Modeling Surface Chemistry
    Tutorial 16. Modeling Evaporating Liquid Spray
    Tutorial 17. Using the VOF Model
    Tutorial 18. Modeling Cavitation
    Tutorial 19. Using the Mixture and Eulerian Multiphase Models
    Tutorial 20. Using the Eulerian Multiphase Model for Granular Flow
    Tutorial 21. Modeling Solidification
    Tutorial 22. Using the Eulerian Granular Multiphase Model with Heat Transfer
    Tutorial 23. Postprocessing
    Tutorial 24. Turbo Postprocessing
    Tutorial 25. Parallel Processing
    download
    http://rapidshare.com/files/142219394/tut01-Introduction-.rar
    http://rapidshare.com/files/142219295/introduction.zip
    http://rapidshare.com/files/142219543/tut02-periodic_flow_heat-.rar
    http://rapidshare.com/files/142219415/periodic_flow_heat.zip
    http://rapidshare.com/files/142219690/tut03-external_compressible-.pdf
    http://rapidshare.com/files/142219648/external_compressible.zip
    http://rapidshare.com/files/142219875/tut04-unsteady_compressible.rar
    http://rapidshare.com/files/142220530/unsteady_compressible.zip
    http://rapidshare.com/files/142220579/tut05-radiation_natural_convection.pdf
    http://rapidshare.com/files/142220662/radiation_natural_convection.zip
    http://rapidshare.com/files/142221031/tut06-non_conformal_mesh.pdf
    http://rapidshare.com/files/142220963/non_conformal_mesh.zip
    http://rapidshare.com/files/142221174/tut07-porous.pdf
    http://rapidshare.com/files/142221143/porous.zip
    http://rapidshare.com/files/142221221/tut08-single_rotating.pdf
    http://rapidshare.com/files/142221205/single_rotating.zip
    http://rapidshare.com/files/142221288/tut09-multiple_rotating.pdf
    http://rapidshare.com/files/142221254/multiple_rotating.zip
    http://rapidshare.com/files/142221706/tut10-mixing_plane.pdf
    http://rapidshare.com/files/142221612/mixing_plane.zip
    http://rapidshare.com/files/142221865/tut11-sliding_mesh.pdf
    http://rapidshare.com/files/142221832/sliding_mesh.zip
    http://rapidshare.com/files/142222081/tut12-dynamic_mesh.pdf
    http://rapidshare.com/files/142222053/dynamic_mesh.zip
    http://rapidshare.com/files/142222226/tut13-species_transport.pdf
    http://rapidshare.com/files/142222133/species_transport.zip
    http://rapidshare.com/files/142222440/tut14-non_premixed_combustion.pdf
    http://rapidshare.com/files/142222393/non_premix_combustion.zip
    http://rapidshare.com/files/142222834/tut15-surface_chem.pdf
    http://rapidshare.com/files/142222803/surface_chem.zip
    http://rapidshare.com/files/142223097/tut16-evaporate_liquid.pdf
    http://rapidshare.com/files/142223029/evaporate_liquid.zip
    http://rapidshare.com/files/142223143/tut18-cavitation.pdf
    http://rapidshare.com/files/142223105/cavitation.zip
    http://rapidshare.com/files/142223961/tut19-mix_eulerian_multiphase.pdf
    http://rapidshare.com/files/142223924/mix_eulerian_multiphase.zip
    http://rapidshare.com/files/142224062/tut20-eulerian_multiphase_granular.pdf
    http://rapidshare.com/files/142223997/eulerian_multiphase_granular.zip
    http://rapidshare.com/files/142224145/tut21-solidification.pdf
    http://rapidshare.com/files/142224090/solidification.zip
    http://rapidshare.com/files/142224271/tut22-eulerian_granular_heat.pdf
    http://rapidshare.com/files/142224248/eulerian_granular_heat.zip
    http://rapidshare.com/files/142224613/tut23-postprocess.pdf
    http://rapidshare.com/files/142224385/postprocess.zip
    http://rapidshare.com/files/142225654/tut24-turbo_postprocess.pdf
    http://rapidshare.com/files/142225512/turbo_postprocess.zip
    http://rapidshare.com/files/142225869/tut25-parallel_process.pdf
    http://rapidshare.com/files/142225811/parallel_process.zip
    من مواضيع سعا :
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    جزاك الله خيرا كان من الافضل تفعيل الروابط بدل ما نقوم نحن بعمل كوبى بست لكل رابط
    amanj
    amanj غير متواجد حالياً
    domoo3fr7
    domoo3fr7 غير متواجد حالياً
    لو سمحت اخي العزيز هل يوجد عندك modeling PEM fuel cell
    sami aslan
    sami aslan غير متواجد حالياً
    اخي العزيز لم استطيع ان استرجع اي من الملفات فاذا كانت لديك tut22 ارسالها الى بريدي الاكتروني
    [email protected] مع الشكر الجزيل مقدما
    سامي
