نظرا لانتشار البلاطات المجهدة Pre-Tension Concrete Slab وكثرة الاسئلة في هذا الموضوع سأبدأ باذن الله بطرح هذا الموضوع وسيقسم كما يلي
1- مرحلة التصميم
2- مرحلة التنفيذ
وفي هذه المشاركة سأبدأ في مرحلة التصميم
هناك العديد من البرامج التي تستخجم في تصميم pre tension concrete ومن اشهر هذه البرامج برنامج ADAPT وهذا البرنامج من عددة اجزاء
STANDARD BUILDING DESIGN
Industry proven analysis and design software for concrete floor systems and beams using the Equivalent Frame Method of design
ADAPT -PT
ADAPT - RC
ADAPT - PULT
ADAPT - FELT
3D FEM BUILDING DESIGN
Integrated 3D modeling and design of RC or post-tensioned concrete
structures using Finite Elements and BIM Technology
ADAPT - Modeler
ADAPT - Floor Pro
ADAPT - SOG
ADAPT - MAT
BRIDGE DESIGN
State-of-the-art analysis and design of segmentally constructed bridges and building frames using time-dependent Finite Element Method
ADAPT - ABI
وسيتم شرح كل برنامج بشيء من التفصيل
ADAPT-PT v8
Advanced Post-Tensioning Software for Beam Frames, Slabs and Floor Systems in Buildings and Parking Structures
This software is based on the proven Equivalent Frame Technology and features the following modeling, analysis and design capabilities: Modeling Capabilities
Project parameters entered using easy to learn and use design wizard
Bonded (grouted) and unbonded post-tensioning
One-way and two-way floor systems and beam frames
Multiple beam cross-sections: rectangular, T, L and I
Drop caps, drop panels, steps above and below the slab
3D solid model viewer for visual verification of input geometry
Imports input data for design strip from ADAPT-Builder suite of programs
Analysis Capabilities
Equivalent frame or simple frame method of analysis
Allowance for cracking in deflection calculation of beams and one-way slab systems
Calculation of long-term losses due to creep, shrinkage, and relaxation in prestressing
Friction and elongation calculations
Design and Automatic Code Checks
Automatically generates first-pass post-tensioning design optimized for:
User-specified range of precompression
Allowable tensile and compression stress limits
User-specified range of dead load balancing
Interactive design summary page (Recycle Window) gives overview of analysis results and allows for rapid optimization
Graphical display of tendon profile eliminates errors while editing post-tensioning
Graphical display of stress levels against user specified stress limits while editing post-tensioning allows the user to immediately see the effects of the changes on the design!
Beam shear and punching shear checks
Reinforcement check for strength and minimum requirements of the code
Design of reinforcement for lateral load cases
Output and Reports
A graphical display of the structural model and tendon profile
Graphical and tabular display of location, length and amount of required reinforcement
Codes
The program comes supports the following design codes:
ACI-318 (1999 and 2005)
IBC (International Building Code) 2003
British-BS8110 (1997)
Canadian-A23.3 (1994)
Canadian-A23.3 (2004) - New
Australian-AS3600 (2001)
Brazilian-NBR6118 (2001)
Indian IS456 (2005 reprint) - New
European EC2 (2004) - New
Units
The program supports the following units:
SI
MKS
ADAPT-PT
is the industry standard stand-alone program for the
design of beam frames, slabs and floor systems post-tensioned with either bonded, or unbonded tendons. For two-way floor systems the user can base the analysis on either the Equivalent Frame Method, or the Simple Frame Method. For the post-tensioning design, the user can select between the Effective Force method and the Variable Force (Tendon Selection) method. In the Variable Force method, the software computes and accounts for the tendons' friction and long-term stress losses along the length of the post-tensioned member. ADAPT-PT can handles drop caps, drop panels, steps above and below, transverse beams and non-prismatic sections. Selfweight is calculated using actual dimensions and material properties. In addition to the post-tensioning amount and profile, the software reports the location and amount of the nonprestressed steel along the length of the structure for the strength and minimum requirements. The solution is presented in a clear and concise tabular form, as well as in graphical format.
Output options also include a graphical summary report of all important design data, ready for transfer to structural drawings and inclusion in structural calculations. The graphical summary includes:
Elevation of the member with the post-tensioning tendons in place
The post-tensioning profile, elevation of control points and PT-force/number of strands
Location, length and number of nonprestressed bars required over the entire member length
Outcome of the one-way or punching shear design
Designer's comments
DXF output
Flexibility in selection of cross-sectional geometry makes this software suitable for design of box girder bridges, and I-girders in addition to traditional building and parking structures. ADAPT-PT is fast, easy to master, and is the choice of production-oriented consulting engineers around the world.
ADAPT-PT
ADAPT-PT is a stand-alone program. But, when used together with ADAPT-Builder, it can receive input data generated graphically in Builder's 3D Modeling environment.
View Demo
http://www.adaptsoft.com/movies/ptv8_release.html http://www.adaptsoft.com/resources/A...gn_process.pdf http://www.adaptsoft.com/resources/A...tic_design.pdf http://www.adaptsoft.com/resources/A...tic_design.pdf http://www.adaptsoft.com/resources/A...gn_process.pdf هذا الموضوع منقول من موقع البرنامج
والى اللقاء في مشاركات قادمة
م. رزق حجاوي
