Power Plant Maintenance Mechanic
النتائج 1 إلى 5 من 5
    م.تركي الصاعدي
    م.تركي الصاعدي غير متواجد حالياً
    POWER PLANT MAINTENANCE MECHANICDEFINITION:
    Under general supervision, perform maintenance and repairs on plant facilities and equipment.
    EXAMPLES OF DUTIES:
    NOTE: The following are the duties performed by the employees in this classification. However,
    employees may perform other related duties. The duties listed are not necessarily performed by each
    individual in the classification:
    1. Service and maintain plant equipment.
    Measures: Work is performed accurately, safely, and within prescribed timeframes. Follows
    vendor recommendations and established procedures.
    2. Perform routine maintenance duties, including the collection of trending information for the
    Power Plant Supervisor.
    Measures: Routine maintenance is performed as required. Data is collected and reported to the
    Maintenance Supervisor as requested.
    3. Keep track of spare parts as they are used and complete usage report.
    Measures: Records are accurately maintained and proper forms are completed so that
    replacement items can be ordered.
    4. Keep abreast of revisions to the maintenance manual.
    Measures: Keeps up-to-date on revisions. Vendor maintenance and repair manuals are
    returned to the proper location after use.
    5. Assist in the maintenance of plant operating manuals, technical references, prints and diagrams,
    and preventive/predictive maintenance records.
    Measures: Manuals are maintained and updated as required.
    6. Set up and operate lathes, drill presses, and other machine tools in the performance of all
    machine work to close tolerances.
    Measures: Set up and operations are performed in a safe and efficient manner. Work is
    completed within established timeline. Work is accurate.
    7. Inspect and repair all turbines, heat exchangers, pumps, fans, and similar equipment.
    Measures: Equipment is appropriately inspected and repaired as required.
    8. Dismantle and reassemble combustion and steam turbine generators during inspection.
    Measures: Equipment is accurately dismantled and reassembled. Work is completed within
    required timeline.
    9. Scrape, fit, and adjust all bearings where precision fit and adjustments are required.
    Measures: Work is accurately and safely completed and within required timeline.
    10. Align and balance rotating equipment.
    11. Machine, fit, and install such parts as turbine blades, turbine packing and couplings.
    12. Reseat high pressure valves in place.
    13. Inspect and repair steam generating equipment and associated apparatus.
    14. Assemble and repair piping, valves, and fittings subjected to both high and low temperature or
    high and low pressure, or where certified welding is required.
    15. Check boilers under hydrostatic test.
    16. Assemble, disassemble, repair, and adjust all types of equipment.
    17. Analyze, check, test, and repair lighting, signal, and simple control circuits and associated
    equipment.
    18. Install and repair all types of thermal insulation, paint equipment, buildings, and structures.
    19. Perform other related duties as assigned.
    QUALIFICATIONS:
    Knowledge of:
    Thorough knowledge of power plant equipment; equipment maintenance and repair; welding; and
    basic mathematics.
    Ability to:
    Interact effectively with the public and employees; understand procedures and instructions specific
    to area of assignment; read and understand maintenance manuals, technical references, prints, and
    diagrams and preventive/predictive maintenance records; operate lathes, drill presses, and other
    machine tools; prepare and maintain records or reports; and perform shiftwork, overtime, or
    weekend work.
    Education:
    Any combination of training and experience that provides the required knowledge, skills, and
    abilities is qualifying; typical education would include a high school diploma, or equivalent.
    Experience:
    Typical experience would include years three years of journey level experience in industrial or
    power plant maintenance.
    Special Requirements:
    Possession of a valid California driver's license, or the ability to acquire one within ten days of
    appointment.
    Welding Certification may be required
    من مواضيع م.تركي الصاعدي :
    وعن أبي أمامة -رضي الله عنه- قال: قال رسول الله -صلى الله عليه وسلم-: ( من قرأ آية الكرسي دبر كل صلاة مكتوبة لم يمنعه من دخول الجنة إلا الموت) رواه النسائي وصححه ابن حبان .
    جابر كريم الشمري
    جابر كريم الشمري غير متواجد حالياً
    الاخ Tnt تحية طيبة
    اخي العزيز هذا اعلان عن وظيفة شاغرة وليست مواصفات فنية ممكن الاستفادة منها والغاية في هذا المنتدى نشر العلم والمعرفة وليس نسخ ولصق اعلانات وظيفية وعدم التمييز بينها ونرجوا من ادارة المنتدى الانتباه لهذه الظاهرة ومعالجتها قبل نشر الاعلان او وضع اي مادة علمية بدون معرفة محتواها وشكرا
    tariqsamer
    tariqsamer غير متواجد حالياً
    الصورة الرمزية tariqsamer
    thanks but what you want from this subject it is not clear
    حديد سابك
    حديد سابك غير متواجد حالياً
    الصورة الرمزية حديد سابك
    تحياتي........
    م.تركي الصاعدي
    شكرا على التعقيب .......
