دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
صفحة 84 من 142 الأولىالأولى ... 347480818283848586878894134 ... الأخيرةالأخيرة
النتائج 831 إلى 840 من 1420
مشاكل تنفيذية وحلول هندسية
السلام عليكم من الاسلئة التي تردد في المشاريع والتي يتم الاختلاف حول الاجابة عليها بين الاستشاري والمقاول. Adding Water On-Site
  1. #831
    إستشاري الهندسة المدنية الصورة الرمزية رزق حجاوي
    تاريخ التسجيل
    Mar 2008
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    Adding Water On-Site to Concrete Mixtures
    هل من المسموح اضافة الماء للخلطة بعد وصلها الموقع ؟
    وللاجابة على هذا التساؤل اقدم لكم هذا البحث
    Adding water on-site to concrete mixtures has been a controversial topic for as long as concrete has been used as a construction material. The addition of water is clearly covered in ASTM C94, Standard Specification for Ready Mixed Concrete. The standard does allow for on-site addition of water to adjust fresh concrete properties so the material as delivered is suitable for the specific application.
    Concrete that is delivered with a low slump may lack the workability for proper concrete placement consolidation and finishing operations. Additionally, low slump concrete mixtures in some cases may be deficient in air ******* for durability in freezing and thawing environments or where the material may be exposed to deicing chemicals. While on-site additions of water may potentially reduce the final concrete strength properties, in many cases the consequences of adding the water may be less detrimental than attempting to place, consolidate, and finish a concrete mixture that that lacks proper workability and/or air *******.
    How Much Can I Add?
    The general rule is that water may be added to adjust the slump of the material to comply with specifications upon arrival as long as the maximum specified water-cement ratio is not exceeded. Typical additions of water on-site are in the order of 1 to 2 gallons (3.8-7.6 liter) per cubic yard (0.8 m3) of concrete (this would amount to 10 to 20 gallons (38-76 liter) of water in a ten cubic yard (7.6 m3)load. A general rule of thumb for the effect of the addition of water to a concrete mixture is an increase in slump of approximately 1 in. per gallon(25 mm/3.8 liter) of water added to a cubic yard of concrete In short, a small addition of water (1 to 2 gal per cubic yard of concrete) can be beneficial to the quality of the hardened concrete when appropriately added (not exceeding the maximum water-cement ratio or maximum revolutions) on-site during the normal course of concrete construction.
    Impact of Water on Concrete Properties
    should you allow water addition on site? ASTM C94, ACI 301, and other building codes allow for it. Many times obstacles such as transportation and weather conditions take away from the workability of concrete. There are pros and cons to consider. Get a realistic look at the effects of adding water to concrete at the job site – including discussion on water-to-cement ratio, testing and chemical admixtures. Then make an educated decision on whether to add, or not to add…
    Upon completing this webinar, the participant should be able to:
    1. Recognize applicable codes and specification requirements on water (ACI 318, ACI 301, ASTM C 94).
    2. Discuss influence of water on consistency of concrete- including sources of water (batch water, aggregates, wash water).
    3. Understand the importance of water cement ratio.
    4. Describe the impact of on-site water addition to consistency, set time, chemical admixtures, strength and permeability.
    Verified participants in this webinar will be awarded 0.1 CEUs (usable for 1.0 PDH in most places) sent via email after submitting an evaluation.
    ومن وجهة نظري اذا اكان هناك نقص في درجة التشغل للخرسانة workability او ان هناك كثافة في التسليح او لاية اعتبارات اخرى فيفضل اضافة مواد مضافة تساعد على درجة التشغيل
    Chemical admixture like super plasticizer بدلا من الماء لان ذلك يحافظ على قوة الخرسانة ويتم اضافة نسبة قليلة وتعطي الغاية المطلوبة اكثر من الماء الذي يؤثر سلبا على الخرسانة.
    من مواضيع رزق حجاوي :
    التعديل الأخير تم بواسطة رزق حجاوي ; 10-04-2010 الساعة 01:07 PM
  2. #832
    تاريخ التسجيل
    Mar 2008
    مكرر بالخطأ مع الاعتذار.
  3. #833
  4. #834
    عضو متميز الصورة الرمزية إسلام علي
    تاريخ التسجيل
    Mar 2005
    للرفع والنفع مع الشكر للمهندس رزق حجاوي :)
    من مواضيع إسلام علي :
  5. #835
    تاريخ التسجيل
    Mar 2008
    French Drain System
    عندما يكون هناك تسرب لمياه الامطار او اي مصدر للمياه حول الابنية فان ذلك يشكل خطرا على الابنية خصوصا اذا كان هناك طوابق تحت مستوى الارض حيث يلاحظ كثيرا تسرب للمياه خصوصا في فصل الشتاء ولمنع هذه المشلكة يتم تركيب نظام تصريف French drain حيث يتم عمل شبكة حول المبنى من المواسير المثقبة( او تكون مشرحة ) UPVC Perforated Pipes ويتم تنفيذها بميول تحت منسوب ادنى طابق تسوية بحيث تتجمع في النهاية في حفرة تجميعية Submersible pit ومن ثم تركيب مضخة غاطسة submersible pumps او اذا امكن يتم تصريفها لمنطقة اخفض اذا امكن ذلك
    واليكم طريقة التنفيذ بالتفصيل
    How to design and build a French Drain / Leach Line
    Many of us have had water problems on the land around our homes and businesses. When the rains come we sometimes end up with water problems that range from bird-baths to small ponds to huge lakes! Oftentimes these water issues affect our homes - and cost in repairs. Grading the land surface, or pouring water-deflecting, sloped concrete are the typical “first choices.” Other solutions involve adding surface drains and diverting problematic water by underground pipe to a better location.
    Sometimes we inherit a soggy-situation or we create our own problems by installing expensive hardscapes that were really great until that first BIG RAIN - when we learned that we failed to adequately-allow for some water situations. In many circumstances there is no where to run drain lines and our choices are very limited…
    Then there are those who must keep the fluids underground - those who need to repair, replace, or add capacity to a Septic System. In this instance, the “French Drain” is called a Leach Line, Leach Field, or Leach System. Whatever the issue, if you have soil that will absorb liquid and you will not create other problems by going underground, then a French Drain / Leach Line may be a solution!
    * * * DISCLAIMER: Please remember - the Posts and Pictures on our site are to assist D.I.Y. folks and contractors who might be new to particular construction challenges. We are not Civil Engineers. You should check with your local building departments before tackling such a project. Septic Systems are usually governed by sets of Health & Safety Rules that will change jurisdiction by jurisdiction. Porting water into the earth on hillsides may cause instability. Be careful. Use wisdom. Check with your local authorities… * * *
    That said - we have built a number of French Drains, Leach Lines and Leach Fields over the years - from long, long trenches that you’d swear could easily handle the runoff from the mighty-Mississippi, to small, but functional 4′ x 4′ square foxholes dug straight down about 7-8 feet deep to handle some runoff on the rear concrete deck of a small condominium…
    No matter the size or complexity - the basics are simple…
    Most French Drain Systems are constructed using simple tools and materials; a Bobcat, a one-day Backhoe rental or just some shovels; woven landscape fabric, (sometimes called: Geo-Textile fabric, landscape fabric, weed-control fabric); pea gravel or crushed rock; and manufactured perforated drainage pipe or heavier-duty pipe that you can perforate yourself…
    We located a ***** of soil downhill from the house, and ran a level mason string such that we ended up with a level area that measured 144 feet.
    We could have rented a mini-excavator for $220, including delivery and pick-up. We should have. Our client wanted to provide some work for a young man - so this 3′x3′x144′ trench was dug by hand in four days. There were some roots that slowed the progress.
    We purchased some Geo-Textile fabric - sometimes called “landscape fabric.” The rolls of this are sized like carpeting in 12′ rolls.
    We lined the trench with landscape fabric, leaving sufficient extra to fold over the top of the gravel
    The trench was big enough (volume wise) that we could have ordered a full truck and trailer of 3/4″ crushed rock - delivered (a Truck & Trailer = 24-Tons). Since this was a more-casual project, one of several concurrent projects being performed during a week when we were at the job site every day anyway, we simply used our trailer for a few loads which we would pick up at a Masonry & Stone Supply Yard.
    The hillside homes we often work at have long, winding, narrow driveways - so the trailer was as effective as a semi-truck delivery. We have a John Deere Skid-Steer at the site (often generically called a “Bobcat”). So scooping the gravel up and getting it to the trench was a snap.
    We are really enjoying this trailer - can you tell?
    Contractors around the U.S. use all manner of rock sizes for drainage projects. Most French Drains are going to be so effective that you will never surpass their capacity. 3/4-inch crushed rock is extremely common, and priced right too.
    Many contractors will place their perforated pipe close to the bottom of the trench and expect the liquids to rise above the pipe. We find that “set-up” is asking for problems as any solids or silt that may get through the landscape fabric will tend to collect inside the pipe.
    We want to fill up our 3′ x 3′ trench about 2/3’s to 3/4’s high with crushed gravel. We are placing the gravel carefully so that it is level when time to place the pipe.
    If you have a mason string or laser level - you will want to double check your gravel bed before getting to the next step.
    With a 144′ Mason String now pulled taunt - we checked that it is level. Now we are ready to lay our home-made, perforated, 4-inch pipe. We want the pipe level so that when water is flowing slowing into the pipe that it will travel THE ENTIRE 144-FOOT LENGTH of our pipe before the water rises high-enough to the level of the perforated holes. Then the water will ooze out along the ENTIRE LENGTH of the trench.
    We are going to set up a simple Laser Level, then adjust the Remote-Sensor on our Level-Stick. As we touch the “Level Stick” to the top of the perforated drain pipe, we dig the pipe into the gravel or add gravel under the pipe every few feet as we MAKE CERTAIN that our DRAIN PIPE is PERFECTLY LEVEL.
    The gravel was pretty uniformly placed and raked level to that string before we started. Kicking gravel with shoes here or there is about as difficult as it is to level the pipe. AS WE LEVEL THE PIPE we scoop more gravel ON TOP so as to hold the pipe “in place.”
    The holes in the pipe (as seen in the photo below) are not yet pointed correctly - so please do not make any assumptions. We have made our own perforated pipe - as we wanted to buy stronger, schedule-40, Sewer Pipe (available at any Home Depot, Lowe’s, etc…). We drilled 2 parallel rows of 5/8″-inch diameter holes using a new, sharp, hole-saw bit every 6-inches on the pipe. Since we had a lumber-rack on our truck, we purchased 21′ 4-inch pipes - so that is 2 rows of 42 holes - or 84 holes per pipe length. Over our trench of 144 lineal feet we have approximately576 drain holes.
    Laser Levels are so inexpensive these days - and so useful. This is very basic. We could have clipped the sensor to a tree branch - it doesn’t matter… What is important is that when the “stick” is on top of the pipe a-n-y-w-h-e-r-e on the 144-feet of pipe that the sensor is “chirping” its “I am level tune…
    As one person double-checks the pipe, two helpers adjust the gravel accordingly - adding gravel on top of the pipe too.
    It is a good idea to bring up the ends of the pipes at each in if you are constructing a single-pipe French Drain / Leach Line.
    These “RISERS” are capped and a “Sprinkler Valve” Access Box is placed over these access points to keep its location “known” and to protect the pipe from damage.
    See the Orange Cap? Put caps on the pipe to keep rodents and debris from getting into your drain line.
    Now we have two clean-outs should we ever need them.
    A second perforated pipe is put into the trench all the way to the bottom of the trench so that you can test the “liquid-level” in your gravel with a test “Dip-Stick.” This is more-common in Septic System Leach fields - for maintenance and performance testing.
    The next step is to fold the Geo-Textile Landscape Fabric over the gravel - so well that soil will not easily breach our fabric barrier. We use galvanized 10-d or 16-d nails to “PIN” the fabric together. Pin it like you pin a name-tag to a shirt or blouse.
    Cover over your trench with soil (as we are planning to do), perhaps pour a concrete walkway on top, maybe build a paver walkway on top, put more gravel on top and place stepping stones in the covering gravel if this drain area will help with other runoff issues.
    Trim your Clean-Out “Risers” just below the level of the surface and protect them with inexpensive valve cover boxes. Here is our East End.
    Here is our West End.
    التعديل الأخير تم بواسطة رزق حجاوي ; 24-04-2010 الساعة 05:31 PM
  6. #836
    المصري3 Don't Avatar
    تاريخ التسجيل
    Dec 2009
    مهندس رزق السلام عليكم وجزاكم الله خيراً على هذه الاطروحات الممتازة .
    مهندس رزق أنا الأن بصدد عمل بحث عن تصميم الواجهات الزجاجية structural glazingفأتمنى أن أستفيد من خبرة حضرتك إن أمكن بتزويدي بأي تفاصيل عن تصميم هذه الواجهات من حيث تصميم قطاعات الألومنيوم وكيفية حساب مقاساتها وكيفية حساب أكبرمقاس ممكن لضرف الزجاج وخلافه , وبعض الإعتبارات التي تأخذ أثناء التركيب ولسيادتكم جزيل الشكر.
    من مواضيع المصري3 :
  7. #837
    تاريخ التسجيل
    Mar 2008
    اقتباس المشاركة الأصلية كتبت بواسطة المصري3 مشاهدة المشاركة
    بخصوص الواجهات الزجاجية structural glazing
    قبل البدء لنعرف معنى الواجهات الزجاجية الانشائية
    Structural glass is glass which has gone through a manufacturing process to enable it to be used for structural elements of buildings. The resulting product enables walls, floors and ceilings in buildings to be transparent and can even be load bearing. Structural glazing is made by "heating sheets of glass uniformly after manufacture until it is plastic and then rapid cooling with jets of air. The outer layers closest to the jets of air cool and solidify first; they contract as they cool. As the inner layers try to follow they throw the outer layers into compression. This process creates a glass that is about 7 times stronger than ordinary / untreated float glass."
    ان لكل شركة مصنعة لها المقاطع الخاص الخاصة بها وهي تكون مسؤولة عن تقديم الحسابات الانشائية واجراء التجارب على الواجهات الزجاجية وبشكل عام فان هناك متطلبات عامة يجب ان تحقق عند تقديم اي شركه لمنتجاتهامن حيث :-
    1. الحسابات الانشائية التي تثبت قدرة الواجهات على تحملها حسب المتطلبات التصميمية من حيث ( سرعة الرياح ، العوامل الحراية وهي التمدد والتقلص، وقوى الصدم وغيرها من الاحمال والقوى ..... ).
    2. المقاطع التفصيلية للواجهات العمارية ومناطق التثبيت وطريقة الثبت مع الحسابات لانشائية اللازمة.
    3. عازلية الزجاج للحرارة ولاشعة الشمس U-Valueبحيث تحقق العازلية المطلوبة حسب متطلبات التكييف وحسب معامل العازلية يختلف الحمل الحراري سواء للتبريد او للتدفئة تبعا لذلك.
    4. مدى وضوح الرؤيا من خلال الزجاج.
    5. متطلبات خاصة من حيث مقاومتة للحريق او للرصاص او للانفجارات .
    6. تقديم الشهارات والفحوصات من جهات معتمدة تثبت الخصائص المطلوبة ومطابقتها للمواصفات.
    7. اجراء التجارب الموقعية من حيث كتامتها للتسرب ومقاومتها للرياح ( حسب ارتفاع المبنى والسرعة التصميمية للرياح ) في مختبرات الفحص.
    هذا بشكل عام وللمزيد اليك هذه الابحاث والكتب
    http://uploading.com/files/KIR2HSTE/...dings.zip.html
    http://depositfiles.com/en/files/f6e97mrdl
    http://www.techno-preneur.net/inform...e-of-glass.pdf
    واليك ما تم نشرة سابقا بخصوص طلبك
    مطلوب بحث عن cladding system باللغه الانجليزيه
    مطلوب تفاصيل عن ال Cladding للواجهات ..........
    Great Glass Building
    http://uploadbox.com/files/bd6af5679b
    http://uploading.com/files/6WU21SVP/...lding.rar.html
    http://depositfiles.com/en/files/9yd12w79o
    http://www.dowcorning.com/*******/pu...2-0979c-01.pdf
    http://www.buildnova.com/buildnovav3...g/sglazing.htm
    تفاصيل المقاطع
    http://www.google.jo/images?hl=en&q=...ed=0CDkQsAQwAw
    التعديل الأخير تم بواسطة رزق حجاوي ; 10-05-2010 الساعة 06:23 PM
  8. #838
    عضو متميز جداً الصورة الرمزية ايمن حسين
    تاريخ التسجيل
    May 2006
    موضوع مهم وشيق
    جزى الله خيرالجزاء كل من شارك
    من مواضيع ايمن حسين :
  9. #839
    تاريخ التسجيل
    Dec 2009
    مهندس رزق متشكر جدا جدا جدا وجزاك الله خيراً
    من مواضيع المصري3 :
  10. #840
    احمد قديس Don't Avatar
    تاريخ التسجيل
    Mar 2008
    Lightbulb ارجوو الرد
    في البداية احب احيي كل القائمين علي هذا المنتدي الجميل وعلي كل المهندسين الذين يشاركون بارائهم ومقترحاتهم العملية وخبرتهم الواسعة وان شاء الله يكون عملا يتقبلهم الله منهم ويكون من الاعمال الباقية
    وثانيا احب اشكر صاحب الموضوع لانه موضوع فكرته في غاية الروعة
    ثالثا اليكم مشكلتي واتمني ان اجد الحل العملي الهندسي
    قمت بعمل تصميم لمنزل وبسبب انشغالي واستعجال صاحب اللمنزل في البناء لظروف خاصة به فلم اكن اتابع المقاول المنفذ بصورة جيدة وقام بعدم تنفيذ بعض الاجزاء اما لقلة خبرته او عدم تمكنه من تنفيذها او لاي سبب اخر
    المهم مدرج صورة توضح الجزئية التي تجاهلها
    1- الدائرة الكبيرة ( المشكلة الاولي )
    الكمرة محمل عليها كمرتين هل هناك مشكلة انشائية في ذلك (كمرة محمل عليها كمرتين ) ؟؟؟؟
    طول الكمرة المحمل عليها تقريبا 4.5 م
    الكمرة الاولي المرتكزة عليها تقريبا 3.5 م
    الكمرة الثانية المرتكزة عليها 1.20 م
    قطاع الكمر60*25 سم
    الدائرة الصغيرة وهي المشكلة الاكبر
    في التصميم كانت الكمرة تصل حتي العمود المقابل ولكن المقاول لم يفعل ذلك وربطها مع الكمرة المتصلة بالعمود الذي في زاوية المبني فاصبحت الكمرة مثل حرف l اي غير مرتكزة علي عمود في زاويتها ( اصبحت الكمرة تحمل كمرة ) فهل هناك مشكلة علما ان المقاول قام بزيادة الحديد في هذه المنطقة ( عمل مخدات او فواتير )
    وهذا التصميم للدور الارضي فهل عمل حائط سمك 25 سم يقوم بحل المشكلة لانه سيحمل الكمرة فوقة ويوزع الاحمال علي الارض مباشرة
    بحيث نتلافي هذا الخطاء مستقبلا بالغاء العمود الموجود في الزاوية ومد الكمرة الي العمود المقابل ابتداء من الدور الاول ؟؟؟
    قبل ان يتهمني احد بسوء توزيع الاعمدة والكمرات والتصميم الانشائي عامة فاحب ان اقول ان بعض الاعمدة كانت موجودة في الموقع قبل البدء في التصميم اي انها مفروضة علي
    ثانيا انا مهندس معماري وليس انشائي
    اتمني الا يكون هناك مشكلة انشائية
    وارجوو الرد بحل عملي ان كان هناك مشكلة ليمكن حلها
    تحياتي لكم اخوتي في الله
    من مواضيع المصري3 :
المواضيع المتشابهه
  1. اعاده رفع ملف مشاكل تنفيذيه وحلول هندسية للمهندس رزق حجاوي على الميديافاير
    بواسطة خلوف العراقي في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 17
    آخر مشاركة: 18-05-2013, 06:01 PM
  2. مشاكل المنظفات وحلول تلك المشاكل
    بواسطة احمد هلطم في المنتدى قسم الصناعات الخفيفة
    مشاركات: 117
    آخر مشاركة: 21-11-2012, 08:19 PM
  3. مشاكل وحلول
    بواسطة eng.thualfiqar في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 3
    آخر مشاركة: 30-07-2011, 04:57 PM
  4. مشاكل وحلول
    بواسطة زيد عبدالهادي في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 2
    آخر مشاركة: 18-07-2011, 01:17 AM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
