النتائج 1 إلى 2 من 2
    Hydraulic System Troubleshooting
    Problem 3: The pump output is low. Probable causes:
    1. The oil level is low.
    2. The viscosity of the oil is incorrect.
    3. The pump has too much wear. Problem 4: The oil pressure is low. Probable causes:
    1. The main relief valve opens at low oil pressure.
    2. The pump has too much wear.
    3. An O-ring seal in the system failed.
    4. The control valve and the valve spool have excessive wear.
    Problem 5: The work tool moves while the control lever is in the HOLD position. Probable causes:
    1. The control valve and the valve spool have excessive wear.
    2. A piston seal in a cylinder has excessive wear.
    3. There is a leak in a connection between the control valve and the cylinder that is drifting.
    4. A check valve is not closing because of dirt or because of a worn seat.
    5. The control valve is not centering correctly.
    6. There may be dirt or the return spring may be broken.
    7. The lever position sensor is not functioning properly.
    8. One of the lever position sensors has moved since the last calibration.
    9. One of the lever position sensors needs to be recalibrated.
    10. The solenoid valve for the pilot hydraulics needs to be replaced.
    11. One of the lever position sensors needs to be replaced.
    Problem 6: The lift cylinder droops when the lift control lever is moved from the HOLD position to the RAISE position.
    Droop is an initial movement of the hydraulic cylinders. The movement is in the opposite direction that is commanded by the operator. The cylinders then move in the correct direction.
    Probable causes:
    1. The oil is too cold.
    2. The piston seals and/or the lift cylinders are worn.
    3. The load check valve is not closing because the spring is weak or broken or because there is dirt or debris in the check valve.
    Problem 7: The hydraulic force is too low when the lift control lever is moved to the RAISE position or to the LOWER position.
    Probable causes:
    1. The machine is being operated improperly.
    2. The pilot system pressure is too low.
    3. The modulation current to the solenoid is not correct.
    4. The lift position sensor is damaged or the sensor not calibrated properly.
    5. The relief valve setting for the ride control valve is too low while the ride control switch is ON.
    6. The main control valve is contaminated or damaged.
    7. The makeup valve is sticking.
    8. The main relief valve setting is too low.
    Problem 8: All implement functions are sluggish. Probable causes:
    2. The pump is worn or damaged.
    3. The implement electronic control module is not calibrated.
    4. The main relief valve setting is too low.
    5. The pressure reducing valve for pilot pressure is not functioning properly.
    6. The hydraulic system is contaminated.
    Problem 9: The implement functions are erratic or intermittent. Probable causes:
    2. There is air in the hydraulic oil.
    Note: A problem with air in the hydraulic oil must be corrected before the hydraulic system will operate at normal temperatures. There are two conditions that cause air to be in the hydraulic oil: Return oil is flowing into the hydraulic tank above the level of oil that is in the tank. There are leaks in the oil suction line between the pump and the tank.
    4. The implement electronic control module is not calibrated.
    7. The load check valve is not closing because the spring is weak or broken or because there is dirt or debris in the check valve.
    Problem 10: There is too much lift cylinder drift.
    Drift is a cylinder movement with the control lever or the joystick in the HOLD position.
    Probable causes:
    1. The modulation current to the solenoid is incorrect.
    2. The ride control valve is worn or damaged.
    3. The piston seals and/or the lift cylinders are worn.
    4. The components of the main control valve are worn or damaged.
    5. The load check valve is not closing because the spring is weak or broken, or because there is dirt or debris in the check valve.
    6. The lift lever sensor is not properly mounted. The lift lever sensor not calibrated properly.
    Problem 11: The hydraulic force is too low when the tilt control lever is moved to the TILT BACK position or to the DUMP position.
    Probable causes:
    2. The position sensor for the tilt control lever is sending an incorrect signal.
    3. The modulation current to the solenoid is incorrect.
    4. The pressure reducing valve for pilot pressure is not functioning properly.
    5. The settings of the line relief valves are too low.
    6. The piston seals and/or the tilt cylinder is worn.
    7. The main control valve is contaminated or damaged.
    8. The main relief setting is too low.
    Problem 12: The lift cylinders collapse during the raise operation.
    Cylinder collapse is the sudden drop during normal operation.
    Probable causes:
    1. The lift control lever and/or the position sensor may be worn or damaged.
    2. The modulation current to the solenoid is incorrect.
    3. The pressure reducing valve for pilot pressure is not functioning properly.
    4. The ride control valve may be worn or damaged.
    5. The nitrogen precharge pressure in the ride control valve is too low.
    6. The piston seals and/or the lift cylinders are worn.
    8. The makeup valve is sticking.
    9. The load check valve is not closing because the spring is weak or broken, or because there is dirt or debris in the check valve.
    Problem 13: There is low power to the implements. Probable causes:
    1. The machine is operating above the intended capacity.
    2. The engine power is too low.
    4. The modulation current to the solenoid is incorrect.
    5. The implement electronic control system is not calibrated correctly.
    6. The pressure reducing valve for pilot pressure has a low setting.
    7. The main relief valve setting is too low.
    8. The settings of the line relief valves are too low.
    9. The piston seals and/or the cylinders are worn.
    10. The load check valve is damaged or contaminated.
    11. A solenoid on the control valve group is not functioning properly.
    Problem 14: There is too much tilt cylinder drift.
    Drift is a cylinder movement with the control lever or joystick control in the HOLD position.
    Probable causes:
    2. The setting of the line relief valve is too low.
    3. The piston seals and/or the tilt cylinder is worn.
    5. The load check valve is contaminated or damaged.
    6. The tilt lever sensor is not properly mounted. The tilt lever sensor is not calibrated properly.
    Problem 15: The tilt cylinders collapse during the tilt function.
    Probable causes:
    2. The pressure setting of the line relief valve for the tilt cylinder is too low.
    4. There is dirt or debris in the main control valve.
    5. The main control valve spool and/or the mating surfaces may be worn or damaged.
    6. The makeup valve is sticking.
    Problem 16: The tilt cylinder droops during the tilt function.
    Probable causes:
    2. The piston seals and/or the tilt cylinder is worn.
    3. The load check valve is not closing because the spring is weak or broken, or because there is dirt or debris in the check valve.
    Problem 17: There is too much drift in the auxiliary cylinders.
    Drift is a cylinder movement with the control lever or the joystick control in the HOLD position.
    Probable causes:
    3. The piston seals and/or the auxiliary cylinders are worn.
    4. The load check valve is not closing because the spring is weak or broken, or because there is dirt or debris in the check valve.
    5. The main control valve is contaminated or damaged.
    6. The auxiliary lever sensor is not properly mounted. The auxiliary lever sensor is not calibrated properly.
    Problem 18: The auxiliary cylinders collapse during the auxiliary function.
    Probable causes:
    5. The main control valve spool and/or mating surfaces may be worn or damaged.
    Problem 19: The auxiliary cylinder droops during the auxiliary function.
    Probable causes:
    2. The piston seals and/or the auxiliary cylinders are worn.
    Problem 20: The hydraulic force is too low during auxiliary functions. Probable causes:
    1. The machine is being operated above the intended capacity.
    2. The position sensor for the auxiliary control lever needs to be recalibrated.
    3. The implement electronic control module is not calibrated correctly.
    5. The setting of the line relief valve is too low.
    6. The piston seals and/or the auxiliary cylinders are worn.
    7. The main control valve spool and/or the mating surfaces are worn or damaged.
    8. A solenoid valve for the pilot hydraulics is not functioning properly.
    Problem 21: One implement function is sluggish or nonfunctional. Probable causes:
    1. The position sensors for the control levers are sending an incorrect signal.
    3. The setting of the line relief valve is too low.
    4. The spool in the ride control valve and the mating surfaces are worn or damaged.
    5. The main control valve spool and/or the mating surfaces are worn or damaged.
    6. A solenoid valve for pilot pressure is sticking.
    7. A solenoid valve for pilot pressure is receiving low voltage.
    Problem 22: The implements are not functioning. Probable causes:
    1. The switch for the hydraulic lockout is in the LOCKED position.
    2. The hydraulic lockout valve for the pilot oil is not functioning properly.
    3. The element in a fuse has separated.
    4. The pump is worn or damaged.
    6. The main relief valve setting is too low.
    7. The implement electronic control module is not functioning properly.
    لرابط الموضع pdf
    http://ebiedyousif.net/vb/showthread.php?t=20
    لمتابعة المزيد
    بسم الله الرحمن الرحيم.
    السلام عليكم ورحمة الله وبركاته.
    جزاك الله كل الخير على مجهودك
