Oasys Compos v8.0|9.3MB
Analysis and design of studded composite beams
Compos gives you so much more:
>>Analysis and design of composite steel beams, including automatic beam and stud selection
>>Tapering plate girders
>>Variable slab widths and thicknesses
>>Web penetrations and notches, with or without stiffeners
>>Design to ultimate and serviceability limit states, such as vibration frequency, deflection, beam weight and depth
>>Link beams together, so that secondary beams load primary ones
>>Footfall induced vibration checks - calculate the >>Response Factor
>>Analyse the effects of using the Resotec Damping >>System from Richard Lees Steel Decking. No other program gives you this.
>>Compos just got even better.
What makes Compos so unique?
Footfall induced vibration checks - calculate the Response Factor
Resotec - analyse the effects of using Richard Lees damping system.
