تم افتتاح مركز رفع الملفات للأعضاء من جديد ..  و نعتذر عن عدم إمكانية دمج المركز السابق مع المركز الحالي لرفع الملفات ........ ( إدارة الملتقى )
العودة   ملتقى المهندسين العرب > الملتقى الهندسي > هندسة الطيران
هندسة الطيران ................ بإشراف : جاسر, م/ مصطفي, م المصري
قديم 02-11-2005, 09:36 AM
aerospace engineer يستحق التميز
لماذا تطير الطيور بشكل ال V
Most of us have probably seen large groups of migrating birds like geese or ducks flying in formation. These large groups of birds are particularly common in late autumn and early winter when birds migrate from their summer homes in Canada to the warmer climate of the southern United States. Such groups of birds will typically fly in a large "V" shape with one bird in the lead and others trailing behind in two lines.
Snow geese flying in formation
Scientists who have studied formation flight believe that birds fly in this way for two reasons. The first reason is that the shape of the formation reduces the drag force that each bird experiences compared to if it were flying alone. This decrease in drag occurs thanks to the formation of wingtip vortices .
Creation of trailing vortices due to a difference in pressure above and below a lifting surface
These vortices are generally undesirable because they create a downwash that increases the induced drag on a wing in flight. However, this downwash is also accompanied by an upwash that can be beneficial to a second wing flying behind and slightly above the first.
Regions of upwash and downwash created by trailing vortices
A bird flying in one of these upwash regions essentially gains free lift so that it can fly at a lower angle of attack. As angle of attack is reduced, the induced drag is also lowered so that the bird does not need to flap its wings as hard or as often to generate the thrust needed for forward flight. Flapping the wings less often means that the bird's muscles do not work as hard and its heart rate drops. As a result, the bird does not tire as quickly and is able to fly farther.
Researchers explored this theory by monitoring pelican heartbeats during flight. Examination of the data showed that the heart rates of pelicans flying in formation were much lower than that of a bird flying alone. Other studies have estimated that a flock of 25 birds in formation can fly as much as 70% further than a solo bird using the same amount of energy.
Theoretical investigations further support these observations of birds in formation flight. By spacing themselves apart properly, birds can achieve optimum positions that reduce the drag of every bird in the formation. However, not all birds benefit equally. Your speculation about the lead bird being in the best position is actually incorrect. This bird has to work the hardest since it flies into undisturbed air. The upwash that this bird creates improves the aerodynamics of the two behind it, and these two further improve conditions for the next two birds in line.
Reduction in induced drag for birds in formation
The majority of the benefit goes to the birds further aft, but the front bird does still gain some reduction in drag. The presence of the two birds flanking the leader helps to dissipate the downwash off the lead bird's wingtips and reduces the induced drag this bird experiences. These two flanking birds also benefit from a similar reduction in drag if outboard birds flank them as well. In other words, the birds in the middle of each of the lines forming the V are in the best position. These birds benefit from the upwash off the lead birds as well as off the trailing birds. This additional bonus means that birds in the middle experience less drag than either the lead bird or the bird at the end of each line.
An optimal V-formation
Even though the V formation benefits all of the birds, the bird in the lead position has to work the hardest. When this bird tires, it will drop out of the lead position and fall further back into one of the lines of the V. Another bird from further back will rapidly move forward to take the leading position and maintain the formation. The two birds in the furthest trailing positions also tire more rapidly than those in the middle, so these positions are also rotated frequently to spread the most fatiguing locations throughout the flock. This cyclical rearrangement gives all birds the responsibility of being the leader as well as a chance to enjoy the maximum benefits of being in the middle of the formation. This sense of teamwork comes naturally since even the youngest members of the flock rapidly realize that it takes less work to fly in a V formation than it does to fly alone.
Another theory as to why birds fly in formation is that this orientation allows the birds to communicate more easily. The V formation provides the birds with good visual contact of each other to keep the flock together. This communication minimizes the possibility of losing birds along the way as the formation crosses vast distances during migration.
Although manned aircraft can also exploit the benefits of formation flight, it is difficult to do so since we still lag behind nature in the ability of our technology to "feel" the air and adapt to it for optimum performance. Close formation flight among a group of aircraft is often difficult to maintain because of the turbulence created by the lead aircraft. Perhaps one day we will be able to develop advanced technologies that make aircraft as sensitive to their surroundings as the body of a bird is today. We may then be able to make better use of formation flight to improve the efficiency of flying vehicles.
Military aircraft flying in a V-formation
However, military planes do still operate in V formations, but they are typically spaced too far apart to enjoy the benefits of reduced drag. These aircraft instead fly in formation primarily to maintain visibility of all the aircraft in the squadron in the same way that birds do.
التعديل الأخير تم بواسطة aerospace engineer ; 02-11-2005 الساعة 09:42 AM.
رد مع اقتباس
  #2 (permalink)
قديم 04-11-2005, 01:52 AM
مشرف الهندسة الميكانيكيه
أبـو عمـــر يستحق التميز
كلام جميل .... ولــكن إذا كان طيران السرب أو المجموعة في خط مستقيم بحيث يكون العنصر الاول أو قائد السرب الذي في المقدمة هو من يقاوم معظم التيارات الهوائية .....
ألــــــن تكون مقاومة الهواء بالنسبة للمجموعة الباقية ( تشكيلة الخط المستقيم ) أقل منها في تشكيل V ؟؟؟؟؟؟ أم السبب في ذلك يرجع لعملية turbulence
هذا الموضوع ذو شجون بالنسبة لي ... وخاصة أنه متعلق بتصميم الأنصال الحديدية Baldes الموجودة في الضاغط والتربينة بمحرك الطائرة ( التربينة البخارية ) Gas Turbine
واستخدام طريقة الزوبعة ( إن صح الإسم ) Vortex في تصميم هذه الانصال .
أشكر الأخت مهندسة الفضـــاء جزيل الشكر على الموضوع ......
أمنياتي للجميع بالتوفيـــــق والنجاح
أخوكم
أبو عمــــــر
رد مع اقتباس
  #3 (permalink)
قديم 04-11-2005, 10:56 AM
الصورة الرمزية مهاجر
مشرف عام
معدل تقييم المستوى: 53
مهاجر يستحق التميز
Arrow كيف الحااااال
أبو عمر ردك لا يدل على عمل الفريق بروح الفريق الواحد.....
أشكر طارح الموضوع ولقد كان هذا الموضوع أحد أسئلة موضوع [glint]تعليم التخصص الهندسي لغير المتخصصين >>> سؤال وجواب ومنافسة [/glint]
أدعوكم لمشاهدة الردود 26 - 27 - 29 على الرابط التالي:
http://www.arab-eng.org/vb/showthrea...4&page=2&pp=15
رد مع اقتباس
  #4 (permalink)
قديم 04-11-2005, 11:53 AM
اقتباس:
شكرا لك االزميل أبو عمر على السؤال, سأحاول اجابة السؤال حسب فهمي له,
لو كان في تيار او ما شابه لاحظ ان كل الطيور التي في السرب ستتعرض له - ربما هذا يعتمد على اتجاه التيار, و لكن لو اخذنا تيار من الامام, الكل راح يكون في الواجهه سواء القائد او الاخرين- و لكن بم ان الطيور التي تشكل الاضلع او الخط المستقيم تكسب قوة رفع اضافية من الزوبعة, فقد تكون مقاومتها بالعكس اكبر من القائد. يعني القائد هو الذي لا زال يبلغ الجهد الاضافي اما بقية السرب جهدها لا زال اقل في مقاومة التيارات.
ارحب باي مداخلات اخرى او تصحيح معلومات.
رد مع اقتباس
  #5 (permalink)
قديم 04-11-2005, 12:01 PM
شكرا لكك الزميل مهاجر على هذا التنويه
رد مع اقتباس
  #6 (permalink)
قديم 06-11-2005, 11:40 AM
الصورة الرمزية جاسر
مشرف عام
جاسر يستحق التميز
السلام عليكم ورحمة الله وبركاته,,
جزاك الله خير, وحقيقة ما يعجبني في مجال الطيران أنه يحاكي خلقة الله في الطيور
فكلما تأملت جزئية معينة في الطائرة تجدها قريبة أو متطابقة المبدأ في ما يماثلها عند
الطيور.
وأحب أشارك بهذا
1. الزوبعة ( turbulence ) تقلل الاحتكاك, ولكن ينهار عندها قوى الرفع حول
الجناح. وهي مفيدةٌ في سباق السيارات مثلاً فالسيارة التي تقاد خلف أخرى حالتها
أسهل وأقل استهلاكاً للوقود, كذلك التجاويف في كرة التنس لتقليل الاحتكاك.
ولكن حول مقطع الجناح الحال يختلف تماماً فلا قوة ترفع الجناح الا بسيران التيار
حول معظم سطح الجناح والزوبعة تقلل المساحة الفعال في الجناح.
2. خلف الطائرة (مباشرة) تتكون منطقة تخلخل boundary layer , وهي بلا شك غير مفيدة للجناح وقد
ينهار ويسقط! ومن المحظور أن يقترب قائد الطائرة الصغيرة خلف طائرة كبيرة (مباشرة)
لأنه سيفقد السيطرة ويفقد السيطرة لأنه فقد قوى الرفع وفقدها قوى الرفع لأنه فقد مساحة كبيرة من الجناح لأن الهواء لم يسري بانتظام حول الجناح!
3. وحسب ما وضحت المهندسة الطيور المهاجرة لا تطير خلف الطائر القائد مباشرة بل على الجانين يميناً وشمالاً حيث هناك تيارات (وليس زوبعة) صاعدة upwash وفي الوسط هناك تيارات - هابطة-! أي أنها منطقة لا تساعد بل على العكس - الصورة الثالثة واضحه -
الخلاصة
الـ turbulence مفيدة إذا كان مصدر الحركة غير التيار (السيارة الخ)
وغير مفيده (وتودي في داهية) إذا كان مصدر الحركة هو التيار ذاته (الطائرة)
شكراً لكم ودمتم بخيرٍ
لا إله إلا أنت سبحانك إني كنت من الظالمين
رد مع اقتباس
  #7 (permalink)
قديم 23-11-2005, 01:12 PM
نغم الدموع يستحق التميز
hello
thanks for the wonderfull subject
we look for more
nagam
رد مع اقتباس
  #8 (permalink)
قديم 23-11-2005, 11:23 PM
وجدي_1405 يستحق التميز
السلام عليكم ورحمه الله و بركاته ..............بعد التحيه
جزاك الله الف خير على هذه المعلومه و التنويه
ترى هذه اول مره اشارك فيها
رد مع اقتباس
  #9 (permalink)
قديم 01-01-2006, 04:28 PM
kamaljaber يستحق التميز
thanks for the info
رد مع اقتباس
  #10 (permalink)
قديم 11-12-2007, 10:27 PM
الصورة الرمزية م المصري
مشرف قسم الطيران + E
م المصري يستحق التميز
موضوع جميل جدا ....
بارك الله في كل من شارك ....
رد مع اقتباس
مواقع النشر (المفضلة)
الساعة الآن 09:21 AM.
