تم افتتاح مركز رفع الملفات للأعضاء من جديد ..  و نعتذر عن عدم إمكانية دمج المركز السابق مع المركز الحالي لرفع الملفات ........ ( إدارة الملتقى )
العودة   ملتقى المهندسين العرب > ملتقى البرامج و الانترنت و الكتب > المكتبه الهندسية Engineering ebook Library
المكتبه الهندسية Engineering ebook Library ................ بإشراف : محب الله ورسوله, نايف علي
قديم 10-05-2008, 06:02 PM
فلسطين والنضال يستحق التميز
مجموعة من الكتب في Java
Java Power Tools
By John Ferguson Smart
* Publisher: O’Reilly Media, Inc.
* Number Of Pages: 910
* Publication Date: 2008-04-22
* ISBN-10 / ASIN: 0596527934
* ISBN-13 / EAN: 9780596527938
* Binding: Paperback
All true craftsmen need the best tools to do their finest work, and programmers are no different. Java Power Tools delivers 30 open source tools designed to improve the development practices of Java developers in any size team or organization. Each chapter includes a series of short articles about one particular tool — whether it’s for build systems, version control, or other aspects of the development process — giving you the equivalent of 30 short reference books in one package.
No matter which development method your team chooses, whether it’s Agile, RUP, XP, SCRUM, or one of many others available, Java Power Tools provides practical techniques and tools to help you optimize the process. The book discusses key Java development problem areas and best practices, and focuses on open source tools that can help increase productivity in each area of the development cycle, including:
* Build tools including Ant and Maven 2
* Version control tools such as CVS and Subversion, the two most prominent open source tools
* Quality metrics tools that measure different aspects of code quality, including CheckStyle, PMD, FindBugs and Jupiter
* Technical documentation tools that can help you generate good technical documentation without spending too much effort writing and maintaining it
* Unit Testing tools including JUnit 4, TestNG, and the open source coverage tool Cobertura
* Integration, Load and Performance Testing to integrate performance tests into unit tests, load-test your application, and automatically test web services, Swing interfaces and web interfaces
* Issue management tools including Bugzilla and Trac
* Continuous Integration tools such as Continuum, Cruise Control, LuntBuild and Hudson
If you are a Java developer, these tools can help improve your development practices, and make your life easier in the process. Lead developers, software architects and people interested in the wider picture will be able to gather from these pages some useful ideas about improving your project infrastructure and best practices.
Download
Core Java, Vol. 2: Advanced Features, 8th Edition
By Cay S. Horstmann, Gary Cornell
* Publisher: Prentice Hall PTR
* Number Of Pages: 1056
* Publication Date: 2008-04-19
* ISBN-10 / ASIN: 0132354799
* ISBN-13 / EAN: 9780132354790
The revised edition of the classic Core Java™, Volume II–Advanced Features, covers advanced user-interface programming and the enterprise features of the Java SE 6 platform. Like Volume I (which covers the core language and library features), this volume has been updated for Java SE 6 and new coverage is highlighted throughout. All sample programs have been carefully crafted to illustrate the latest programming techniques, displaying best-practices solutions to the types of real-world problems professional developers encounter.
Volume II includes new sections on the StAX API, JDBC 4, compiler API, scripting framework, splash screen and tray APIs, and many other Java SE 6 enhancements. In this book, the authors focus on the more advanced features of the Java language, including complete coverage of
Streams and Files
Networking
Database programming
XML
JNDI and LDAP
Internationalization
Advanced GUI components
Java 2D and advanced AWT
JavaBeans
Security
RMI and Web services
Collections
Annotations
Native methods
For thorough coverage of Java fundamentals–including interfaces and inner classes, GUI programming with Swing, exception handling, generics, collections, and concurrency–look for the eighth edition of Core Java™, Volume I–Fundamentals (ISBN: 978-0-13-235476-9).
Download
Binildas A Christudas “Service-Oriented Java Business Integration”
Packt Publishing | 2008 | ISBN:1847194400 | 436 pages | PDF | 4 Mb
The book first discusses the various integration approaches available and introduces the Enterprise Service Bus, which is a new Architectural pattern that can facilitate integrating services. ESB provides different forms of mediation services including routing and transformation. Java Business Integration (JBI) provides a collaboration framework that provides standard interfaces for integration components and protocols to plug into, thus allowing the assembly of Service-Oriented Integration (SOI) frameworks following the ESB pattern. JBI is based on JSR 208, which is an extension of Java 2 Enterprise Edition (J2EE). Once JBI and ESB are introduced, we look at how we have been doing service integration without either of these using traditional J2EE. The book then slowly introduces ESB and, with the help of code, showcases how easily things can be done using JBI.
depositfiles.com
easy-share
JavaScript Design Patterns
Apress | 2008 | ISBN: 9781430204954 | 298 Pag. | PDF | 1.4 MB
How This Book Is Structured
This book is divided into two parts. Part 1 covers the basics of object-oriented JavaScript. The chapters are intended to be read sequentially. Each chapter builds on the one before it and assumes that you have read all preceding chapters. It is a good idea to read these chapters all the way through because the chapters in Part 2 use the techniques described in Part 1, in some cases without further explanations.
Part 2 covers specific design patterns and their practical applications in JavaScript. Each chapter can be read in whatever order you like. Some chapters reference other chapters, either in Part 1 or Part 2, but we always give the chapter number where more information can be found.
[RapidShare.com]
سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
رد مع اقتباس
  #2 (permalink)
قديم 10-05-2008, 06:03 PM
Computer Graphics Using Java 2D and 3D
By Y. Daniel Liang, Hong Zhang
* Number Of Pages: 632
* Publication Date: 2006-12-16
* ISBN-10 / ASIN: 0130351180
* ISBN-13 / EAN: 9780130351180
This Java handbook makes a practical tutorial on Java 2D and Java 3D for computer professionals. It contains in-depth coverage of basic computer graphics concepts and techniques, and introduces advanced graphic features to an audience mostly trained in the Java language. Chapter topics include mathematical background for computer graphics, .geometric transformation, views, lighting and texturing, behavior and interaction, and animation. For computer programmers and engineers, data analysts, graphic designers/animators, and game developers.
Download
http://rapidshare.com/files/63605353/Computer2006.rar
Advanced Programming for the Java 2 Platform
By Calvin Austin, Monica Pawlan
* Publisher: Addison Wesley Longman
* Number Of Pages: 400
* Publication Date: 2000-09-20
* ISBN-10 / ASIN: 0201715015
* ISBN-13 / EAN: 9780201715019
Summary: A good book with nice example
I like the ******* on Chapter 2 and 3 with good examples on EJBs, especially on CMP and BMP EntityBeans. It also has good coverage on the use of transaction management in both CMP and BMP environment. If you have fundamental JDBC/EJBs knowledge, you will enjoy reading this book.
Chapter 4 has good introduction on distributed computing regarding RMI/IIOP/Corba plus the JNDI object lookup and the sub-system data marshaling mechanism.
Finally, Chapter 7 and 8 provides some insight with regard to debugging and performance tuning that is quite helpful in Java programming.
Download
Java 2D Graphics
By Jonathan Knudsen
* Number Of Pages: 366
* Publication Date: 1999-05-05
* ISBN-10 / ASIN: 1565924843
* ISBN-13 / EAN: 9781565924840
Amazon.com:
Java 2D Graphics is a remarkably accessible guide to graphics programming using Sun’s new Java 2D API. Besides the basic navigation of the API, this title delivers plenty of useful advanced material for extending Java 2D’s capabilities.
After a simple introductory example, the book focuses on the graphics architecture of Java 2D and its rendering pipeline. Support classes in Java 2D receive ample coverage as well, with sections outlining topics like storing points, shapes, and paths. For basic graphics output, the book demonstrates the simple–which can be found in the process of drawing common shapes like lines, ellipses, and rectangles–as well as the complex seen in modifying graphics output through translating, rescaling, rotating, or shearing.
Text output in Java 2D receives its due as well, since the book acknowledges Java 2D’s advanced font capabilities that allow it to handle right-to-left languages such as Arabic. Further sections delve into Java 2D color models (including support for the CIEXYZ and sRGB color standards). Concerning the display of images, the book covers the built-in support for image filtering in Java 2D, which allows programmers to build toggles and fades into their code that alter brightness, contrast, blurring, and sharpening.
For advanced readers, Java 2D Graphics presents techniques like double buffering and matrix operations for custom image effects. Another expert section on the internal storage classes for image data will be useful for those who want to write image decoders. (A sample PNG decoder shows off the basics here.) Final sections look at printing, animation, and performance issues.
In all, Java 2D Graphics provides a fine introduction to the latest in 2-D graphics programming from Sun, in a title that will be useful to both beginning and advanced Java developers. –Richard Dragan
Download
XML and Java(TM): Developing Web Applications (2nd Edition)
By Hiroshi Maruyama, Kent Tamura, Naohiko Uramoto, Makoto Murata, Andy Clark, Yuichi Nakamura, Ryo Neyama, Kazuya Kosaka, Satoshi Hada
* Publisher: Addison-Wesley Professional
* Number Of Pages: 688
* Publication Date: 2002-05-23
* ISBN-10 / ASIN: 0201770040
* ISBN-13 / EAN: 9780201770049
Fully revised to cover the latest standards and technologies, XML and Java™, Second Edition provides the practical solutions developers need to design powerful and portable Web-based applications. Featuring step-by-step examples, this book focuses on harnessing the power of Java™ and XML together to streamline the development process.
XML and Java™, Second Edition provides new coverage of emerging areas such as document management, databases, messaging, servlets, JDBC, data binding, security, and more. It begins with an overview of XML programming techniques, standard APIs, and tools. Building upon this foundation, the book goes on to cover the latest technologies, including DOM Level 2, SAX2, XSLT, SOAP, WSDL, and UDDI. It explores the role of these major middleware technologies in XML and Java-based Web application development, as well as the limitations and potential pitfalls.
Topic coverage includes:
The role of XML and Java in Web applications
Parsing XML documents
How to use the Document Object Model (DOM) Level 1 and DOM Level 2 APIs
How to work with SAX
Techniques for making the most of existing XML processors
W3C XML Schema and OASIS RELAX NG
The XML application server, XML and databases, and XML messaging, including SOAP
Techniques for storing XML documents by using JDBC
Information on Web services, including WSDL and UDDI
How to represent data in XML (data binding)
Standard techniques for securing B2B applications
XML Schema languages
The accompanying CD-ROM contains ready-to-run sample programs along with trial versions of WebSphere and DB2.
Combining a team of experienced authors with a practical cookbook-style approach and packed with useful sample code, XML and Java™, Second Edition provides the most complete toolset available for developers navigating the next frontier of Web-based business applications.
رد مع اقتباس
  #3 (permalink)
قديم 10-05-2008, 06:05 PM
Beginning JavaScript, 3rd Edition (Programmer to Programmer)
By Paul Wilton, Jeremy McPeak
* Publisher: Wrox
* Number Of Pages: 767
* Publication Date: 2007-05-21
* ISBN-10 / ASIN: 0470051515
* ISBN-13 / EAN: 9780470051511
With this up-to-date guide, you’ll find everything you need to know in order to develop interactive, robust, and personalized pages using JavaScript. It takes you step by step through this powerful scripting language so you can begin enhancing your site right away and increase visits. You’ll learn how to take advantage of native JavaScript objects, manipulate objects that are available to you in the latest browsers, use cookies, and jazz up your web pages with Dynamic HTML.
Download
Eclipse Rich Client Platform: Designing, Coding, and Packaging Java(TM) Applications (The Eclipse Series)
By Jeff McAffer, Jean-Michel Lemieux
* Number Of Pages: 552
* Publication Date: 2005-10-21
* ISBN-10 / ASIN: 0321334612
* ISBN-13 / EAN: 9780321334619
Summary: Great, indispensable.
I couldn’t do my RCP application without this book. its example application goes growing showing everything we need to learn to make an RCP application.
Download
Complete Java 2 Certification Study Guide (3rd Edition)
By Philip Heller, Simon Roberts
* Publisher: Sybex Inc
* Number Of Pages: 814
* Publication Date: 2002-07
* ISBN-10 / ASIN: 0782140777
* ISBN-13 / EAN: 9780782140774
* Binding: Hardcover
Want to conquer two of the most difficult programmer certifications? The new edition of the best-selling Complete Java 2 Certification Study Guide is the resource you need. Authors Philip Heller and Simon Roberts, developers of Sun’s Programmer and Developer exams for the Java 2 Platform, give you everything you need to pass the exams the first time. This fully revised edition is updated for the changes in both exams, including coverage of new objectives for J2SE 1.4, a new emphasis on Swing and RMI, and information for tackling the new format of the Developer exam. The book is also enhanced with all-new features from Sybex’s market-leading Study Guides, including Exam Essential sections to reinforce key subject areas and real-world scenario sidebars with sample programming assignments. The companion CD contains all the review questions from the book, a practice programmer’s exam, and 150 random-test questions, including 100 new questions. The CD also includes a fully searchable electronic edition of the book.
Download
Password: none
Pro J2ME Polish: Open Source Wireless Java Tools Suite
By Robert Virkus
  • Publisher: Apress
  • Number Of Pages: 472
  • Publication Date: 2005-07-28
  • ISBN-10 / ASIN: 1590595033
  • ISBN-13 / EAN: 9781590595039
  • Binding: Hardcover
Pro J2ME Polish: Open Source Wireless Java Tools Suite is written for wireless and other mobile Java programmers who want to “polish” their efficiency and acquire in-depth knowledge about programming real-world J2ME applications. It also uncovers all common device limitations and quirks, and explains how these can be circumvented.
The book describes the Open Source tools collection, “J2ME Polish,” and shows how the tools can be used for creating professional J2ME applications. Building multiple devices and multiple locales is easy after studying this book. Author Robert Virkus offers tips about the more hidden features of J2ME Polish, like the logging framework, the preprocessor, and the game-engine. You will learn to polish up your applications with the powerful GUI that enables you to design standard J2ME applications with simple CSS text files. You’ll also learn to write portable, fast applications while using all available features on your target devices simultaneously.
Download
http://rapidshare.com/files/5146778/pro.j2me.polish_.open.source.wireless.java.tools.s uite-1590595033.rar
رد مع اقتباس
  #4 (permalink)
قديم 10-05-2008, 06:06 PM
Practical Ajax Projects with Java Technology (Practical)
By Frank Zammetti
* Publisher: Apress
* Number Of Pages: 528
* Publication Date: 2006-07-24
* ISBN-10 / ASIN: 1590596951
* ISBN-13 / EAN: 9781590596951
If you’re a Java developer already versed in Ajax-style programming, and you want to take your knowledge to the next level, then this is the book for you. Practical Ajax Projects with Java Technology provides the ultimate learn-by-example experience, featuring seven complete example applications for you to learn from and then adapt for use in your own projects. During each application, the author will lead you through the planning, design, and implementation stages.
The book begins with a few quick chapters to recap Ajax basics and build up a complete development environment, and then moves on to the applications. The seven applications are diverse: an auto-complete application, an Ajax game, a two-way chat application, a webmail client, an RSS aggregator, an online calendaring/scheduling system, and a Flickr-style photo gallery application. Technologies covered include Apache, Ant, Ajax Tags, Struts, Prototype, DWR, Dojo, and more. Overall, this book will save you countless hours of development time, and help further your Java Ajax knowledge!
  • Publisher: McGraw-Hill Osborne Media
  • Number Of Pages: 1184
  • Publication Date: 2002-08-13
  • ISBN-10 / ASIN: 0072224207
  • ISBN-13 / EAN: 9780072224207
  • Binding: Paperback
This book is the most complete and up-to-date resource on Java from programming guru, Herb Schildt — a must-have desk reference for every Java programmer.
Download
http://rapidshare.com/files/30293671/Java_2_Complete_Reference_5E.zip
Java Media APIs: Cross-Platform Imaging, Media and Visualization (Sams White Book)
By Alejandro Terrazas, John Ostuni, Michael Barlow
* Publisher: Sams
* Number Of Pages: 848
* Publication Date: 2002-12-06
* ISBN-10 / ASIN: 0672320940
* ISBN-13 / EAN: 9780672320941
Java Media APIs: Cross-Platform Imaging, Media, and Visualization presents integrated Java media solutions that demonstrate the best practices for using this diverse collection. According to Sun MicroSystems, “This set of APIs supports the integration of audio and video clips, animated presentations, 2D fonts, graphics, and images, as well as speech input/output and 3D models.” By presenting each API in the context of its appropriate use within an integrated media application, the authors both illustrate the potential of the APIs and offer the architectural guidance necessary to build compelling programs.
Download
http://rapidshare.com/files/2265106/javamedia.rar
Next Generation Java Testing: TestNG and Advanced Concepts
By Cédric Beust, Hani Suleiman
* Number Of Pages: 512
* Publication Date: 2007-10-25
* ISBN-10 / ASIN: 0321503104
* ISBN-13 / EAN: 9780321503107
Enterprise Java developers must achieve broader, deeper test coverage, going beyond unit testing to implement functional and integration testing with systematic acceptance. Next Generation Java™ Testing introduces breakthrough Java testing techniques and TestNG, a powerful open source Java testing platform.
Cédric Beust, TestNG’s creator, and leading Java developer Hani Suleiman, present powerful, flexible testing patterns that will work with virtually any testing tool, framework, or language. They show how to leverage key Java platform improvements designed to facilitate effective testing, such as dependency injection and mock objects. They also thoroughly introduce TestNG, demonstrating how it overcomes the limitations of older frameworks and enables new techniques, making it far easier to test today’s complex software systems.
Pragmatic and results-focused, Next Generation Java™ Testing will help Java developers build more robust code for today’s mission-critical environments.
This book
* Illuminates the tradeoffs associated with testing, so you can make better decisions about what and how to test
* Introduces TestNG, explains its goals and features, and shows how to apply them in real-world environments
* Shows how to integrate TestNG with your existing code, development frameworks, and software libraries
* Demonstrates how to test crucial code features, such as encapsulation, state sharing, scopes, and thread safety
* Shows how to test application elements, including JavaEE APIs, databases, Web pages, and XML files
* Presents advanced techniques: testing partial failures, factories, dependent testing, remote invocation, cluster-based test farms, and more
* Walks through installing and using TestNG plug-ins for Eclipse, and IDEA
* Contains extensive code examples
Whether you use TestNG, JUnit, or another testing framework, the testing design patterns presented in this book will show you how to improve your tests by giving you concrete advice on how to make your code and your design more testable.
Download
رد مع اقتباس
  #5 (permalink)
قديم 10-05-2008, 06:07 PM
  • Publisher: Prentice Hall
  • Number Of Pages: 1328
  • Publication Date: 2006-07-22
  • ISBN-10 / ASIN: 0132221586
  • ISBN-13 / EAN: 9780132221580
Now integrating Java 5 throughout, this reference introduces Java programming fundamentals – including problem-solving, object-oriented programming, GUI programming, data structures, networking, internationalization, advanced GUI programming, and Web programming. Includes many new illustrations. Enhances examples throughout, using small, simple, and stimulating examples to demonstrate concepts and techniques. Offers anearlier introduction to writing programs than the previous edition. Features a new chapter on recursion, expanding treatment from earlier editions. A useful reference for anyone interested in learning more about programming.
  • Publisher: Wordware Publishing, Inc.
  • Number Of Pages: 616
  • Publication Date: 2007-11-25
  • ISBN-10 / ASIN: 1598220330
  • ISBN-13 / EAN: 9781598220339
Advanced JavaScript 3rd Edition is an in-depth examination of the most important features of JavaScript. The book assumes readers have a basic understanding of web development, but includes a review of JavaScript fundamentals in Chapters 1 through 3. This book gives the reader a comprehensive look at the fundamentals of JavaScript by examining objects, arrays, date and time functions, math, and all the essentials that are needed for complex yet robust JavaScript scripts. Topics are thoroughly examined with several complete examples.
Download
http://rapidshare.com/files/75107787/1598220330.zip
رد مع اقتباس
  #6 (permalink)
قديم 10-05-2008, 06:08 PM
ارجو ان تنال اعجابكم
رد مع اقتباس
  #7 (permalink)
قديم 10-05-2008, 06:10 PM
TITLE : Bluetooth Application Programming with the Java APIs Essentials Edition (Paperback)
AUTHOR : by Timothy J. Thompson (Author), C Bala Kumar (Author), Paul Kline (Author)
PUBLISHER : Morgan Kaufmann publisher
ISBN : 0123743427
EDITION : 1st
PUB DATE : February 15, 2008
LANGUAGE : English
RLS DATE : 03/26/2008
[ R e l e a s e N o t e s ]
Adoption of Bluetooth wireless technology has become ubiquitous in the last few years. One of the biggest steps forward is the standardization of Java APIs for Bluetooth wireless technology (JABWT). The latest
updates to this standard is explained in detail in this book. The JABWT standard, defined by the JSR-82 Java Specification Request, supports rapid development of Bluetooth applications that are portable, secure,
and highly-usable. Wireless device manufacturers have responded overwhelmingly to the JABWT specification by implementing JABWT applications in mobile phones and other personal wireless communications products.
“Bluetooth Application Programming Essentials: Programming with the Java APIs” explains in detail how to write Bluetooth applications using the Java APIs to exploit the power of both technologies. Written by the
specification lead for JSR-82 and two other key participants in developing the standards of JABWT, this book provides the authoritative explanations and concrete examples needed to get started right away. This book provides embedded Java developers with to-the-point information on the APIs in the specification with detailed programmatic examples of the APIs in use. A NEW chapter on the Push Registry definition (a new feature in the 1.1 version of JSR-82) has been added. Finally, the new Essentials version of the book will update the remaining chapters to reflect changes in the latest Bluetooth spec (2.1) and the industry as a whole. As a bonus, this edition of the book offers over 200 pages of added ******* on the website. This “bonus material” includes complete source code from examples in the book, the javex.bluetooth code package, the java.obex code package, an enhanced set of “Example Applications”, and a tutorial on “Implementing JABWT on a Device.” These code-heavy sections are actually more effective in electronic format where the application can be easily downloaded. KEY FEATURES & BENEFITS
* By focusing only on the essentials, this concise resource enables software and hardware vendors to quickly develop Bluetooth applications for mobile devices in an increasingly competitive market.
* The updated material examines crucial programming areas (including RFCOMM, OBEX, device discovery, service discovery, and L2CAP), which allows developers to not only successfully design, but master and build Java APIs for Bluetooth Wireless Technology.
* Includes a new and valuable chapter that delineates the pivotal Push Registry feature ? a recent development that will help programmers avoid the common problem of connection collision.
* By providing real-world issues and problems involved in implementing the Java APIs specification, the book allows developers to identify with the text and encourages repeated reference.
URL: Code: http://www.amazon.com/exec/obidos/tg/detail/-/0123743427/ Download: rs
رد مع اقتباس
  #8 (permalink)
قديم 10-05-2008, 06:11 PM
The Complete Idiot’s Guide to Javascript (The Complete Idiot’s Guide)
By Aaron Weiss, Scott J. Walter
* Publisher: Que
* Number Of Pages: 316
* Publication Date: 1997-02
* ISBN-10 / ASIN: 0789711362
* ISBN-13 / EAN: 9780789711366
Ready to make your Web page rock? Then check out JavaScript. It’s the new scripting language everyone’s talking about. With JavaScript, you can build powerful applets that add pizzazz and interactivity to your site. To use this new language, you need the leader of the band, The Complete Idiot’s Guide to JavaScript, Second Edition.Its humorous approach to learning will have you writing JavaScript applets in no time. You’ll learn how to add multimedia, animation, sound, and more to your Web pages. But that’s not all. You’ll also get an insider’s view of the new features of JavaScript 1.1 and how they integrate with various Web browsers. So add some rhythm to your Web pages with the book that doesn’t miss a beat, The Complete Idiot’s Guide to JavaScript, Second Edition!
* Updated to cover the latest version of Netscape Navigator and Internet Explorer
http://mihd.net/9hkt36/__3527d3d__via_gigapedia.info__.html
رد مع اقتباس
  #9 (permalink)
قديم 13-05-2008, 11:49 PM
C Bala Kumar, Paul Kline, Tim Thompson “Bluetooth Application Programming with the Java APIs"
Morgan Kaufmann | 2003-09-17 | ISBN: 1558609342 | 498 pages | PDF | 2,7 Mb
Adoption of Bluetooth wireless technology has made great strides in the last few years. One of the biggest steps forwardthe standardization of Java APIs for Bluetooth wireless technology (JABWT)is explained in detail in this book. The JABWT standard, defined by the JSR-82 specification, supports rapid development of Bluetooth applications that are portable, secure, and highly-usable. Wireless device manufacturers have responded to the JABWT specification by announcing mobile phones and other products that will run JABWT applications. Bluetooth Application Programming with the Java APIs explains in detail how to write Bluetooth applications using the Java APIs to exploit the power of both technologies. Written by the specification lead for JSR-82 and two other key participants in the definition of JABWT, this book provides the authoritative explanations and concrete examples you need to get started right away.
depositfiles.com
easy-share
رد مع اقتباس
  #10 (permalink)
قديم 16-05-2008, 06:17 PM
وترقبوا المزيد
رد مع اقتباس
  #11 (permalink)
قديم 04-06-2008, 03:01 PM
Java in 60 Minutes A Day/by R. F. Raposa
Wiley; 1st edition | May (30, 2003) | PDF | 800pages | ISBN: 0471423149 | English | 7Mb
Description
*Shows readers how to use Java to harness the power of object-oriented programming
*Includes thirty one-hour lessons that recreate a typical week-long introductory seminar
*Focuses on the Java 2 Platform, Enterprise Edition (J2EE)
*Helps readers to develop skills that are critical to many Web services scenarios
*The author was one of the first Sun Certified Instructors and has since taught Java to thousands of developers
*Companion Web site features an online presentation by the author that follows along with each chapter and includes
an audio-only option for readers with dial-up Internet connection
download link7mb)
easy-share
or:
depositfiles
رد مع اقتباس
مواقع النشر (المفضلة)
الساعة الآن 08:57 AM.
