العودة   ملتقى المهندسين العرب > ملتقى البرامج و الانترنت و الكتب > المكتبه الهندسية Engineering ebook Library > مكتبة هندسة الطيران وعلوم الفضـاء Aerospace Engineering
أدوات الموضوع تقييم الموضوع
  #1
قديم 13-04-2008, 04:49 AM
Flight Stability and Automatic Control
By Robert C. Nelson
* Publisher: Mcgraw-Hill College
* Number Of Pages: 286
* Publication Date: 1989-03
* ISBN-10 / ASIN: 0070462186
* ISBN-13 / EAN: 9780070462182
If this is a required text, as it was for me then buy it. The information isnt bad, and gives a good coverage of the subject, but the errata list I receieved from my professor spanned at least 20 pages, front and back. You'll learn controls with the right professor, but expect the book to confuse you with changing subscripts, even changing values in example problems. For example, the area of a wing in one example problem is listed as 945 ft^2 and yet the problem solves using the area of 965 ft^2. Equations will be missing subscripts entirely, or duplicate them. For example, in one end of the chapter section of problems, the 2-D coefficient of lift for the tail is listed twice as opposed to giving you one value for the tail, and another for the wing as they should have. Expect to make assumptions like they have never been made before either. So much will not be given to you, it will be up to you to decide what value is reasonable that youll use. Good luck to you if this is a required text
9.75MB
http://www.filefactory.com/file/00351e/
http://rapidshare.com/files/10681444...rol_Nelson.pdf
automatic, control, flight, stability
الساعة الآن 02:29 PM.
