العودة   ملتقى المهندسين العرب - أول ملتقى هندسي عربي > ملتقى البرامج و الانترنت > ملتقى البرامج الهندسية
ملتقى البرامج الهندسية بإشراف : Mu7ammad
برامج رائعه لتصميم الهندسة المعمارية والصناعية مع الصور
بإشراف : Mu7ammad
قديم 24-06-2008, 01:51 PM   رقم المشاركة : [91 (permalink)]
الصورة الرمزية فلسطين والنضال
فلسطين والنضال يستحق التميز
IronCAD 10.0.7984 | 170 Mb
Utilizing a breakthrough approach to creative design, IronCAD is the productivity leader for moving creative ideas into 3D reality. IronCAD offers a level of design freedom that is unmatched in the industry today. It is the tool of choice for design engineers when deadlines are tight and a high degree of unanticipated change is expected. IronCAD's drag and drop 3D environment provides a fresh alternative to traditional history-based parametric systems; delivering unmatched ease of use and superior productivity.
Rapidshare.com Part 1
and
Rapidshare.com Part 2
سوف نقتلهم جميعا وسوف نشرب دمائهم في كاس انتفاضتنا وليكن نخبه الموت لنا ولهم ولتحيا فلسطين
فلسطين والنضال غير موجود حالياً   رد مع اقتباس
قديم 24-06-2008, 01:52 PM   رقم المشاركة : [92 (permalink)]
Cadmai 3.0 | 39,5 MB
CADMAI is a relational 2D and 3D CAD system , which can be integrated in 3rd party applications or in a SOA environment.
Basic Features
* Completely parametric and relational
* Integrated script API which serves as a modeling language
* Can be steered by external applications
* Can be hosted in external applications
* Embedded formula interpreter
* Supports a hierarchical assembly structure
* User defined animations
* User defined entity attributes and methods
* API for embedding CADMAI in external solutions
* Base geometry API for technical applications
Non geometric entities
* User defined dialogs
* User defined objects
* User defined variables
* Attributes
* Tables and row cursors incl. ODBC Database connections
* Layers
* Programming structures (loop/ifthen) which can be integrated in the model
2D entities
* Points (15 creation methods)
* Lines (11 creation methods)
* Arcs (20 creation methods)
* Curves
* Views and sections from solid data
* Hatches/area fill
* Transformations
* Symbols
* Text
* Labels
* Dimensioning
3D entities
* Coordinate systems
* Solid creation (16 creation methods)
* Solid modification (23 methods)
* Polygon based 3D representations (Wavefront/3DS/...)
* Components
* FEM Meshes
Import/Export
* Bill of material (table format)
* DXF, IGES, STEP, VRML, STL, XCAF, PARASOLID/ACIS/3D-DXF on request
* OBJ, 3DS, ASC, X, OBT, IOB, DAT, LWO, C, UDO, RAW, RWX, SCE
* BMP, PNG, JPG, TIFF
* AVI
* User defined export formats
API
* Windows API
enables the user to embed CADMAI Windows in applications. CADMAI herby provides special Window classes which can be used similar to the Common Controls
* Object API
serves as an independent geometric library which can be used outside of CADMAI.
This library includes the following objects:
Points, Lines, Arcs, Curves, Hatches, Matrices, Coordinate systems, Views, Solids,
Greps, Dimensions, Symbols, Texts, Tables, Cursors, Layers, Attributes, Variables, Dialogs
* Batch API
enables the usage of CADMAI batch processes and the control of loaded CADMAI models.
* Connect API
enables the connection to CADMAI batch process at the same or a remote computer and the remote control of the process.
Rapidshare.com
قديم 24-06-2008, 01:52 PM   رقم المشاركة : [93 (permalink)]
والمزيد في انتظاركم
قديم 30-06-2008, 01:23 PM   رقم المشاركة : [94 (permalink)]
الصورة الرمزية moh_farouq
moh_farouq يستحق التميز
اكثر من رائع و متميز فعلا
عندى طلب ممكن برامج للحام؟
شكرا
moh_farouq غير موجود حالياً   رد مع اقتباس
قديم 30-06-2008, 01:58 PM   رقم المشاركة : [95 (permalink)]
مشرف عام
الصورة الرمزية مهاجر
مهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداعمهاجر فائق الإبداع
جزاك الله خير أخي: فلسطين والنضال
موضوع مميز‎ وجهد تشكر عليه ... فلقد اضفت الكثير من البرامج وفي مختلف التخصصات وهذا من حبك لفائدة الأخرين ‎
نشكرك بإسم إدارة الملتقى ... والى الأمام
نتابعك ونتابع جهدك في الملتقى
نحو ملتقى هندسي عربي هـــــــــادف
أعــــــوذ بالله من نفــــــحة الكبرياء
حسبنا الله ونعم الوكيل
مهاجر غير موجود حالياً   رد مع اقتباس
قديم 01-07-2008, 08:06 AM   رقم المشاركة : [96 (permalink)]
شكرا اخي المشرف مهاجر والله كلام طيب جدا وشكرا لك على التشجيع والمتابعة واتمنى دوام التقدم للمنتدى
قديم 01-07-2008, 09:38 AM   رقم المشاركة : [97 (permalink)]
مشرف عام
Thumbs up شكر وتقدير ...
أخي:
ما قيل .. قيل عن إستحقاق .. فلك الشكر على جهدك
اقتباس:
المشاركة الأصلية كتبت بواسطة فلسطين والنضال مشاهدة المشاركة
قديم 20-07-2008, 12:13 AM   رقم المشاركة : [98 (permalink)]
الصورة الرمزية م العراق
م العراق
شكرررررا اخي وتسلم على هذه المجموعه
م العراق غير موجود حالياً   رد مع اقتباس
قديم 20-07-2008, 05:50 AM   رقم المشاركة : [99 (permalink)]
MasterCam X2 MR2 SP1 2CD | 1.2 GB
Mastercam delivers CAD/CAM software tools for all types of programming, from the most basic to the extremely complex. 2-axis machining, multiaxis milling and turning, wire EDM, router applications, free-form artistic modeling and cutting, 3D design, drafting, surface and solid modeling – whatever your machining needs, there is a Mastercam product for your budget and application.
Mastercam Solids
Add this fully-integrated Parasolid-based solid modeler to Mastercam’s award-winning CAM products to create, import, and machine solid models.
Mastercam Design
Streamlined 3D CAD software included in Mastercam Mill, Lathe, Router and Wire. Also available as a stand-alone package.
Mastercam Mill
Powerful, fully associative programming package for 2, 3, 4, and 5-axis milling.
Mastercam Lathe
Associative CNC programming system for simple to complex turning.
Mastercam Router
Easy-to-use associative CAD/CAM specifically designed for routers.
Mastercam Wire
Quick and easy associative wire EDM programming.
Mastercam Art
Easily design and machine beautiful 3D work from flat art, drawings, and photographs. Adds on to Mastercam Mill and Router.
Download
http://www.filefactory.com/file/393461/n/MX2_MR2_pm_txt
قديم 21-07-2008, 01:10 AM   رقم المشاركة : [100 (permalink)]
الصورة الرمزية وحيد الشمري
وحيد الشمري يستحق التميز
وحيد الشمري غير موجود حالياً   رد مع اقتباس
لتصميم, المعمارية, الصور, الهندسة, برامج, رائعه, والصناعية
الساعة الآن 08:04 AM.
