Blumentals Software Collection
حصريا لاصحاب المواقع اليكم هذه التجميعة
من البرامج الرهيبة لاهم اللغات
HTMLPad 2007 - is a powerful and multifunctional editor HTML, XHTML, CSS, PHP, VBScript, ASP, SSI, Perl with syntax highlighting and preview. Contains great help system on the topics: "The basic HTML tags," "Description of CSS and numerous options greatly facilitate users to work with documents. Multiple text, HTML editor and editor for programmers with many useful options: creating a new file on the selected pattern - Journal open files with customized number - Opening documents in the proper encoding - Ability to "drag and drop" files to be opened from a conductor - Conservation and copies of all open File one stroke - The list of open files as tabs, and very many others, including syntax 10 languages, the existence of the preset configuration files and html tags along with certificates for their use and functions of Visual Basic and FileSystemObject, opportunities for recoding text search and replace, undo / redo, etc. etc.
Rapid CSS - editor, which allows quick and easy to create and edit CSS files of any complexity. Rapid CSS will easily modify and create cascading stylesheets (CSS). There is a preview window. Code such tables do not necessarily gain manually - in most cases fit specially harvested patterns. The result of the work can be estimated by using the preview.
Rapid PHP - a full and rapid editor PHP, the possibility of which went far beyond the customary PHP environment editor. Convenient allow you to create and edit not only PHP, but also HTML, XHTML, CSS and JavaScript code, while integrated tools allow you to easily check multiple use, and navigate format your code. No matter whether you are a professional developer or simply enthusiast, with Rapid PHP editor you will be able to accomplish the required task faster, save time and increase productivity. Functions include podstvetku syntax, code examples, tips PHP-functions, search and replace, ftp client, and more.
There is a great number of tools to verify the correctness of the code, comfortable navigating the code formatting, etc.
Main Features Editor:
-- PHP syntax, HTML, CSS, JavaScript, WML, XML and SQL,
-- Support for Unicode UTF-8,
-- navigation code using Code Explorer 'and,
-- tooltips on parameters PHP-functions
-- checking on the validity of code,
-- preservation and opening files directly on ftp,
-- embedded SQL browser.
